Author Topic: 240D Jack  (Read 2893 times)
Offline KyLogger
  • Loggin' for a livin'
Re: 240D Jack
« Reply #20 on: April 26, 2018, 10:28:42 PM »
Here's to hoping! The previous guy said it ran just fine and dandy for them, said if they gutted it with a big turn in the summer that she'd get to 200.
I only work old iron because I secretly have a love affair with my service truck!
Offline mike_belben
  • Pulp Friction
Re: 240D Jack
« Reply #21 on: April 27, 2018, 01:25:09 AM »
 the gauge would get to 200.  Coolant may have been 165.  Verification of an actual issue is next step here.
200 isnt an issue IMO.   Honestly the hotter it runs the better the fuel efficiency.  Fuel makes heat.  Heat goes 3 places.  Out exh, into water jacket and toward creating the pressure rise that will be applied to the piston crown in order to drive the rod down and spin the crank.
If you wrap the exhaust and raise the stat, youve got 2 less places for the same amount of energy to be dissipated.  Guess where the remainder goes?  Into the crank.
Best mileage:  highway in summer.
Worst mileage: short trips in winter.
Revelation 3:20
Offline KyLogger
Re: 240D Jack
« Reply #22 on: April 29, 2018, 07:20:28 AM »
After much angst and hours of wracking my brain.... I am 99% sure I have it figured out. I was running out of ideas when it hit me.... It was not circulating water, but the pump had just been rebuilt.... Blockage? Air lock? Or some moron put a RH pump on the motor! Gonna order one tonight or try to find one relatively local. If this doesn't do it (it will) I'ma gonna have a cheap TJ for sale! Lol.
Offline mike_belben
  • Pulp Friction
Re: 240D Jack
« Reply #23 on: April 29, 2018, 10:13:45 AM »
thatll do it
Revelation 3:20
Offline bigred1951
  • logging and sawmilling
Re: 240D Jack
« Reply #24 on: April 29, 2018, 10:14:44 AM »
Good to see you back on. Hey if its cheap enough let me know lol
Offline KyLogger
Re: 240D Jack
« Reply #25 on: April 29, 2018, 05:43:56 PM »
Glad to be back!
Offline bigred1951
Re: 240D Jack
« Reply #26 on: April 29, 2018, 05:50:11 PM »
Not to many people close to me on here
Offline East ky logging
Re: 240D Jack
« Reply #27 on: April 29, 2018, 08:07:34 PM »
Hey big red I seen that you went to the stave mill awhile back hows that working out. Im in magoffin co. I used to haul in there quite a bit. I seen on the news that they are going to start building barrels I hope it works out because we can sure use the jobs around here.
Offline KyLogger
Re: 240D Jack
« Reply #28 on: April 29, 2018, 09:17:39 PM »
The only fault I had with the stave mill coming to town was their minimum diameter on white oak logs. In 10 years there won't be a white oak over 10" dbh left in 8 counties.
Offline bigred1951
Re: 240D Jack
« Reply #29 on: April 30, 2018, 05:38:50 PM »
Yea I worked there as a security guard for a couple months. Then one night they called and said the contract over your all out of work pretty much. Do drawed unemployment for a couple months now Im working for a general contractor doing construction
Offline KWood255
Re: 240D Jack
« Reply #30 on: May 10, 2018, 09:15:13 AM »
Just another idea here, but hopefully you have it solved. Those Detriots had both left hand and right hand rotation coolant pumps. Any chance yours has the wrong one? I just replaced one on my 3-53 last fall. Easy job on mine, so I'm assuming it's about the same on a 4-53.
Offline KyLogger
Re: 240D Jack
« Reply #31 on: May 10, 2018, 07:28:30 PM »
That was exactly the problem, no coolant flow. Someone threw a RH pump on this motor and it needed a LH. Like I said, I am a virgin to a Detroit, but after some research and hair pulling and talking to you all I finally figured it out. A three hour round trip drive and a new $150 pump and the ol' Jimmy runs cool as a cucumber! Thanks!
TJ 240D Hydrauli Pressure
Started by KWood255 on Forestry and Logging
Last post September 19, 2014, 07:24:37 AM
by Neilo
Timberjack 240d starter
Started by mr T on Forestry and Logging
Last post January 05, 2014, 07:08:31 AM
by mr T
Timberjack 240D manual
Started by madmax on Forestry and Logging
Last post July 18, 2012, 09:16:17 AM
by madmax
Need info timberjack 240D
Started by MrTjack on Forestry and Logging
Last post February 07, 2014, 07:21:20 PM
by loggah
