Arborwear
Author Topic: cutting with lucas mill  (Read 507 times)
Offline j78blake
  • Gender: Female
  • His Will Sawmill
« on: March 29, 2018, 01:43:37 PM »
the vertical cut is not matching up with the horizontal cut anymore. it's off by a 1/6 of an inch.  :-\
Offline starmac
Re: cutting with lucas mill
« Reply #1 on: March 29, 2018, 02:52:34 PM »
I can offer no help, but want to see the answer also, as this is something I have wondered about on these mills.
Offline thecfarm
« Reply #2 on: March 29, 2018, 05:23:34 PM »
Welcome to the forum.
Just guessing,got a tooth out of whack? When did this all start to happen?
I have only seen them at a show.
Offline j78blake
  • Gender: Female
  • His Will Sawmill
« Reply #3 on: March 29, 2018, 06:59:04 PM »
It's not the blade. Or the teeth. This has been going on since last fall. We quit milling in the winter. Enough to be aggravating.  ::)
Online Don P
    • Calculator Index
« Reply #4 on: March 29, 2018, 08:54:18 PM »
It's almost always the log moving, tension being released. Can you move over a little more on the horizontal cut to release it? Take a couple of light cuts that are too small to release any tension, just to "prove" whether the lines are meeting.
Offline Dakota
  • Swing'en in South Dakota
« Reply #5 on: March 30, 2018, 09:49:19 AM »
What Don P said.  Mine moved a little like that after the first 5 or 6 years.  I got out the manual and readjusted the blade settings, and that cured the problem.
Dave Rinker
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #6 on: April 02, 2018, 09:15:11 PM »
The vertical cut is not deep enough or misses the horizontal cut left or right ??
D
Offline Lucas_USA
« Reply #7 on: April 06, 2018, 12:52:02 PM »
I would try a new blade before making adjustments. If you have had your blades retipped its important to keep in mind the tip to tip diameter is crucial to match up your cuts. If you are certain it isn't the blade I can send you an instructional DVD that goes over the adjustments you might need to make.
Offline j78blake
  • Gender: Female
  • His Will Sawmill
« Reply #8 on: April 09, 2018, 11:45:07 AM »
That would be great. Po Box NKI
Ketchikan, AK. 99950
Much appreciated!
Offline Lucas_USA
« Reply #9 on: April 09, 2018, 05:53:19 PM »
Much appreciated!
Sure PM me your mills serial number and I will get one on its way free of charge.
thumbup
Lucas cutting 'issue'
Started by sigidi on Sawmills and Milling
Last post March 15, 2015, 04:04:54 AM
by sigidi
Cutting beams on the Lucas
Started by brdmkr on Sawmills and Milling
Last post April 24, 2009, 09:43:29 PM
by brdmkr
Any Lucas owners with the tie cutting kit here?
Started by EJ on Sawmills and Milling
Last post June 07, 2004, 06:44:47 PM
by EJ
Lucas Slabber cutting downward
Started by Seaman on Sawmills and Milling
Last post January 11, 2018, 06:04:17 PM
by xlogger
