Author Topic: Top handle saw-which one  (Read 2751 times)
Offline Tinbeers
« on: April 23, 2018, 07:41:01 PM »
I have decided to buy a top handle saw for on the ground work. The only saw that I have handled is the 193T stihl with a 14" bar. There is a husqvarna dealer and an echo dealer not to far off but none of them have any top handle saws. What are yall's thoughts on the 193t vs the t435 or the echo 355t? I have an old 028 for big stuff but need a small limbing saw. No I am not a professional, I am 55 years old and have been using a chainsaw sense I was a teenager. Thanks for any information.
Offline Maine372
Re: Top handle saw-which one
« Reply #1 on: April 23, 2018, 10:01:25 PM »
what task are you accomplishing with a top handle?
if its weight saving you are after there are plenty of reduced weight saws available without the added risk of one handing the saw.
I was recently impressed by a husqy 543xp. the off switch is a little small to hit with a gloved hand but otherwise it packs a punch for its size/weight.
Offline wild262
« Reply #2 on: April 24, 2018, 07:09:03 AM »
              Not a top handle, but check out the Echo 361P.  Its the 355 with a rear mounted handle.  Very light limbing saw.  I bought one and really like it.
Offline samandothers
« Reply #3 on: April 24, 2018, 11:34:31 AM »
I have a CS341 Echo and I like it.  I use it for limbing or to carry on the 4 wheeler.  Iíve used it to do a lot of sawing while building my pole barn versus using a generator to power other saws.  Handy size. I am cutting something large are real hard it may bog but it is 33 cc and I have a larger Stihl for the bigger stuff.  I assume it maybe for climbing as it has a snap ring.  It is not available now, I donít believe, but there are similar size Echos. The CS 355 maybe similar.
Offline mike_belben
  • Pulp Friction
« Reply #4 on: April 24, 2018, 01:47:10 PM »
Ms200T.  I use a 192tc on the ground nearly every day and love it, except for being a bit low on power.
Revelation 3:20
Offline Al_Smith
« Reply #5 on: April 24, 2018, 04:15:57 PM »
Well now a Stihl 200T is one dandy saw,I have two of them .However for what a decent one will fetch on the open market you could buy a fairly large rear handled saw ,maybe several .
Offline John Mc
« Reply #6 on: April 24, 2018, 04:43:29 PM »
Curious why you'd go for a top handle saw for ground work?
Offline slider
  • sawyer,trucker,tree service
« Reply #7 on: April 24, 2018, 06:37:21 PM »
I am on my third 193t in 4 and one half years . They are great saws for bucket work but hard on crank seals . The repair parts are cheap but i don't have time to rebuild them myself. These saws are used every week so i am not knocking them . I just ordered a new echo to try out for a backup saw.
al glenn
Offline ZeroJunk
« Reply #8 on: April 24, 2018, 09:01:24 PM »
I know there is some added danger with the top handles, especially ones that scream like a MS200T.  But, they are very convenient to set on the floor board of a tractor to go get trash out of the edge of fields, fence lines and such. If I just stick it in the bucket I have a tendency to forget it's there.  :(
Offline Al_Smith
« Reply #9 on: April 24, 2018, 10:32:14 PM »
I've got a little 024 Stihl that rides around on my zero turn mower .Every so often a low hanging tree branch  knocks my hat off which rather annoys me .It will only do it once .
Offline Tinbeers
« Reply #10 on: April 25, 2018, 08:29:02 AM »
I am going to look at the echo top handle Saturday, it will be between it and the sthil. I am leaning toward the echo saw. Thanks
Offline Tinbeers
« Reply #11 on: April 25, 2018, 08:31:18 AM »
Weight and easy to use. Easier to run than a regular saw to me.
Offline mike_belben
  • Pulp Friction
« Reply #12 on: April 25, 2018, 10:06:33 AM »
I have no shortage of saws but reach for tophandle in any work under 8 inch.  Love it.
Revelation 3:20
Offline Al_Smith
« Reply #13 on: April 25, 2018, 07:47:01 PM »
As it seems the older I get the more I've came to appreciate lighter smaller saws .I seem to refer to Stihl but that's not the only option .Fact in the last several months I've done work for others on Echo saws and for the money they do just fine .They aren't oak slayers but for small jobs they are hard to beat .
Offline Greyman
« Reply #14 on: April 26, 2018, 08:45:54 AM »
Stihl tells dealers that their top-handle saws should only be sold to licensed arborists.  Some dealers follow that and some don't.  If they don't they are putting themselves in a bad legal situation.  I wouldn't be surprised if they keep them in the back so the average homeowner won't be tempted to buy one instead of a (much safer) rear handle saw.
Offline woodsdog2015
  • Newbie Woodcutter
« Reply #15 on: April 26, 2018, 02:07:50 PM »
My first ever chainsaw (which I still own and gladly use) I bought several years ago brand new from an Echo Dealer that is no longer around.  He was getting out of the business but not for lack of sales.  Anyway, at the time I needed/wanted a saw for minor yard work and for tree stand preparation so I picked up a CS-300.  It looks like the one pictured here but I just copied this picture off the internet.  It is a climbing saw, has a big loop on the back of it that you tether it to your belt while climbing a tree.  This saw cuts like a beast, starts like a dream and I never really do anything to it except change the spark plug and clean out the air filter and sharpen the little mini chain with a 5/32" file.   I don't know if the newer ones are this caliber now or not but if you can find one of these, they're great little saws.
 OFFSITE IMAGE DELETED BY ADMIN
I'd rather be in the woods.
MS362CM
MS251
CS-300
Homelite 8800
FiskarsX27
Offline Al_Smith
« Reply #16 on: April 26, 2018, 08:35:14 PM »
Everybody has the misdirected
 idea you have to "one hand" a top handle .Nothing could be further from the truth .I have the first saw I ever bought which is a Poulan S-25 purchased around 1974 which I might add  runs as good or better today than it did brand new .It's all I had for years .I cut and sold firewood with that little thing for 8 or 9 years and never had a problem and didn't rebuild the carb until it was over 30 years old .It's classified as "top handle" and I never one handed it .
Offline DelawhereJoe
  • Trapped in Delawhere
« Reply #17 on: April 26, 2018, 09:14:51 PM »
I've got a old homelite xl that looks alot like your saw. I'm trying to retire it because parts locally are unavailable. Theres only 1 store that I can get chains for it and no one except the Internet has bars and air filters for it. Plus the carb needs to be rebuilt/replaced.
Offline mike_belben
  • Pulp Friction
« Reply #18 on: April 27, 2018, 01:35:31 AM »
Im with AL.  They have a top handle and a side handle.  If i dont need my spare hand, it goes on the saw during cuts.
I didnt want to argue it earlier but my reason for suggesting tophandles is my feeling of MORE safe.  Not less.  When i whittle up a top thats down, and stumble over the mess of branches im tromping over, i actually CAN control the tophandle with just one hand as im going down.  If i trip with a 2 handle and my front hand shoots out subconsciously, the saw is going to fling uncontrolled down at my leg or foot, i cant hold a rear handle with one hand.  Its all luck then.  The top handle does NOT want to nosedive like the rear handle when you take your left hand off.
If you find yourself constantly putting down a conventional saw to do a little this and that.. Picking it up, putting it down.. And just get tired of bending down for it in your ground tasks.. Then try a tophandle.  Youll rarely need to set it down at all.  I cut tops on the ground at almost every node, as if i were in a bucket truck.  So the spare hand in that operation is more valuable than the extra power.  Now If i were only making a few cuts and snatching logs then i wouldnt even bring it along.
Revelation 3:20
Offline chet
« Reply #19 on: April 28, 2018, 09:51:03 AM »
Many folks have the mistaken impression that a tiny little top handle saw can't do the great bodily damage as a bigger full size saw is capable of. 'I can control dat tiny little thing one handed no problem'. After a long and pain filled healing process my younger brother no longer has that attitude.
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
I need a new axe handle
Started by sawbob011 on General Woodworking
Last post May 30, 2010, 01:49:29 AM
by SwampDonkey
I Can Handle It!
Started by Lud on General Woodworking
Last post September 23, 2012, 03:49:22 PM
by Magicman
Can I handle it?
Started by Brad_S. on Sawmills and Milling
Last post March 27, 2006, 09:35:29 PM
by wiam
New handle
Started by OneWithWood on General Board
Last post October 11, 2002, 03:19:25 PM
by Texas Ranger
