Author Topic: Which brand tire chains  (Read 1409 times)
Offline goat704
« on: April 09, 2018, 04:03:46 PM »
Hey guys, newbie here.
I'm ready to buy some chains for my compact tractor with Farmi 351 winch.
I would like opinions regarding Ofa EKO8's vs Aqualine Talon's vs Tryg SMT 8's.
It looks like I can get my choice for around the same price. 700.00 - 800.00 w/shipping.
I'm going to be skidding deadfall and selective cut's on my own property, no pavement travel.
Offline Tin Horse
Re: Which brand tire chains
« Reply #1 on: April 09, 2018, 07:51:36 PM »
Welcome.
Don't know much about the other brands but mine are older Trygg's. They've worked great for me.
Bell 1000 Wood Processor. Enercraft 30HTL, Case 580SL. Kioti 7320.
Offline thecfarm
« Reply #2 on: April 09, 2018, 08:46:19 PM »
Winter time use? Logging with the tractor full time?
Offline goat704
« Reply #3 on: April 09, 2018, 11:01:57 PM »
Yes mainly winter use or bad mud. My logging will consist of cleaning up my 20 acres of old growth,
with lots of deadfall and selective thinning.
Offline 47sawdust
« Reply #4 on: April 10, 2018, 05:37:07 AM »
Where do you live? All the brands you mentioned will work just fine.
Mick
Offline goat704
« Reply #5 on: April 10, 2018, 10:20:13 AM »
I'm in Northern Mn. I do realize they would all work, just wondering if there are
Favorites amongst you guys.
Is any one brand made better, or with tougher materials, lasts longer?
I only want to spend money on chains once.
skidders and construction machines.
EKO 8 & EKO 9 TIRE CHAINS
The EKO 8 has 8 mm chain links and 9 mm studs. The side chain is 8 mm.
The EKO 9 has 9 mm chain links and 10 mm studs. The side chain is 9 mm.
 Use these tire chains on machines for snow clearance, agricultural and light forest work.
I've found a supplier for the EKO8 at 475.00, think my decision is made.
Offline barbender
« Reply #6 on: April 10, 2018, 11:28:13 AM »
I've never bought tractor chains, but I do have some experience with chains on large forwarders. We put some Nordic brand chains on one machine, that I have been very impressed with. They don't stretch, very heavy duty. I don't know if they make them for tractors.
Offline Stephen
  • Glad to be part of a great group.
« Reply #7 on: April 10, 2018, 01:01:06 PM »
I have Norse chains on my Ford NAA, and Trygg on my Fiat 45-66DT. Careful of fender clearance on the compact tractor. They make wheel spacers, but not cheap.
1994 WoodMizer LT40G18. 69 acres mixed wood. 1952 ford tractor, Norse 290 winch, studed Norse ice chains. 45-66DT Fiat.
Offline Tin Horse
« Reply #8 on: April 10, 2018, 07:12:20 PM »
I run mine all winter for sawmill logs and firewood. FX 90 winch. Especially good on ice. They're easy to take off but I hate putting them on. My son loves it so he does it now. 8)
Offline John Mc
« Reply #9 on: April 10, 2018, 08:08:38 PM »
Goat704 -
You've mentioned three brands all of which have an excellent reputation and are a good choice for using a tractor in the woods. I have the Ofa Eko 8 chains on my tractor and have been very happy with them. I'm sure I'd have been just as happy with the Trygg or Aqualine of similar design.
I started out with 4 link ladder style with v-Bar. These worked well for clearing snow from my gravel driveway (though would have been just "OK" had I been using a front mounted snow plow due to more limited lateral traction than other options), and was fairly good when traveling at higher speeds over the road. It was not so good working on side-hills in the woods.
I next tried studded Duo-Grip style chains. These were good clearing snow on the driveway, and had good lateral traction for use on side-hills in the woods. They were horrible at high speeds on the road (even gravel roads). I wasn't sure what I was going to shake apart first: my tractor or me. This was an issue, since I regularly need to run my tractor over the road between two properties. I did not even make it through one winter with them, though they would be fine for someone who did not need to do over-the-road transport.
The Ofa Eko 8 chains are definitely keepers. Excellent forward and lateral traction, on the driveway and in the woods, and a smooth ride for over-the-road transport. I've got a smaller tractor with a Uniforest 35E logging winch (similar capability to a Farmi 351) and a Sundown GR40 Forestry Grapple on the front. I use it in the woods regularly on my own property and when working with others in their woods. The chains have made a huge difference.
I've not used the Aqualine or Trygg, but the design is similar and should produce similar results.
Offline goat704
« Reply #10 on: April 10, 2018, 09:59:42 PM »
Which ones do you use?
Offline Tin Horse
« Reply #11 on: April 10, 2018, 10:36:11 PM »
I use the Trygg"s. I'm sure they're all good. My son gets them on tighter than I can but no movement on roads with varying terrain. They're off now for the season. Tough on the ground when not frozen or snow covered.
Offline goat704
« Reply #12 on: April 10, 2018, 10:59:32 PM »
I would like to thank everybody for your time and input!
I'm going to order the EKO 8's as I think the price REED'S quoted is outstanding for this quality of chain.
LOG ON.
Tire chains
Started by Dave Shepard on Forestry and Logging
Last post January 03, 2008, 04:18:14 PM
by Ed_K
Tire Chains
Started by Stephen1 on Wanted
Last post February 03, 2009, 09:39:14 AM
by wdncno
Tire chains
Started by Plankton on Forestry and Logging
Last post January 05, 2016, 01:13:42 AM
by Nemologger
diy tire chains?
Started by mjeselskis on Forestry and Logging
Last post February 10, 2015, 06:41:57 PM
by mjeselskis
