Author Topic: 090 oiler  (Read 844 times)
Offline Beaser
090 oiler
« on: April 14, 2018, 11:03:36 PM »
Hiyall
Recently purchased an 090 av in reasonable shape
issue I'm having is oil flow, using maybe 2 tanks plus to a tank of fuel. The manual is telling me to adjust the control bolt clockwise to slow down the flow, what it doesn't tell me is which side of the saw to do the adjustment from, meaning it could be one way or the other depending on which side of the saw you're standing on, anyone have any clues? The way I read it the bolt needs to screw "in" to increase flow and surprise "out" to decrease flow, can't  see anything on goggle that tells me either way
Cheers beaser
Offline HolmenTree
Re: 090 oiler
« Reply #1 on: April 15, 2018, 01:40:48 AM »
Welcome to the Forum.
Just sold my 090 with manual and haven't adjusted the oiler for years.
Yeah like you I had confusion too trying to figure that one out.
The German translation to English doesn't help either. I believe in the instructions there was "anti clockwise " and "counter clockwise".
Even a fancy little double ended flat wrench that came with my 090 to loosen off the lock knot and turn the bolt.
That bolt tightens and loosens a diaphragm and plunger. And I think tightening the diaphragm by turning in the bolt reduces oil flow.  Turning out makes the diaphragm more loose increasing pumping and oil flow.
Best thing try turning it in then see if it helps reduce oil flow
Offline Beaser
Re: 090 oiler
« Reply #2 on: April 15, 2018, 07:16:26 AM »
Thanks very much HT tried it both ways doesn't seem to make a difference but wasnt sure how far I  could screw it out before it actually came off. Looks like I may have to tear the whole thing down to see what's  happening.
Offline HolmenTree
Re: 090 oiler
« Reply #3 on: April 15, 2018, 02:11:32 PM »
You may need a new diaphragm/plunger.
Part # 1106 640 3100.
Ms 461 Oiler
Started by Jdwoody on Chainsaws
Last post May 28, 2017, 12:49:16 AM
by Jdwoody
272 xp Oiler ?
Started by Knute on Chainsaws
Last post March 26, 2014, 10:25:34 PM
by Knute
oiler mac 2.1
Started by Medina on Chainsaws
Last post April 24, 2006, 07:32:30 AM
by Medina
011 oiler
Started by auger creek on Chainsaws
Last post November 25, 2014, 04:55:27 PM
by auger creek
