TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: Loose sprocket tip  (Read 1378 times)
Online mike_belben
  • Pulp Friction
Loose sprocket tip
« on: April 20, 2018, 09:23:23 PM »
I have a no name 24" large pattern husky bar with an oregon style 3/8 sprocket insert.  Recently it loosened up and started wobbling around quite a lot.  It was binding in the wood a bit and also getting a wear patch right where the rails of the tip and bar meet due to misalignment.
I pounded on the rivet but that did nothing.  Brought the bar to local co-op saw shop (which i think highly of) and theyd never seen it happen.  Bought a new oem oregon tip and swapped it on.  Still the same.  Id never changed a tip before but didnt see any issues.
Anyone got any ideas?
Revelation 3:20
Offline starmac
Re: Loose sprocket tip
« Reply #1 on: April 20, 2018, 09:27:05 PM »
Are you saying that the sprocket is loose in the new tip too?
I have never changed a tip either, but it seems weird that the new one would be loose too.
Online mike_belben
  • Pulp Friction
« Reply #2 on: April 20, 2018, 09:39:45 PM »
No no, sorry.   The sprockets are both fine. The insert is loose in the end of the bar.  Do these normally get loctited in or something?
Revelation 3:20
Offline sawguy21
« Reply #3 on: April 20, 2018, 09:48:36 PM »
It sounds like the rivet holes in the bar are enlarged, the metal must be soft. How old is it?
Online Skeans1
« Reply #4 on: April 20, 2018, 10:24:02 PM »
Ive had them wear out like that before Mike, had to get a new bar in my case they had worn so bad the seats of the tip didnt hold it tight anymore.
Online mike_belben
  • Pulp Friction
« Reply #5 on: April 20, 2018, 10:28:28 PM »
I checked the hole and it held the rivet tight, i was wondering if these are supposed to have a hole offset to pull the tip in maybe.
If its destined to wobble ill probably braze the old one back on and save this new tip for the next one.
Revelation 3:20
Offline ehp
  • logger/chainsaw hack
    • ehpsaws.com
« Reply #6 on: April 21, 2018, 04:25:23 PM »
that happens a lot and I mean a lot if your cutting in the bush for a living . How did I fix that problem, I went to a different bar maker . The older 5 rivot Windsor speed tip bar was a lot worse than the Oregon bar for coming loose
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #7 on: April 21, 2018, 05:30:54 PM »
I've got a country line (TSC) bar has less 5 cords on it and the replaceable tip is just starting to come loose/wiggle. All I was going to do was drill down into the bar in 4 spots (2 on each side) and tack weld it then grind/sand it smooth.
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #8 on: April 22, 2018, 11:01:49 AM »
Ive had Oregon bars do that but usually after several replacement tips. Probably just have to weld it or braze it and throw it when the tip blows. Im trying a sugihara bar hoping it will last better than Ive experienced with Oregon...
79 TJ 225 81 JD 540B Husky and Jonsered saws
Online Skeans1
« Reply #9 on: April 22, 2018, 11:17:12 AM »
Sugihara is a great bar hard rails the tips are ok about the same as Oregon for life.
Offline ehp
    • ehpsaws.com
« Reply #10 on: April 23, 2018, 12:58:53 PM »
those bars are better than Oregon, I run them on my huskies. I find I have to take it easy on the first part of the tank or I get tip problems right off the start, after a tank they seem good to go . Have found thou the chain can pull down into the tip on them but the last bunch of bars I have not had that problem
Offline Grandedog
    • Left Coast Supplies
« Reply #11 on: April 24, 2018, 04:04:29 PM »
     Howdy,
   Ed mentioned the Windsor bars back in the day were more stable than the Oregon because of the long recess tang. Back when Weyerhauser was cutting St. Helens, Windsor sold tons of bars and probably even more tips to them. Guys were going through a tip or better a day. They didn't bother even riveting the tip in. Just roll the chain off and slide in a new tip and back to cutting Douglas Cement.
Regards
Gregg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
Online Skeans1
« Reply #12 on: April 24, 2018, 09:24:30 PM »
Ive heard those stories Gregg and guys buying new saws once a month its impressive to still see to this day.
Offline joe_indi
  • The older I get the more I learn
« Reply #13 on: April 24, 2018, 11:09:16 PM »
Sometimes the hole on the bar might have worn and become bigger. In such cases before flattening out the rivet, using a center punch with a heavier hammer causes the rivet to become fatter and tighten up in the hole. Tap it flat only after this. This should help
Online mike_belben
  • Pulp Friction
« Reply #14 on: April 25, 2018, 10:10:22 AM »
I measured them all, no wear in any dimension, rivets were tight fit.
Im guessing its a chinese clone and some ching chong loctite knockoff is what kept the first tip in there snug enough for initial sale.   Heat would cook that out over time.
Unfortunately, there is no evidence this bar was ever manufactured for a good fit.
Revelation 3:20
« Reply #15 on: April 25, 2018, 10:18:28 AM »
How are the bar rails holding up? If the rails are holding up good and you just tack weld on a new tip you could just drill out the tack weld then tack on a new tip.
Online mike_belben
  • Pulp Friction
« Reply #16 on: April 25, 2018, 03:38:54 PM »
Kinda wore a bit fast IMO but i redressed it entirely when i did the tip.
Revelation 3:20
Offline ehp
    • ehpsaws.com
« Reply #17 on: April 25, 2018, 11:38:14 PM »
in the 80's and 90's   I use to buy tips in a 10 pack and that may not last the week in the winter time for just me
Stihl MS250: wingnut in sprocket cover keeps coming loose
Started by buckthorn on Chainsaws
Last post November 24, 2013, 11:50:26 PM
by deerslayer
Can't get loose
Started by Magicman on Technical Support Topics
Last post September 22, 2011, 09:34:24 PM
by Magicman
Loose Screws
Last post August 31, 2011, 08:03:49 AM
by clww
Loose Chains
Started by Ga Mtn Man on Chainsaws
Last post February 27, 2015, 09:18:23 AM
by Hitchcock Woods
