Arborwear
Author Topic: Husqvarna 455  (Read 1298 times)
Offline Rob30
Husqvarna 455
« on: March 29, 2018, 08:40:27 PM »
My husky 455 has been giving me trouble pretty much since new. I find it does not like to idle for any length of time and if it does, as soon as I hit the throttle it dies. Starts right back up, but gets pretty annoying when working. Lately I find it is flooding, stalling more frequently. If I hit the brake it dies. I am thinking the carb was out of adjustment. I turned up the idle screw to see if that helps, but it did not. It is idling fast enough the chain is always spinning, and it still stalls. I will try to clean the air filter better on my next day off, to see if that helps.
Offline Rebarb
Re: Husqvarna 455
« Reply #1 on: March 29, 2018, 09:11:23 PM »
I've had several Rancher's and absolutely loved them.
Sounds definitely like a L adjustment....starving.
Run 93 Octane non ethenol if possible.
Offline Rebarb
Re: Husqvarna 455
« Reply #2 on: March 29, 2018, 09:18:11 PM »
Ooooops missed that.....the spinning chain represents a high idle but get your L set right.
I tune by ear so whats that mean ?
Turn up your idle screw and go ahead and let the chain spin then find the middle of your L adjustment, should sound pretty smooth.....now turn the L counter clockwise until it starts to bog slightly, should be good.
Then you can adjust idle so chain doesn't spin.
Offline mike_belben
  • Pulp Friction
Re: Husqvarna 455
« Reply #3 on: March 29, 2018, 09:42:17 PM »
Crank up the LA screw and get it running fast.  Adjust the L screw until you find the highest idle speed then turn LA back down until chain stops walking/shuddering.
Now adjust the H screw so that at WOT no load there is a bit of a raspy burble called 4 stroking, this is a rich condition.  You have nailed the H setting when dogging into the wood makes that burble suddenly shift to a crisp clean dirtbike sound, called 2 stroking.  Lift off, raspy.  Dog in, sharp.
Revelation 3:20
Offline Rebarb
Re: Husqvarna 455
« Reply #4 on: March 29, 2018, 10:04:16 PM »
^ that there.
Offline wild262
Re: Husqvarna 455
« Reply #5 on: March 29, 2018, 10:15:15 PM »
          If the carb. adjustment won't correct it, than I would be looking for 3 things.  May need carb kit, clutch springs weak, or a air leak.  Those 3 things usually fixed most of those symptoms for me.
Offline Woodcutter_Mo
Re: Husqvarna 455
« Reply #6 on: March 30, 2018, 07:08:06 AM »
 That sounds like what my 455 started doing quite some time ago. A carb adjustment fixed mine, and also replacing the fuel lines, fuel filter and primer bulb fixed a later issue that acted similar.
I don't know how common it is, but I've read where these saws are sometimes set pretty lean from the factory. I'd first look at the carb adjustments or if you're not confident with it, bring it to a professional to have the tuning checked. Good luck
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, 550XP/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball  bed, '07 Honda Rancher
Offline wild262
Re: Husqvarna 455
« Reply #7 on: March 30, 2018, 08:11:41 AM »
     As Woodcutter said, fuel lines might be the best place to inspect before going any further.  Just a pin hole can suck air causeing carb tuning impossible.  If no change, you can rule that out.
Offline John Mc
Re: Husqvarna 455
« Reply #8 on: March 30, 2018, 01:03:13 PM »
It sounds like a mixture problem (though I wold not discount the other possibilities mentioned here about fuel lines, filters, etc.). If you are not familiar with adjusting the mixture or with what a saw should sound like when properly tuned, I'd suggest taking it somewhere to get this adjusted.
If you want to try this yourself, take a look at the Madsen's Chainsaw Maintenance & Repair page. Click on the "Saw Tuning" link there. They walk you through the process, including playing some recordings of what the saw should sound like when properly tuned (you'll need GOOD speakers/headphones to hear this properly - many laptop speakers are just too cheap to play this back properly).  It's not rocket science, but you should be aware that doing it incorrectly (particularly the high speed mixture) can damage your saw.
Offline Rob30
Re: Husqvarna 455
« Reply #9 on: March 30, 2018, 09:25:41 PM »
Thanks, I will be trying to adjust the carb, I have done other small motors but never a saw. Could be a mixture issue as well. I had my daughter pick up my gas, I think she bought regular gas not supreme. But these issues were there before, maybe just not as bad. The stalling does drive me nuts, especially when in the middle of cutting a big tree or fighting through limbs of a dense spruce.
Offline mike_belben
  • Pulp Friction
Re: Husqvarna 455
« Reply #10 on: March 30, 2018, 10:07:51 PM »
I dont think i have EVER put 93 in a saw.  Higher octane is only for detonation resistance, it has a higher flash and autoignition temp so it burns slower. The only time high test ever makes more power is when it staves off knock thats preventing a timing advance.
At 10 to 12,000 rpm you arent gonna have knock issues.  There are not enough microseconds available to the combustion event for heatsoak to cause detonation of the fuel in the chamber.  Thats what knock is.
Revelation 3:20
Re: Husqvarna 455
« Reply #11 on: March 31, 2018, 01:16:50 PM »
 Be sure and let us know what you find out  :)
Offline Rob30
Re: Husqvarna 455
« Reply #12 on: March 31, 2018, 08:36:20 PM »
I will let you all know how it goes. I watched a couple videos on carb adjustment just to refresh my memory. I won't get at it until next week, I work all weekend and Monday I have to go get hay off the fields before the thaw, things are starting to warm up here.
Offline Spike60
Re: Husqvarna 455
« Reply #13 on: April 03, 2018, 07:11:12 AM »
ALL 455/460 Ranchers need to be adjusted by the seller when new. As Rob posted his saw has had this problem since new, I suspect it was never properly set up. These saws are all too lean as they come out of the box, and act just as Rob described. Both the hi and lo usually need to be opened 1/8 to 1/4 turn for the saw to run properly. Solves the stalling issue and you'll have more power and quicker acceleration.
Husqvarna-Jonsered
Ashokan Turf and Timber
845-657-6395
Offline DelawhereJoe
  • Trapped in Delawhere
Re: Husqvarna 455
« Reply #14 on: April 03, 2018, 08:59:36 AM »
A friend of mine has a 455 and its a great running saw, its 8 years old never had a new airfilter or spark plug , gas sits in it from one use to the other chain doesn't get sharpened only replaced once it doesn't pull dust anymore. But she starts and runs whenever she is needed.
Offline mike_belben
  • Pulp Friction
Re: Husqvarna 455
« Reply #15 on: April 03, 2018, 09:57:25 AM »
I think most of us would call that luck   :D
(I wish mine was that good)
Revelation 3:20
Offline John Mc
Re: Husqvarna 455
« Reply #16 on: April 03, 2018, 10:05:05 AM »
Good advice, and all dealers should be doing this. If you are doing it at home and unfamiliar with the process, it's complicated by the fact that these saws come with adjustment limiters on the mixture screws which may prevent you from enrichening the mixture enough. (And I'm guessing that these days, the adjustment screws all have those funky heads on them to make the process even more of a pain in the neck)
Offline Rob30
Re: Husqvarna 455
« Reply #17 on: April 03, 2018, 08:53:35 PM »
Well it is not just a carb issue. I took the cover off to look at the clutch springs as suggested, soon as I touched them with a screw driver (trying to see if there was any play etc.) one of the springs broke in two. The clutch was also covered in burnt chainsaw oil.
That being said I think there is still a carb issue. As most a few have mentioned is seems to run lean. I made up an adjustment screwdriver out of an old screw driver. Seemed to work. I will replace the springs tomorrow and see if I can adjust the carb before getting back to the firewood pile.
Offline knuckledragger
Re: Husqvarna 455
« Reply #18 on: May 03, 2018, 04:02:29 AM »
I sold a 455 last fall to a man who can't say enough good about the saw.  The saw was a trade in on a 51 believe it or not. The reason for trading the saw was for the same symptoms mentioned in the original post. I simply cleaned up the saw and made the necessary H L adjustment and viola two happy saw owners.  The man who has the 51 says that it is the best saw he has ever owned. Lean factory carbs setting.
Husqvarna 285CD & Husqvarna 375K concrete saw
Started by Coach on For Sale
Last post June 25, 2014, 12:30:04 AM
by hacknchop
husqvarna 40
Started by Jims small husky on Chainsaws
Last post March 03, 2011, 09:38:05 AM
by NCFarmboy
Husqvarna 66???
Started by derailedbus on Chainsaws
Last post February 22, 2004, 01:47:42 AM
by Stan
Looking for New Husqvarna
Started by KYCase511 on Chainsaws
Last post March 17, 2016, 07:01:42 PM
by RIDE-RED 350r
