Author Topic: 045 stihl  (Read 367 times)
Offline welderskelter
045 stihl
« on: April 03, 2018, 08:34:03 PM »
I bought a 045 stihl for 10.00 without a rewind on it replaced that and got it running. Then it died after about 10 cuts. I rebuilt the carb. But it still didnt run.Took the clutch off to get to the crank seal because I couldnt get a vacumn in the case. Thats when I found it. The little pin that is supposed to run the oil pump had come thru from the clutch hub and wiped out the oil seal. There must be a washer or something that is supposed to prevent that. I havent got a book on a 045 av yet so if anyone out there does could you please let me know. Or maybe there is someway to prevent this from happening again. Thank you all. Harold
Re: 045 stihl
« Reply #1 on: April 04, 2018, 03:00:35 PM »
Ok, I found that there is supposed to be a washer in there. I found all you have to do is type in your saw size on google and BINGO. I hate to admit but I will that my wife showed me. :D
Does Stihl have a different mount size at the studs for bigger and smaller Stihl
Started by quietrangr on Chainsaws
Last post October 09, 2011, 08:25:11 AM
by Al_Smith
Mounting Cannon S2 (big Stihl) 42" bar on MS661 (small Stihl)
Started by neildorin on Chainsaws
Last post September 11, 2017, 06:01:44 AM
by Al_Smith
There are Stihl dealers then there are Stihl sellers.
Started by Ward Barnes on Chainsaws
Last post January 31, 2012, 11:16:22 AM
by tcrew
Ordered Stihl 261 C-M & Received Stihl 261 C-MQ
Started by beeser on Chainsaws
Last post February 12, 2019, 07:55:24 AM
by Pulphook
