Author Topic: 346xp leaking fuel  (Read 447 times)
Offline Maine372
346xp leaking fuel
« on: April 13, 2018, 10:03:18 PM »
previous owner says the saw always leaked gas. fuel lines looked tired so I started by replacing them. found the tank vent had backed out of where its seated in the tank. rattling around in there it had oversized the hole. so I put that in with some sealant and figured it was good. wrong! still leaking gas like a sieve.
the main feed line from the filter to the carb isn't making a seal where it passes into the tank.
is there supposed to be a seal there or is it just the outside of the fuel line pressing against the orifice? does OEM husqy line have a different outside diameter than the generic stuff I got at tsc? any thoughts on how to seal this up?
thanks in advance.
Offline steele109
Re: 346xp leaking fuel
« Reply #1 on: April 13, 2018, 10:36:06 PM »
Hi I have fixed several huskys that leaked where the fuel line comes out of the tank and yes there are several sizes of generic fuel hose. The way I fixed them was putting a stihl weedeater gromet in the hole then run the fuel line through that,it seals them tight. I had a 350 that I fixed that way.I drilled the hole just big enough to get the gromit in run the hose through it no more leak.
Offline Maine372
« Reply #2 on: April 15, 2018, 09:17:52 AM »
got a part number for that grommet?
Offline dougand3
« Reply #3 on: April 15, 2018, 09:34:35 AM »
Stihl Fuel line grommet 0000-989-0516
Search online - many choices.
Offline Maine372
« Reply #4 on: April 15, 2018, 07:10:58 PM »
that sounds much easier than trying to sleeve it with a larger piece of fuel line.
many thanks!
husqvarna leaking fuel
Started by first shirt on Chainsaws
Last post March 03, 2009, 10:06:26 AM
by Etced
Ms660 leaking fuel
Started by PAmizerman on Chainsaws
Last post January 06, 2018, 08:51:40 PM
by blueberrymuzik
Husqvarna 365 leaking fuel when full
Started by straincm on Chainsaws
Last post October 16, 2018, 07:46:50 AM
by straincm
Fuel leaking out of 385XP when on its side
Started by jteneyck on Chainsaws
Last post November 05, 2014, 07:41:52 PM
by jteneyck
