Author Topic: Mahogany  (Read 5206 times)
Offline nativewolf
Re: Mahogany
« Reply #20 on: April 13, 2018, 07:58:29 AM »
We got around 100" of rain a year with 3-4 month dryseason, temps 22-35degrees (72-95), at sea level. that's pretty much ideal for teak. Teak loves the hot temps, needs lots of water but not too much, a little wind is ok but should not be storm wind or they crack or get damaged.
In the Caribbean side of CR they have 180" of rain year around and teak grows even faster there but does not develop the beautiful dark color in the heartwood so the  price drops significantly. Teak needs some dryseason month so they drop all the leaves and start over growing when the rain comes back, like fall and winter
I figured you had to be pretty moist, your pictures show such lush growth.  So by comparission the teak plantations you reference in Thailand are only getting half your moisture.  I guess that's the holdup on rotation.  On the other hand, color is excellent.
Liking Walnut
Offline teakwood
  • Switzerland
Re: Mahogany
« Reply #21 on: April 13, 2018, 08:03:31 AM »
yes, for sure and you said that they just have 4 month rain season, that's another factor.
As the teak grows nicely here also does the underbrush!! it's a real fight to battle that
Offline Ed_K
Re: Mahogany
« Reply #22 on: April 13, 2018, 08:33:52 AM »
 There's a story in Biomass Magazine about Powering Paradise. Their building a 30-MW Hu Honua Bioenergy plant on the big island. They planted Eucalyptus on acre's of what was sugar plantations to run this biomass plant. Would this be the management job?
Ed K
Offline nativewolf
Re: Mahogany
« Reply #23 on: April 13, 2018, 08:58:07 AM »
No nothing related.  Think a very small version of The Decedents (George Clooney movie reference).  Only no family drama, really just a management issue and a consulting issue.  I'd be the consulting forester, wouldn't do the harvest but make sure plans were in place, vegetative controls were being practiced (Teakwood is so right, if you don't stay up on the veg control in the wet tropics you are going to loose huge % of potential growth).
Liking Walnut
Offline longtime lurker
Re: Mahogany
« Reply #24 on: April 13, 2018, 09:20:20 AM »
Very nice pictures of the Pellita.  I can imagine that would be a hit in China.  Rotation length is surprising to me, I'd have though with the moderate clime you'd be able to push that along like a P. radiata; ie large sawlogs in 20 years.  So it is a slow growing Euc compared to others?   Very cool tree, thanks for sharing!
Most eucalypts are pretty steady growth wise: goes with the high density/ extreme strength I suspect. Takes a while to lay down fibre of those qualities. I would class pellita as moderate by euc standards even in a tropical climate like here. Form also plays a part - the likes of Euc grandis (rose or flooded gum) goes tall fast and then takes a long time to girth out because of the height. pellita is more average in height but denser so often slower
To put it in perspective we are currently cutting a native forest stand that includes a mix of pellita and grandis. it's a mixed age cut for ecological reasons with a pretty high retention rate of stems for either habitat or next harvest purposes - being a native stand its not clear cut. The high retention rate also helps timber production in terms of making the next generation grow up chasing light rather then needing pruning to stop them growing dumpy.
The last harvest cycle through there was about 40 years back which is in line with the normal state harvest rotation for "wild" timber production areas.
We average about 30-50' of sawlog with an average diameter at midpoint of about 15" in the pellita. Most of those are probably 40-50 years old. Density is about 78 lb/ft3
We average about 65-85' of sawlog with an average diameter at midpoint of about 15" in the grandis. Most of those are 30-40 years old. Density is around 49 lb/ft3
American White Oak is about 47 lb/ft3, so as you can see the strength/density of the pellita is considerably greater while the grandis is about the same.
Course give them all 100 years and they spit out some seriously good logs. At 200 they get a bit over ripe.
Eucalyptus grandis: Rose or Flooded Gum, mature stem proabbaly abotu 150 years old and on the downhill slide. Best guess from that picture is shes got 100' of log from ground to the bottom of the crown.
Eucalyptus resinifera: the other "red mahogany" (2 subspecies but pellita is virtually identical, its kinda like the red oak thing) probably pushing 200 years old. That lump has been lying there on the ground through regular burning cycles since the last harvest in the late 1970's. The sapwood has degraded but the heartwood in that will be like cutting a steel bar by now: thats where the value lies in the denser eucalypts... extreme durability and naturally fire and insect resistant.
Offline mike_belben
  • Pulp Friction
Re: Mahogany
« Reply #25 on: April 13, 2018, 09:28:13 AM »
Wow, that things in better shape than me and its cord was cut ten years before mine!
Revelation 3:20
Re: Mahogany
« Reply #26 on: April 13, 2018, 09:34:41 AM »
yeah I dropped an axe into him to see. Spongy for the first three inches then it got real hard real fast. Been a tie log, and it was 2" short on length (I put a tape over it) so they left it behind.
I hooked the dozer on him and dragged him a ways and he's turned into a nice loading ramp face. The next guy in 2060 will most likely thank me for it.
Offline nativewolf
Re: Mahogany
« Reply #27 on: April 13, 2018, 09:41:15 AM »
Thanks Lurker.  You never know what you're going to learn on FF.
Liking Walnut
Offline mike_belben
  • Pulp Friction
Re: Mahogany
« Reply #28 on: April 13, 2018, 10:52:07 AM »
So its like australian locust.
Revelation 3:20
Offline Ianab
Re: Mahogany
« Reply #29 on: April 13, 2018, 05:31:30 PM »
Problem with short rotation eucalyptus is that the younger logs seem to have a LOT of tension. Very hard to get stable boards out of them. So you can grow something that "looks" like a saw log in 25 years, but it's only good for firewood. They need to grow for longer and lay down some more stable wood. If you are growing for bio mass,  then the wood properties don't matter, it just needs to burn.
Offline nativewolf
Re: Mahogany
« Reply #30 on: April 13, 2018, 09:15:03 PM »
That is interesting.  How about that Radiata Pine you have, that is cut darn young.  Any tension issues on them?
Liking Walnut
Offline Ianab
Re: Mahogany
« Reply #31 on: April 13, 2018, 10:53:00 PM »
Nowhere near as bad as Eucalyptus  :D
The Radiata has been bred over the years to minimise the juvenile wood, which is the first few years of growth in the log. That's the part that shrinks in length and makes some fast grown pine unstable. It's also present on older logs, but if the tree grew slower then the juvenile wood is only a couple of inches around the pith, and the rest of the log is good.
So the NZ radiata is a long way removed from the original wild stock, and surprisingly stable for wood with up to 1" growth rings.
Offline kanoak
Re: Mahogany
« Reply #32 on: April 19, 2018, 01:53:24 PM »
Aloha, I run a treefarm in Kona on the big island growing many of the species mentioned in this thread and I may be familiar with the planting you are talking about. Swietenia macrophylla about 30 years old now, just past Pahoa toward Kalapana. I drive by and would guess most stems are 12-16" DBH max. Relatively fertile area with high volcanic risk. Stand has not been pruned or thinned and desperately needs attention. I expect culls will be relatively low grade and size, however they should have tight grain due to their slow growth. My experience is limited, however the young S. macrophylla, 18y, that I have cut disappointed me, color and grain, compared to Toona for example. Nothing like Eucalypts, except maybe the grain and color red; young wood is not totally stable, but logs dont explode on the saw. Tectona and S. mahagoni have been rock solid off the saw like nothing else.
Aloha,
Kanoa
Offline mike_belben
  • Pulp Friction
Re: Mahogany
« Reply #33 on: April 19, 2018, 03:16:59 PM »
Nice, a local.  What do you guys have for equipment there?
Revelation 3:20
Offline kanoak
Re: Mahogany
« Reply #34 on: April 20, 2018, 02:10:49 AM »
Started with a lt10, but just passed that on to my friend with a Lucas who will use it for branches and resaw. Now I've got a rebuilt lt30hdd and a bit of support equip.; few 939s, couple Case ex's, a bus' Case rc80? forklift, and a little other rotting iron. Building a home for the mill.
Thanks for sharing pictures and narrative everyone; cool to see your projects and learn about how things work and have worked in your neck of the woods. Ill work on an intro thread to keep from hijacking this one.
Aloha,
Kanoa
Offline kanoak
Re: Mahogany
« Reply #35 on: April 20, 2018, 02:24:13 AM »
I would like to also say that everything Mike says regarding obstacles is somewhat true. We do have good machinists and welders, but they are busy or leave for greener pastures; so you need to know them and what they enjoy. Mainland market is where it is at; may need to just do cants and sell carving and turning blanks.
Aloha,
Kanoa
Offline teakwood
  • Switzerland
Re: Mahogany
« Reply #36 on: April 20, 2018, 07:27:14 AM »
Nice, now we have a Hawaiian Member, Welcome.
Show us some pics of your operation, we love them.
You can post them here, i'm pretty sure the OP Nativewolf doesn't mind and it's topic related.
Offline mike_belben
  • Pulp Friction
Re: Mahogany
« Reply #37 on: April 20, 2018, 08:59:59 AM »
I left in 2003.  the proliferation of small, freightable benchtop equipment since then has probably helped a bit.  Enco started making pretty good machines for a fraction of american made stuff around that time too if i remember right.  Then hobby CNC made plasma tables possible for a guy with a 1car garage.  A lot has changed now that i think of it!
939 track loaders?  What do you cut and move logs with?  Cut to length on site or skidded whole to somewhere?  What kind of size?  Would love to see pics.
I cant imagine trying to run and maintain an old harvester/processor out there while waiting a week on every little fitting and O ring in the mail.
Revelation 3:20
Offline nativewolf
Re: Mahogany
« Reply #38 on: April 20, 2018, 09:11:59 AM »
Great to have Hawaii joining in on the thread, thread can move in any direction.  All good to me.
Liking Walnut
Offline kanoak
Re: Mahogany
« Reply #39 on: April 20, 2018, 03:06:03 PM »
Aloha, the 939s are 6x6 military trucks. I am mostly thinning planted stuff younger than 30 years, so everything is less than 2' dbh, and relatively close to access. Rebuilding and mounting a Prentice on one of the trucks, but for now excavator and dump truck do everything.
Sawmill building its home
E. microcorys stickered with E. deglupta
S. macrophylla in a mixed stand with brushbox and jackfruit. Pruned to 20'.
and, just to stay on topic, ltr S. mahagoni, S. humilis, S. macrophylla.
Sorry about the sideways pics, is there a rotate function in the gallery?
Aloha,
Kanoa
Mahogany (?) Log.
Started by Fla._Deadheader on Sawmills and Milling
Last post April 23, 2004, 06:16:12 PM
by Fla._Deadheader
mahogany
Started by riverlog on Drying and Processing
Last post August 10, 2008, 06:00:43 PM
by riverlog
mahogany or oak and its value
Started by rebocardo on General Board
Last post January 01, 2008, 09:04:41 PM
by metalspinner
question
Mahogany. Where can I get it?
Started by robedwards58 on Sawmills and Milling
Last post June 07, 2014, 04:37:37 PM
by POSTON WIDEHEAD
