Author Topic: How to place the sawmill  (Read 1185 times)
Offline teed
  • All this is new to me!
    • Twitter
« on: April 22, 2018, 11:14:07 AM »
I have made a video about how I placed my sawmills to help others place their sawmills. have I missed something you think?
Offline ljohnsaw
Re: How to place the sawmill
« Reply #1 on: April 22, 2018, 12:04:16 PM »
Teed,
 8) Very nice video!  You covered it pretty well.  I like the "review" lists after each discussion.  The only thing missing (and I didn't see any around) was how and what do you do with your slabs (opening cuts)?
John Sawicky
Offline Skipper11A
« Reply #2 on: April 22, 2018, 09:11:31 PM »
Great video!  I agree that you should mention how you handle your waste wood.
Offline teed
    • Twitter
« Reply #3 on: April 23, 2018, 08:06:22 AM »
Yes I clearly forgot of cut :) I have to make a update video for the things I forgot
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #4 on: April 23, 2018, 08:33:42 AM »
Very nice teed.  How do you decide which mill you are going to use?  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline dboyt
  • Log On!
« Reply #5 on: April 23, 2018, 08:58:14 AM »
Thanks for the video.  I agree, it is great to have the sawmill out in the open where you can work around it from all directions.  Do you remove the sawmill from the track at the end of every day that you use it?  How long does it take to set it on the track and get it ready to cut?
Offline teed
    • Twitter
« Reply #6 on: April 23, 2018, 09:05:46 AM »
No I donít remove it every day :) itís really simple to putting it on the track and removing it, max 3 min.
Offline teed
    • Twitter
« Reply #7 on: April 23, 2018, 10:29:44 AM »
For hardwood I run the Logosol it gives much better cut quality, and sidings I run bandsaw since the cut quality is not so important
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #8 on: April 23, 2018, 02:10:30 PM »
Tobias,
   Nice video. Thanks for posting. Very good points. The major things I think you need to consider, and you covered, was access for the equipment and logs and removal of the boards and waste.
   The amount and kind of equipment you have available and the size  logs you saw are major influences on your setup. Keep up the good work.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #9 on: April 23, 2018, 09:53:25 PM »
I never would have guessed that a chainsaw mill would have a better quality cut than a band mill. Interesting.
1992 LT40HD
Offline teed
    • Twitter
« Reply #10 on: April 24, 2018, 07:10:35 AM »
Saw quality with logosol electrical saw beats everything else I have tested. I have compared to a mass of different sawmills.
It is important to take care of bar and chains to get a good quality cut.
Why I bought a sawmill in the first place
Started by SW_IOWA_SAWYER on Sawmills and Milling
Last post February 22, 2007, 11:15:22 PM
by sawmilllawyer
Circular sawmill popping in place.
Started by Satamax on Sawmills and Milling
Last post June 30, 2017, 07:58:30 AM
by bandmiller2
I really like this place
Started by mrector on Sawmills and Milling
Last post August 18, 2013, 09:57:34 PM
by Ernie
could you use a 4''x6'' in place of a 2''x12''
Started by Rod on Sawmills and Milling
Last post September 13, 2004, 05:30:03 PM
by karl
