Baltic Abrasives Technologies
Author Topic: velocity fuses?  (Read 398 times)
Offline starmac
velocity fuses?
« on: April 23, 2018, 03:37:07 PM »
I have a question about the velocity fuses on my old woodmizer. Mine looks a little different than pictures of the replacements, as they have female threads in each end,an elbow coming out to the hose and a short nipple on the other end to screw into the cylinder.
The nipples are both bent and cracked (leaks) but do not want to break lose from the fuse, can I heat the fuse itself or is there something inside it that heat will damage? I suspect it is just metal with a restricted hole in it, but am not 100% sure.
Offline Jim_Rogers
  • Keep your chisels sharp.
    • jrsawmill.com
Re: velocity fuses?
« Reply #1 on: April 23, 2018, 04:18:22 PM »
Sounds like a job for blue creeper.
If it's broken and leaking then it doesn't matter about the heat. Just do burn up beyond what you need to save.
You should post a picture of your set up.
Mine is male on both ends with a spring thing inside to activate when you need it.
They should have replacement parts for your machine, unless someone else put something else on it. Or give you an idea of how to work around your situation.
Jim Rogers
Online Dave Shepard
  • Geometrically proportional
    • My homepage
Re: velocity fuses?
« Reply #2 on: April 23, 2018, 04:23:04 PM »
There should be a spring and a little disc with holes in it in there. The spring probably won't survive heating. The replacements ate soils in pairs, as they are rated for gpms. I think mine are 5 gpm fuses.
WM log loader velocity fuses
Started by Ga Mtn Man on Sawmills and Milling
Last post October 03, 2014, 07:46:39 PM
by delvis
225 amp fuses for 98 or after Woodmizer GONE!!
Started by Papa1stuff on For Sale
Last post November 07, 2012, 01:54:39 PM
by Papa1stuff
225 amp fuses for woodmizer sawmill
Started by just_sawing on Sawmills and Milling
Last post March 09, 2006, 07:58:18 AM
by sparks
velocity fuse removal
Started by Dan_Shade on Sawmills and Milling
Last post July 25, 2015, 10:06:52 PM
by Dave Shepard
