Author Topic: Large area tree fall  (Read 795 times)
Offline mfraser
  • Member*
« on: April 05, 2018, 10:27:54 AM »
Hi, first time here, with a question if I  may?
What is the term used to describe an area of a forest where a wind (Chinook or the like) has produced a swath of trees down. the Phenomenon is a 'scar' on that area which tends to advance (as observed from nearby higher ground)with the prevailing winds over the years, as exposed trees on the lee side of the gap are toppled in succession by ensuing storms.
thanks for any suggestions.
regards
martin
Offline Klunker
Re: Large area tree fall
« Reply #1 on: April 05, 2018, 02:14:37 PM »
Windthrow is the term I think your looking for.
Offline reride82
« Reply #2 on: April 05, 2018, 02:22:21 PM »
I've always heard those areas/storms called microbursts.
Levi
'Do it once, do it right'
'First we shape our buildings, then our buildings shape us'
Living life on the Continental Divide in Montana
Offline mike_belben
  • Pulp Friction
« Reply #3 on: April 05, 2018, 02:47:01 PM »
windthrow and blowndowns are what i think of them as.
Are the trees snapping off or is the whole root system turning up?
Shallow soils over rock ledge are prone to blowdowns during heavy wind and rain.  Really wet soil lubes up the whole rootball pretty good.   Once this hole is made in the forest its natural for the next wave to go over.  They are taking a bigger brunt of open wind and are lacking their former partners to lean on.
Revelation 3:20
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #4 on: April 05, 2018, 03:38:53 PM »
I hear windfell as well.  I think windfell is the verb and windthrow the noun.  Though some use interchangeably.
In the long run, you make your own luck good, bad, or indifferent. Loretta Lynn
What tree did you fall from?
Last post May 13, 2008, 09:09:05 AM
by tcsmpsi
Ash tree fall fail
Started by wbrent on Forestry and Logging
Last post April 14, 2019, 09:15:41 PM
by Ron Scott
Any recommendations on who to call for milling a large oak in Tampa area?
Started by cdb529 on Sawmills and Milling
Last post November 19, 2014, 12:44:51 PM
by cdb529
apple sometimes doesn't fall far from the tree
Started by timberlinetree on General Board
Last post April 26, 2015, 06:27:35 AM
by timberlinetree
