Baltic Abrasives Technologies
Author Topic: Smoked my Skid Steer  (Read 3095 times)
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« on: April 17, 2018, 08:58:44 PM »
I was moving dirt yesterday that is being excavated for the basement under our new addition.  While I was dumping a load from the bucket I thought I got a whiff of burning leaves.   Then a minute later I smelled something else burning and jumped off the skid steer and popped the rear hood and there was a fire burning down in the bottom of the engine compartment.   I ran at top speed 400 feet to the garage and back to get the fire extinguisher.  Fortunately, the fire hadn't spread or gotten bigger and I put it right out.    I left it sit overnight and then this morning I walked out to it and started assessing the damage.   I untangled and separated about half a dozen wires that were melted together.   The wires leading to the solenoid and started were also melted and had to be separated.    Then it actually started.  8)     I quickly drove it over to the front of my garage and shut it down before something else happened.
Once I cleaned off the extinguisher powder I could see things better.   The good news is that damage is limited to the half dozen wires already mentioned and the melted/cracked solenoid casing.   The bad new is Gehl does not have a part number for the solenoid and I had to order a new starter with it already attached.
The fire was apparently caused by a combination of a small hydraulic leak spraying on the muffler heat shield and to much debris that had fallen into the machine from running it in the woods.  That was the burning leaves I smelled.  ::)    I was lucky this time.  You can bet it will get a complete cleaning inside before it goes back in service.
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline ljohnsaw
Re: Smoked my Skid Steer
« Reply #1 on: April 17, 2018, 09:16:41 PM »
And maybe a fire extinguisher mounted somewhere handy? ;)
John Sawicky
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #2 on: April 17, 2018, 09:23:34 PM »
ditto lj suggestion. Glad you are okay. Equipment can be repaired or replaced - FF members can't. :embarassed:
Offline thecfarm
« Reply #3 on: April 17, 2018, 09:25:52 PM »
I betcha them starters are not cheap. :( But lucky that is all that you have to spend out.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #4 on: April 17, 2018, 09:46:58 PM »
A local starter shop might be able to get you a solenoid to put on the old starter.
Offline Busysawyer
« Reply #5 on: April 17, 2018, 09:59:41 PM »
I'll second the fire extinguisher mounted in the machine. I have a small one in the cab of my t300. II will also second the starter repair shop suggestion.  I have only had one starter out of about 10 or so that the local shop couldn't rebuild and that was for a 91 bobcat that caught on fire.
Even a blind squirrel finds a nut every once in awhile
Offline coxy
« Reply #6 on: April 17, 2018, 10:29:49 PM »
was it a gehl skid steer mine melted the electronic shutoff and caught fire
Offline Busysawyer
« Reply #7 on: April 17, 2018, 10:52:43 PM »
I believe dr buck said his is a gehl. The one I smoked was a 91 bobcat 743b and it was 100% my fault. The starter had been getting weaker and weaker and I had 3 batteries and a wheel charger hooked up to it trying to get it to turn over. I started it like that for a couple months before it actually caught on fire
Offline coxy
« Reply #8 on: April 17, 2018, 11:02:24 PM »
gehls are an electrical night mare i have ripped every safety censer out of mine trying to find the short  one time the loader was 1/2 way up and it wouldn't come back down had to take the safety thing out of the hydro line  i now start it by touching 2 wires together and shut it off by hand at the injection pump i would never get another gehl
Online Southside logger
« Reply #9 on: April 17, 2018, 11:28:54 PM »
Try Rick at the Battery Barn in Petersburg - that guy can fix any starter or alternator.
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #10 on: April 17, 2018, 11:49:55 PM »
Its a 2003 Gehl 6635 and the new starter with solenoid cost $134.
Hidden Acres Farm
Offline starmac
« Reply #11 on: April 18, 2018, 03:40:52 AM »
It seems like most of the time anymore, a guy can buy a starter cheaper than having one rebuilt, that is if they are available. I forget the price, but My son had to get one for his bobcat, and it was not bad at all. I had to buy one for my dodge last week, dodge price 1168 bucks, O'reillys, 158 bucks.
Offline Logger RK
« Reply #12 on: April 18, 2018, 06:05:40 AM »
A battery master switch might be a good idea incase of electrical short,leading to a fire.
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
« Reply #13 on: April 18, 2018, 08:19:47 AM »
Weren't you one of the Guys that laughed when I burned up the dozer? .....HAHAHAHAHAH AHAHAHHAHH AHAHAHAHAHAHAHAHAHAHAHAHA!
:D :D :D :D :D :D :D :D :D :D :D
See it's easy to do.
The First 60 years of childhood is always the hardest.
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #14 on: April 18, 2018, 08:44:23 AM »
Weren't you one of the Guys that laughed when I burned up the dozer? .....HAHAHAHAHAHA HAHAHHAHHA HAHAHAHAHAHA HAHAHAHAHAHA!
I'm not sure I laughed at you for the dozer burning.  I think it was the story you told.....  :D
A Funny Story in General Board
Hidden Acres Farm
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #15 on: April 18, 2018, 09:17:29 AM »
I set my UTV on fire just by having to many dry leaves under the muffler. was running less than 5 minutes before full on fire. dry leaves are dangerous. The leaves were a good 8-10" below the muffler and still lit up real easy and quick.
Offline dchiapin
  • TK B-20
« Reply #16 on: April 18, 2018, 09:56:04 AM »
Online Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #17 on: April 18, 2018, 10:00:31 AM »
Oh boy, this reminds me of a story.
Many years ago we were logging between Clare Harrison and Farwell off of Harrison Avenue. This was a huge property owned by a man named Cappaert who at the time was the only share holder for Diamond Reo Trucks and he also owned Marlette mobile homes.
Where we were logging was way back in the center of a section. You turned off from Harrison avenue in the driveway of one of the caretakers homes, then drove back across a field, then through a wooded area, then across a sugar sand airstrip, then on into the woods again where we were working. Our landing was set up about 50 yards from a beautiful little stream that I could see trout darting around out from under the undercut banks.
This was a Saturday. We were doing equipment maintenance. There was me, our mechanic Pat Ahac, and a mobile welder named Bruce from Service welding in Clare. Bruce had finished some welding up on the 404 Timberjack dozer blade and had turned his attention to the bobcat. I can't remember exactly what he was welding on now, but we heard him say "HEY! I have a fire!" Some sparks had dropped down in the belly pan where there was quite a bit of oil and debris accumulated. Pat ran to his work truck and grabbed a big extinguisher. He ran back and sprayed it down into where the fire was but the fire would not go out, even after using the entire contents of the extinguisher. There was an empty 5 gallon pail in the truck so I hoofed it to the stream to get a pail of water and then hoofed it back to the bobcat and tried to awkwardly poor the water in through the side panel past the engine and down into the pan where the fire was. I did this 5 times (I was a young man and in very good shape at that time) and all it did was die the fire down. This wasn't a huge fire, but it was sure meaning to be if we didn't get it out.  Pat hollered at me to jump in the truck and drive back out to the caretaker's house and call the Fire Department.  So off I went, through the woods, out across the airstrip, through the woods, acrodd the field and made a sliding stop at the house. Ran up to the door and knocked loudly.  A middle aged woman answered the door and I quickly told her that we had a piece of equipment on fire out back across the airstrip could she call the fire department.  "Yes!" she said, so off I ran back to the truck and flew back to the woods where Pat was about to drop from running pails of water while I was gone. He was probably 10-15 years older than I was at the time.
When I jumped out of the truck, we could hear the sirens go off in the distance in the direction of Surry Township. Not to far away.  Then we heard sirens at about 90 from that.  Clare sirens! No time to listen I started humping pales of water from the stream to the bobcat. We continued to just keep the fire under control, but it was starting to build. It took about 15 minutes for the first vehicle to arrive from the fire department, a volunteer in a pickup. Then they really started coming, about 5 minutes after the first vehicle pulled in, a foam truck rolled in. They drove right up to the bobcat and had the fire out in about 5 seconds.
Vehicles continued to arrive. Fire trucks, pickups, now we had a truck and a dozer roll in, DNR trucks started showing up one hauling a modified green skidder with a huge firebreak plow on it. Before it was over, there were several pieces of heavy equipment and probably 50 men there. As it turned out, when I left the caretakers house, and she called the fire department, she told them that the loggers had "set the woods on fire".  Before all the trucks had left, S. L. Cappaert's leer jet was buzzing the area. He couldn't land as the airstrip was only for small prop planes.
I was whooped after this all ended.  I walked back over to the stream, laid down on the bank and washed my face. I then washed out my hardhat. Took the liner out and washed it out really good then dipped the hat back in the fast moving crystal clear waters of the stream and got me a good long drink.  I then stood up, and that is when I looked up stream for the first time and saw the dead sheep laying mid stream about 50 feet away.  What a day.
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #18 on: April 18, 2018, 10:11:44 AM »
Great story Jeff.
You couldnt make that stuff up.
One time 4 wheeling at my ADK camp we stopped for an adult beverage in a meadow.
After about 5 minutes I smelled smoke but couldnt pin point it right away.
Finally one of the guys said pete its under your machine.
Sure enough dry grass had ignited.
Moved the ATV and stomped it out.
another pal parked his in his shed also at our property went inside came out a few minutes later and the shed was on fire, burned to the ground atv and all.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #19 on: April 18, 2018, 10:51:54 AM »
I went to a house fire similar to that. the biggest saving grace was the non code compliant PVC water line running through the garage over the top of the quad. It melted and put the fire out :)
Quad was just a frame but the house was saved.
skid steer?
Started by Faron on General Board
Last post July 08, 2011, 07:10:22 AM
by 250quality
Skid Steer
Started by Magicman on General Board
Last post December 13, 2015, 08:37:33 AM
by jdonovan
skid steer
Started by gtr on Forestry and Logging
Last post April 14, 2006, 08:25:57 AM
by woodsteach
skid steer
Started by slider on Sawmills and Milling
Last post April 23, 2012, 09:03:50 AM
by Cedarman
