Author Topic: Tordon question  (Read 1008 times)
Offline gspren
Tordon question
« on: April 21, 2018, 04:25:58 PM »
  I got a quart of Tordon and started cutting some of the wild cherries and mulberries that were sprouting up around the pines. The Tordon stayed on the stumps although the sap is starting but on a vine about 1" dia the juice was coming out so strong that the Tordon pretty much just floated off. Is it the wrong time of year to use or just wrong for the vines? When will be a better time.
Offline Claybraker
  • Mostly New!
Re: Tordon question
« Reply #1 on: April 23, 2018, 04:27:42 AM »
I've had good luck this time of year with the drill and fill technique using Tordon on wild grape vines and really about any stem I can drill a shallow 3/8" diameter hole. Never been a big fan of cut stump, seems like more work than necessary.
Offline Blue Noser
Re: Tordon question
« Reply #2 on: April 23, 2018, 07:20:08 AM »
 Would it have been possible to do a foliar application?
Maybe try a cut stump application later on in the growing season when sap flow should be less vigorous.
Offline John Mc
Re: Tordon question
« Reply #3 on: April 23, 2018, 07:04:25 PM »
In most parts of the US, this is the wrong time of year to be doing cut stump. I usually start around mid-summer and go until the leaves start to turn.
Offline colby 92
Re: Tordon question
« Reply #4 on: June 09, 2018, 07:26:50 PM »
spring means heavy sap flow. everything is trying to grow leaves and put flowers on, so upward flow of sap is very high. I do most of of my stump spraying after the target plants have their leaves and are actively growing. I mainly commented because i was thinking that Tordon is know to move through the soil to other plants (no target plants) if used heavily.Might want to check that out before going full throttle on it. A strong concentration of Glyphosate will do the job. 50%.
Offline Larry
Re: Tordon question
« Reply #5 on: June 09, 2018, 08:09:21 PM »
I use a lot of the rtu tordon in the quart squirt bottles for cut stump application.  I only use it in the months that have an "R" in them, just because its too hot to be in the woods in the other months.  Most use comes in January or February.  My vine experience has only been with grape vines up to 2" diameter.  Always had excellent results on anything I used it on.
Tordon question
Started by Steven A. on Ask The Forester
Last post June 02, 2017, 07:55:02 AM
by Claybraker
Tordon and T.S.I.
Started by Smitty316 on Forestry and Logging
Last post November 02, 2014, 09:54:17 PM
by chain
Band selection question (boring question but includes bonus pics!)
Started by Piston on Sawmills and Milling
Last post October 15, 2010, 05:39:58 PM
by barbender
angry
Question for you surveyors (sorry but it's a touchy question)
Started by SwampDonkey on General Board
Last post September 25, 2008, 10:55:40 PM
by cheyenne
