Baltic Abrasives Technologies
Author Topic: Diesel engine on wm  (Read 1154 times)
Offline richard boyd
  • 93 LT40 Woodmizer
Diesel engine on wm
« on: April 21, 2018, 03:35:58 PM »
Question I need info on what diesel engine you are running on your wm super hydraulic mill. Make and model number would be good. I have a Lombardini engine that is beyond repair and can't afford to spend 9 thousand on a new engine. Was hoping to find a Kubota engine to replace the Lombardini. I know I'll have to do a little fabricating to just bolt it up. Thanks in advance.  PS. Has manual clutch.
Offline terrifictimbersllc
    • Terrific Timbers LLC
Re: Diesel engine on wm
« Reply #1 on: April 21, 2018, 05:02:11 PM »
My 2001 has a 4 cylinder 42HP Kubota.  I'll get the model number off of it.  This engine I've been told was one of the best for this mill.
DJ Hoover, Terrific Timbers LLC,  Mystic CT  2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.  2001 F350 7.3L PSD 6 spd manual ZF 4x4 Crew Cab Long Bed
Offline JB Griffin
« Reply #2 on: April 21, 2018, 05:05:42 PM »
My standard hyd has a 1505 kubota on it. Wm calls it 33hp
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2.5 million bdft sawn with a Baker Dominator and counting.
Offline Percy
  • Resident trouble maker
« Reply #3 on: April 21, 2018, 07:32:17 PM »
I have the Kubota 1505t which is the same as JBís cept for the turbo giving 42 hp. It has lots of torque, stingy on fuel and mine has 11000 hours on it. No crank support kit needed. Only grief was a front crank seal that I changed myself in about 3 hours. Had to remove radiator or it woul have been easier. It just runs and runs. For the life of me, I canít understand why wm quit using them. Musta been some corporate issues yadda.
Online Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #4 on: April 21, 2018, 07:36:47 PM »
Mine is a 2008 Perkapiller 51 hp. It's a common engine in small equipment like the ASV tracked skid looaders. I'd look for a Kubota.
Offline barbender
« Reply #5 on: April 21, 2018, 07:53:12 PM »
If my Lombardini ever lays down I'll be Kubota hunting. I wondering the other day if you could get WM to sell you a mill without an engine, like the "glider kits" we get for trucks. I really wouldn't want one of the tier 4 small diesels. I'm sure that the bugs will get worked out of them eventually, but I'd prefer it wasn't on my dime.
Offline starmac
« Reply #6 on: April 21, 2018, 08:31:08 PM »
I don't know what horsepower they are rated at, but those perkapillar engines were used in some of the light towers and can be picked up pretty reasonable every now and then.
  • 93 LT40 Woodmizer
« Reply #7 on: April 21, 2018, 08:55:04 PM »
Thanks for the response. I need all info I can get to get this thing going. Again Thanks.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: April 21, 2018, 09:31:38 PM »
I hope that you do not have to settle for less hp or a gasser.  :-\
Offline thechknhwk
    • Story of the Trees
« Reply #9 on: April 21, 2018, 09:47:44 PM »
The kubota on my mill is a 33hp model number v1505.
Offline scully
  • Orange Mills Matter
« Reply #10 on: April 21, 2018, 09:58:55 PM »
I think you can get the right hardwhare to mount a Kabota from WM , Bar none Kabota is the best diesel they ever starped on a mill ! My turbo is smooth as silk !
I bleed orange  .
Offline PAmizerman
  • Just Another Day In Paradise!!
« Reply #11 on: April 21, 2018, 10:12:50 PM »
The Kubota on my 2001 lt40 super is a
42hp model 1505D
Hydraulics everywhere
Traverse 6035 telehandler
WM bms250 sharpener
WM bmt250 setter
Offline gmmills
« Reply #12 on: April 21, 2018, 10:47:58 PM »
   Try to find a Kubota.  I have put over 4200 hrs on my first lt 40 super remote with a 42 HP 1505 t Kubota on it. Great engine. Only needed fluid and filter changes over that period of time. The engine mounting plates may still be available from  WM. If recall correctly, the 1505 engine was only offered as a power unit not a tractor engine.
    Only consider a Perkpillar engine if it is extremely reasonably priced. I personally put over 7600 hrs on one. Had the head off of it twice, head gasket, and both front and rear oil seals replaced.  That engine family was the poorest overall quality of any industrial diesel engine I have ever owned.  I will never own another one.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
« Reply #13 on: April 22, 2018, 10:37:06 AM »
It says V1505D on the engine, 1.498 L
  • 93 LT40 Woodmizer
« Reply #14 on: April 22, 2018, 11:00:12 AM »
Thanks for the reply's. I found a Kubota engine V1505 T to replace the Lombardini engine. If wm don't have the hardware I need to mount it we'll come up with something I'm sure. Thanks again.
Diesel engine and bio diesel
Started by artenvielfalt on Peterson Portable Sawmills
Last post August 10, 2008, 07:33:45 PM
by techmark
diesel engine?
Started by getoverit on Sawmills and Milling
Last post November 26, 2005, 08:13:20 PM
by twistedtree
MWM Diesel engine
Started by Tin Horse on Sawmills and Milling
Last post April 09, 2018, 10:14:16 PM
by jason.weir
diesel engine
Started by saltydog on Wanted
Last post April 03, 2010, 11:53:47 AM
by saltydog
