Author Topic: stihl ms250 leaking oil from a hole (see pics) Not enough oil getting to chain.  (Read 2188 times)
Offline Adwoodmass
Hello folks.
My father is having trouble with his chainsaw. He ran into a problem with it a couple of days back and asked if i could do some research.
It's very difficult to see on the images but the small hole is to the left of the (exhaust?) It currently has a small metal nail in it as my father thought wise to try plug it up to stop it leaking, it did work for a short time but flew out when turned on. Due to the oil coming from that hole he mentioned overheating and the chain not getting enough oil.
Does anyone know if that hole is meant to be plugged up with something, has it fallen out and he hasn't noticed? He isn't quite sure himself what the hole is for.
Thank you.
Adam
Offline steele109
Hi I looked at mine and there is a screw comes up and ends there. It's probably under the clutch cover,it comes up at a angle.I will take the side cover off this one and see if I can see where it comes from.
Offline realzed
  • Old Fart but - I'm new!
Does the thread and associated answers and discussion posed in the 'similar topic' right below yours here, answer any of your questions here?
Certainly sounds very similar although the OP of that thread doesn't exactly describe where his leak is..
Offline steele109
I took the clutch cover and chain brake cover off and didn't see it.I just put a new crank case on mine a few weeks ago and can't remember that screw.SORRY say_what
Offline limbwood
there is supposed to be a little orange plug in that hole. if you can find a self tapping screw the right size with some good sealant it will fix it. you will have to take the muffler off to get it in though.
Offline Adwoodmass
No worries, Steele. Thank you for taking your own apart to solve our problem. Appreciate it!
Offline Adwoodmass
Certainly sounds very similar although the OP of that threat doesn't exactly describe where his leak is..
Hi Realzed.
I have just checked that thread and it sound very much like the problem my dad is facing. Thank you for bringing that to my attention. I will take the laptop over tomorrow and let him read it over.
Regards
Adam
Offline Adwoodmass
Hi Limbwood. Thanks for that information, i guess he wasn't far of trying to plug it with a nail. Didn't quite fit though. I'll talk with him tomorrow. It'll probably require a trip to the diy store for a proper fit screw/nail.
Thanks again all for the info.
Regards
Adam
Offline joe_indi
  • The older I get the more I learn
.....It currently has a small metal nail in it as my father thought wise to try plug it up to stop it leaking, it did work for a short time but flew out when turned on. Due to the oil coming from that hole he mentioned overheating and the chain not getting enough oil.
Oh, oh... That hole was formed during the manufacturing process and the orange 'screw' is just a dummy to block that hole.
If you insert anything long enough it will block the flow of chain oil from the pump.
Take a pin and insert it into that hole and watch where it goes on the side, in the groove where the oil comes through. You will understand this better.
To block the hole use a very tiny stub of plastic or metal 2 or 3mm long, apply a bit of epoxy cement and pus the stub in, not too deep, just enough to block the front hole.
Offline Adwoodmass
Ah it's starting to make sense now. The screw he put in there was pretty long, that must be why the oil isn't getting to the chain. I think he has epoxy cement so i imagine any cut down screw head would work in this situation with a tad of epoxy cement, sounds good to me!
Thank you for that info, Joe!
Regards
Adam
Offline Adwoodmass
I'd like to thank you all for your knowledge and help! The problem has been sorted and the chainsaw is running as well as it usually does.
Thanks again!
Regards
Adam
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
I love a success story!
Thanks for updating with the solution.
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
Offline baronthered
A small set screw will take care of it. Put some silicone goo on the screw and tap the hole first or it may crack the case right there. There is a YouTube channel called taryl fixes all that shows the same fix.
Life's short make fun of it!
stihl MS 290 oil leaking from weep hole by muffler?
Started by ruger1 on Chainsaws
Last post April 10, 2013, 09:47:37 AM
by Paul_H
Stihl MS250, having issues keeping the chain tight
Started by knightgang on Chainsaws
Last post October 16, 2015, 09:10:35 PM
by HolmenTree
question
Reduced-kickback chain on Stihl MS250 Question
Started by Adam1976 on Chainsaws
Last post May 25, 2004, 07:23:29 PM
by Hunter
Expert question: Stihl MS250 head/chain combo
Started by KROWBAR26 on Chainsaws
Last post October 23, 2003, 09:36:38 PM
by jokers
