Council Tool
Author Topic: Stihl ms 880 bar size  (Read 3738 times)
Offline Busysawyer
« on: April 12, 2018, 09:21:08 AM »
 I am looking for a shorter bar for my 880. I have a 47in and a 60in and would like something shorter for bucking medium sized logs. What size bar balances well on this power head?
Offline HolmenTree
Re: Stihl ms 880 bar size
« Reply #1 on: April 12, 2018, 12:54:09 PM »
28" - 32" b/c in .404 46RSF
Offline Busysawyer
« Reply #2 on: April 12, 2018, 05:28:58 PM »
Ok. Thank you
Offline esteadle
    • Steadwood Forest Products
« Reply #3 on: April 13, 2018, 05:24:22 PM »
I had a 36" bar on my 880 and it's a bit forward heavy. I agree 25"-32" will be the right balance.
Timber Harvester 30HT26 (setworks, hydraulic) Stihl 880 (36" bar).
Offline Busysawyer
« Reply #4 on: April 13, 2018, 09:46:17 PM »
Thank you for the reply. I will probably go with the shorter side of reccomendations.
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #5 on: April 13, 2018, 09:48:45 PM »
Will an 880 running a 25" bar even know your cutting wood with it, or will it think its just being revved up ?
Offline wild262
« Reply #6 on: April 13, 2018, 09:54:54 PM »
Or another way to put it;  Its like having a 500 ci Caddy motor in a S-10 pickup. :D
Offline Busysawyer
« Reply #7 on: April 13, 2018, 10:15:05 PM »
Pretty sure it won't notice a 25in on it. It pulls a 47in pretty well. I have cut a few oaks that buried the bar and had to cut from the other side to finish the cut and it made short work of those.
Sounds fun. I like overpowered equipment.
Today I was researching places to send the 880 in for special treatment but I think I'm going to get a 395 and have that done up and leave the 880 stock.  I've always wanted a built up saw. I really don't need any more saws but I like them. I have a 450 rancher with 18in bar, a 455 rancher with 20in bar, ms 201tc with 14in and the ms 880 with a 47 and 60in. I'm thinking a hopped up 395 with a 36in bar could be fun. I have quite a few saws for a non professional guy who just likes to play with them.  Funny thing is that my wife gets it but my dad doesn't. He thought my 455 rancher cut plenty fast enough until he saw the 880 demolishing large oak logs.
Offline HolmenTree
« Reply #8 on: April 13, 2018, 10:36:31 PM »
If you go 25" make sure to keep a .404 chain on it. My favorite is the Stihl 46RSF on 25" and longer on those big cube saws.
« Reply #9 on: April 13, 2018, 10:36:46 PM »
Have you looked into buying a ported 372xp ? It would easily replace your 455 and its not much heavier only a pound or 2 but alot more hp and ported its even more hp.
Offline Busysawyer
« Reply #10 on: April 13, 2018, 10:56:41 PM »
I have looked at them a little. I made a list of guys that do porting and other work and I was going to call around Monday and see what they had to say. I'll ask about the 372 as well. I have a friend that has a tree service and he runs all husky saws and I've borrowed his 395 a couple times and I always wanted one of my own. I really have no logical reasoning behind buying a 395
Will do. I have that chain on my 47in bar and have been really impressed with it.
Offline teakwood
  • Switzerland
« Reply #11 on: April 14, 2018, 07:55:49 PM »
I agree too. had the exact same setup.
With a 25" that thing is nasty.  Once i had a 18" 3/8 B/C on my 066, that was fun too!
Offline starmac
« Reply #12 on: April 14, 2018, 10:24:53 PM »
Being as you have that 088, I would think a 372 or maybe the new version of it would fit right in and fill the gapin your line up, that 455 is no comparison at all to a 372, not even close to the same league in my opinion.
Online Skeans1
« Reply #13 on: April 14, 2018, 10:38:28 PM »
My hopped up 395 will pull a 60 in fir buried without the extra weight of the 090, 088, 3120, or Mac 125.
Offline Busysawyer
« Reply #14 on: April 14, 2018, 11:25:14 PM »
With a 25" that thing is nasty.  Once i had a 18" 3/8 B/C on my 066, that was fun too!(Image hidden from quote, click to view.)
I really want to throw a 25" or 28" on it . Not really practical but sounds like fun .
The 455 was my first saw. Not sure when I bought it but it must of been about 12 to 15 years ago now. I bought it to cut firewood to heat my old house. It has been a great, trouble free saw and it has cut a ton of firewood. I agree with you though that it is weak in comparison to the pro level saws. What is the new version of the 372? 372xpg ?
I believe it. I have done a lot of reading on modded 395s and that seems to be what I've been seeing.
Offline starmac
« Reply #15 on: April 14, 2018, 11:30:29 PM »
I want to say the new version coming out is 572, but others will know more than I. I think the XPG designation meant heated handles, I want to say the last 372 was extratorque  or some such thing.
Offline wild262
« Reply #16 on: April 15, 2018, 03:26:43 AM »
Yes Starmac, You are correct.  Husky 572 is newest 72cc class Husky coming out.  The current X-Torq, has a bit more "low end" than the standard 1st edition 372.  Guess that's why they call it X-Torq.  The "G" stands for generator on the heated handle saws.  Hopefully Husky will solve the main bearing issues with the X-Torq on the new 572's.
Offline Maine372
« Reply #17 on: April 15, 2018, 09:25:57 AM »
as you put shorter bars on the 880 you can start increasing the sprocket size. you have the horsepower to run in a higher gear. I have two saws that get sprocket changes with bar changes. I haven't run an 880 so I cant recommend a sprocket bar ratio for you.
Offline Southside logger
« Reply #18 on: April 15, 2018, 09:27:45 AM »
Wicked Work Saws out of Tennessee does great custom porting work and sells new saws ported to your liking.
Offline HolmenTree
« Reply #19 on: April 15, 2018, 02:06:31 PM »
Easy to swap out different rim sprockets on the 088 inboard clutch drum.
With a 25" -28" .404 b/c a 8 tooth .404 rim would be perfect.
Not a common rim now a days. I have a couple of Oregon ones.
Offline HolmenTree
« Reply #20 on: April 15, 2018, 02:19:32 PM »
Yep the main bearings were a major concern for Husqvarna in their development of the 572XP. They actually over built it with those 2 huge main bearings. All they need to do now is put a larger piston/cylinder on to make the power to weight ratio competitive.  :)
Offline Busysawyer
« Reply #21 on: April 17, 2018, 08:13:38 PM »
Called wicked work saws today and got a machine saying he broke his ankle and will be out of the shop for a few weeks. I'm in no hurry.
Is it your opinion that the stihl is a better saw overall.  I have had good luck with both and don't have a preference between those two. The only thing is that none of the local husky dealers will work with pricing. I saved around 500 when I bought my 880 and 201 together.  Local husky places wouldn't budge a penny.
Offline teakwood
  • Switzerland
« Reply #22 on: April 17, 2018, 10:03:50 PM »
another good reason to buy stihl!
Offline Busysawyer
« Reply #23 on: April 17, 2018, 10:09:05 PM »
another good reason to buy stihl! (Image hidden from quote, click to view.)
That's the main reason I bought the 880 and 201. I tried to buy a 540 and 3120 from about 6 local dealers and not one would budge a penny . Then they all told me I would have to wait weeks for delivery of the 3120 and tried talking me into a 395 which they all had in stock. After calling every husky dealer in a 20 mile radius I decided to call a stihl dealer.  More than 500 off retail , making it substantially less money that the 2 husky saws and they had my 880 by noon the next day.
Offline Busysawyer
« Reply #24 on: April 17, 2018, 10:22:23 PM »
Also I just have to add. I did have an issue with the 201. The second time I used it I noticed the pull cord was frayed and nearly severed about 4in from the handle. I called the dealer and they said they would take care of it and to drop it off whenever was convenient for me or just use it until it broke and bring it in then. I used it for a few weeks and had a few days when I knew I wasn't going to need it. I dropped it off and mentioned I don't get out that way often and it is about a 25 minute drive for me to get there. Two days later they had it fixed and brought it out to my house and told me if I have any issues with equipment I get from them just call and they would pick it up next time. They went way above and beyond any place I've dealt with in the past.
Offline HolmenTree
« Reply #25 on: April 17, 2018, 10:28:20 PM »
Busybeaver, that sounds like best service I ever heard of.
You must be in a small town  🙂
Offline Busysawyer
« Reply #26 on: April 17, 2018, 10:44:43 PM »
I live in what was a small town 15 years ago but has been growing very rapidly.  We are on the outskirts of west mi largest city, grand rapids. The dealer is a John Deere dealer and is the closest Deere dealer to me. I have got parts for my little tractor from them in the past. They are a pretty good sized outfit with 3 locations on this side of the state.  They said they deal in quantity and have a few of the largest tree companies around going through them . That is why they can give good pricing. He said he sold 25 201s to one company alone this year.  To them I'm a nobody home owner and they still treated me like I was their most valuable customer. The bobcat dealer right up the road had been really good to me as well
 Besides those two places i get the standard crap service that is common these days.
Offline olcowhand
  • I'm new- ish!
« Reply #27 on: April 18, 2018, 05:20:55 AM »
Busybeaver,
That's a great story about that Stihl Dealer. My work place is in GR, and my buddy often tells me I should stop in to the Dealer you speak of.
I've given up on my local Stihl dealer, and bought my most recent saw (an MS 261 CM much discussed in one of Willard's threads...) at a JD Dealer a little farther away.
They were very easy to work with (price- wise, too), and I'll be going back there for all my Stihl needs.
I have no input on your original topic, as my largest saw is an MS 461. I run a 20" on that and it's a beast. I don't think I'll ever need a bigger saw for my limited use. Good Luck on finding the right combo.
They say the mind is the first to go; I'm glad it's something I don't use!
Ezekiel 36:26-27
Offline Ed
« Reply #28 on: May 01, 2018, 11:40:57 PM »
I have a 24" bar for my 084......the saw doesn't know it's there.
Ed
Offline Al_Smith
« Reply #29 on: May 03, 2018, 07:34:15 PM »
I've got only a 42" on my 084 which doesn't see much action nor do any of my other 100 cc and over saws .These things were built for big wood and I see no sense in wrestling around an 25-30  pound saw to cut 18-24" stuff .Most actually 18" and under .
Offline ZeroJunk
« Reply #30 on: May 03, 2018, 09:29:09 PM »
Yeah, there are lighter saws that will pull a 24 at the same RPM as the MS880 but would bog with a 42.
Offline Al_Smith
« Reply #31 on: May 04, 2018, 09:51:35 PM »
More on this when it comes to saw size .While it can be a hoot to run a big cubic inch saw it can wear you out .I don't care how old or young you are .Providing you have as I do a choice of saws as per the job you can get a lot more done by picking the saw for the job .
I have at least two years of work ahead of me just to clean up the wind fallen  dead ash trees ,some only 8" in diameter .I'm not even going to go as large as 70 cc's on those things when a 50 cc saw will do just as well .Certainly not a 123 cc McCulloch SP 125 or a 99 cc 2100 Husqvarna .That would be like shooting rats with a 30:06 .
Offline Ed
« Reply #32 on: May 05, 2018, 12:16:08 AM »
What Al said...
The fun factor goes away real quick when running a 125cc saw.
Ed
Offline beauj5
« Reply #33 on: May 05, 2018, 01:20:13 AM »
I had to go to the top to find your original question, to which I can only say that the shortest bar I have that fits my 880 is a 36 and that bar a bit small for that saw size, but, it flies through the wood for certain. I have a hopped up 395 and it is truly a monster.  Loud and aggressive and a bit lighter than the 880.  Did I mention that it was loud and aggressive?  Aggressive is probably and understatement.  Its probably the equivalent of going from the stock camero to the supercharged Corvette...  its louder, lighter, and higher revving than the 880, but for cutting big wood constantly, the 880 is easier and more efficient to use.
When the road forked, I went straight.
T540xp, 562xp, 034 super mag, 044, 460, 576, 056 super mag, ms460, 066, ms880, 090.
Does Stihl have a different mount size at the studs for bigger and smaller Stihl
Started by quietrangr on Chainsaws
Last post October 09, 2011, 08:25:11 AM
by Al_Smith
stihl 075 bar size's
Started by Quartlow on Chainsaws
Last post November 07, 2004, 06:57:19 PM
by Quartlow
stihl size
Started by Striker525 on Chainsaws
Last post March 24, 2016, 03:18:55 PM
by joe_indi
Stihl 051 av bar size.
Started by Hiway40frank on Chainsaws
Last post April 02, 2016, 09:04:59 PM
by Hiway40frank
