Author Topic: Scored piston on my 034 AV, time to replace?  (Read 435 times)
Offline Falcone
  • Member*
« on: April 01, 2018, 08:56:51 PM »
Well, my first post here and with the couple minutes poking around it looks like I知 going to have hours of great reading material here. I値l just cut to the chase though.
I recently picked up an older 034AV Stihl to fill the gap in my line up between my 291C-BE and my 660 mag. Got it for a song at $40, was told it was hard to start and won稚 stay running, bogs and dies. I hoped it was a plugged carb or spark arrestor screen. Something cheap and easy. Well would not appear the case.
How bad does this piston look? (Having trouble uploading the picture, will edit the post shortly)
When I pull it over slow with the muffler off, I can see the gas squish by the sides of the piston and bubble up a bit. It feels like the saw has 1/2 decent compression. Anyone able to tell me what it should be at?
Offline sawguy21
Re: Scored piston on my 034 AV, time to replace?
« Reply #1 on: April 01, 2018, 09:40:33 PM »
Welcome aboard, glad to have you with us. A healthy saw should have at least 125psi compression. A quick way to check is by holding the saw by the starter handle, if it drops it needs freshening up.
Before tearing into it you shold have the crankcase pressure/vacuum tested. A problem with seals or gaskets leaking will show up, no point replacing the top end only to have another failure. For help posting pictures scroll to the bottom of the home page for a tutorial. Good luck and keep us posted.
Replace piston rings, piston, or cylinder?
Started by Spruce_Goose on Chainsaws
Last post May 11, 2014, 10:28:50 PM
by Al_Smith
stihl 460 scored jug and piston
Started by Randy88 on Chainsaws
Last post July 04, 2016, 11:26:55 PM
by farmguy
Echo scored piston
Started by sawwood on Chainsaws
Last post March 31, 2005, 10:29:21 PM
by mshillbilly
056aveq scored piston
Started by wood monger on Chainsaws
Last post February 17, 2010, 09:04:52 AM
by wood monger
