Author Topic: Score  (Read 2665 times)
Offline PAmizerman
  • Just Another Day In Paradise!!
Score
« on: April 14, 2018, 08:09:41 PM »
I scored these today. A guy that runs a circle mill up the road from me had to call it quits. The deal was too good to pass up.
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: Score
« Reply #1 on: April 14, 2018, 08:35:05 PM »
Looks like you scored high.
1992 LT40HD
Offline D6c
Re: Score
« Reply #2 on: April 15, 2018, 08:33:13 AM »
Looks like a good deal....Id like to find a dust collector like that.
Offline moodnacreek
  • Sawin by the notches
Re: Score
« Reply #3 on: April 15, 2018, 09:41:04 AM »
Don't unload that stuff! Bring it to me.
Offline scully
  • Orange Mills Matter
Re: Score
« Reply #4 on: April 15, 2018, 09:47:12 AM »
That will save you some work for sure . share pic's when you get it set up with the mill !
I bleed orange  .
Offline Percy
  • Resident trouble maker
Re: Score
« Reply #5 on: April 15, 2018, 10:40:36 AM »
Im liking the looks of that sawdust blower.  Good find.
Offline PAmizerman
Re: Score
« Reply #6 on: April 15, 2018, 11:36:43 AM »
I'm really looking forward to getting this equipment into my operation. Unfortunately I   am stuck in a little hole right now and don't have room to set it up. But I just couldn't pass this stuff up.
I'm in the process of closing a deal on 17 acres though and can't wait to get my operation moved out there. It will be quite awhile but yes lots of pictures to come.
WM bms250 sharpener
WM bmt250 setter
Offline PAmizerman
Re: Score
« Reply #7 on: April 15, 2018, 11:40:40 AM »
I was told that this blower is meant to drop the sawdust out the bottom gently and not have to be over a sealed container. But I have not done the research on it yet. Any idea how to tell?
WM bms250 sharpener
WM bmt250 setter
Offline PA_Walnut
Re: Score
« Reply #8 on: April 15, 2018, 11:47:40 AM »
It appears to be a cyclone, so it should just drop the heavier materials out the bottom. The smaller particles either stay in suspension until they migrate downward far enough or follow the lower-resistance exit path, usually into a filter.
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Online YellowHammer
  • Take Steps to Save Steps
    • Hobby Hardwood Alabama
Re: Score
« Reply #9 on: April 15, 2018, 11:59:58 AM »
Its feeding the sawdust through the blower, into the side duct, pushing the material through the cyclone.  The dust spins out the bottom, the exhaust air is driven out of the top.
If the blower motor was on the top it would require a vacuum to pull the material into the cyclone, which requires a sealed bin on the sawdust drop funnel.
I set my cyclone up like your picture, and it will indeed drop the sawdust straight down into a nice pile.  I drop mine into a self dumping forklift hopper.
HobbyHardwoodAlabama.com
Offline PAmizerman
Re: Score
« Reply #10 on: April 15, 2018, 11:29:50 PM »
That makes sense. Thanks for the explanation!
WM bms250 sharpener
WM bmt250 setter
Offline PA_Walnut
Re: Score
« Reply #11 on: April 16, 2018, 06:52:07 AM »
Nice score! I'm tired of shoveling sawdust next to my mill and about to put it on a slab, take the wheels off and make it stationary. So, sawdust extraction is on the agenda What brands/setup are available readily? YellowHammer?
I understand Baker has/had something and TimberKing also. I'd like to avoid 3-phase if possible. I have plenty of single-phase power, but don't really want to do a convertor, drive, etc.
Thx
Offline Trapper John
  • Location: Galena, Ak. 200 miles west of Fairbanks on Yukon River
  • Trying to learn circle milling
Re: Score
« Reply #12 on: April 20, 2018, 04:18:56 PM »
Are the conveyors part of the dust collection system?
Offline PAmizerman
Re: Score
« Reply #13 on: April 20, 2018, 06:36:11 PM »
No the conveyors don't go with the sawdust blower.
The one that is on it's side will either tail boards off the mill or be used as a return for the edger. I picked up another one that is near identical to that one at an auction last year.
As for the 16' paddle conveyor I'm thinking of maybe using behind my chopsaws to carry cutoffs out to a bin. I'm not completely sure yet. It was just too good to pass up.
WM bms250 sharpener
WM bmt250 setter
Online YellowHammer
Re: Score
« Reply #14 on: April 20, 2018, 11:11:40 PM »
For sawdust out of the sawmill chute, I've finally got a system that's working great.  It's a Woodmaster/Timberking 5 hp single phase 220 blower going into an Oneida cyclone and all the sawdust dropping into a forklift self dumping hopper.  The outlet of the mill goes to flex hose, a rotating ball joint and into the hard pipe.  The setup is very similar to what PAmizerman scored.  The dust collection blower services my whole shop with a planer, straight line rip saw, 20 inch jointer, occasional edger, and chop saw.  With a 5 hp I can run any two at the same time.  No more spraying sawdust out over the back 40 acres anymore, it piles in the hopper clean as a pile of sand.  I pick the bin up with my front end loader forks, drive to my field edge, or wherever else I want mulch, pull a chain and the hopper automatically dumps.
Since bark chips, vines, other junk falls under the mill, the blower can't pick it up, I'd use the paddle conveyor directly under the mill, in a trough, and use it to clean under the mill at the end of the day.
You scored some really nice stuff.
Offline PAmizerman
Re: Score
« Reply #15 on: April 21, 2018, 10:31:06 PM »
Indeed nice stuff! I feel very fortunate to have been able to get these items.
I like the idea of the conveyor under the mill. That will work out good with my design plan. I am planning to put a slightly elevated wood floor in. So the conveyor could be tucked right between the floor joists. I also picked up a 20' grain elevator last year that I could use there if needed. Thanks for the idea yellow hammer.
WM bms250 sharpener
WM bmt250 setter
Offline PA_Walnut
Re: Score
« Reply #16 on: April 22, 2018, 05:54:12 AM »
Yellow, it would be great to see this setup (with the cyclone). I have an Oneida cyclone with a 2 HP for my previous woodworking shop. Worked great.
The WoodMaster/Timeberking 5HP--is it still made? I've looked for this several years ago and couldn't find a thing listed on their site.
THanks.
Online YellowHammer
Re: Score
« Reply #17 on: April 28, 2018, 12:03:34 AM »
Offline PA_Walnut
Re: Score
« Reply #18 on: April 28, 2018, 07:02:18 AM »
Thanks Yellow! Much appreciated...once again!  8)
Score!
Started by lowpolyjoe on General Woodworking
Last post January 03, 2016, 06:56:31 PM
by lowpolyjoe
Score....
Started by Rusticcreations on Sawmills and Milling
Last post May 14, 2016, 10:27:11 AM
by tnaz
SCORE!
Started by metalspinner on Urban and Community Forestry
Last post May 04, 2010, 07:55:42 AM
by metalspinner
Woo-Hoo! CL score
Started by justallan1 on General Woodworking
Last post September 24, 2014, 11:19:51 PM
by justallan1
