Author Topic: Mini log Loaders  (Read 3660 times)
Offline thecfarm
Re: Mini log Loaders
« Reply #20 on: October 31, 2018, 02:06:16 PM »
Good size log you got up in the air there.
Offline John Mc
« Reply #21 on: October 31, 2018, 04:09:25 PM »
That was the previous owner. My tractor is on loan to a friend who is digging a garage foundation and doing some long-overdue driveway maintenance. I can't get my truck out on to the trails on my property: one way is too wet, the other is still waiting for me to build a bridge.
Offline Puffergas
    • Puffergas
« Reply #22 on: November 01, 2018, 07:45:18 PM »
I don't understand the language but kind of interesting machine.
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, IHC 300 Utility, Timberjack 225D, Burg Bandsaw mill, Steiger Bearcat II
Offline jimbarry
    • WoodchuckCanuck
« Reply #23 on: November 02, 2018, 08:30:22 PM »
 If the ground is soft I'll drop down plywood sheets. But the MTL has the same compression as that of a 400lb man with a size 12 foot. So relatively low impact. Its only if you have to turn a bit when the damage can occur.
Jim
2017 Nyle L200
8ft x 10 ft x 20ft bldg
3.5-4" 2lb closed cell spray foam, Demilec brand HeatLok Soya Spray Polyurethane Foam Insulation
Offline Treepro123
« Reply #24 on: November 02, 2018, 08:34:26 PM »
Hello magicman, thanks for the welcome.
Offline Skeans1
« Reply #25 on: November 03, 2018, 08:41:53 AM »
Thatís an original Blondin Rottne forwarder they started life as ford tractors.
Looking at log loaders
Started by flyboy16101 on Sawmills and Milling
Last post October 14, 2016, 01:05:38 PM
by etroup10
Anyone ever been around one of these loaders ???
Started by BargeMonkey on Forestry and Logging
Last post June 29, 2016, 10:52:16 PM
by BargeMonkey
loaders
Started by xlogger on Sawmills and Milling
Last post August 30, 2017, 07:24:51 PM
by Brandon1986
self loaders
Started by sjfarkas on Forestry and Logging
Last post March 02, 2012, 12:46:05 AM
by sjfarkas
