Author Topic: Siatic nerve pain  (Read 7070 times)
Offline alan gage
Re: Siatic nerve pain
« Reply #60 on: January 28, 2019, 05:19:51 PM »
At the advice of my doctors I put my last surgery off for a couple of years of on and off again issues until that fragment made the decision for me as I could not walk.  I remember during recovery commenting that I should not have waited so long, the constant pain takes a toll on so many levels that it was not in my best interest to have waited, but that was my experience.  I will say that from my experience your February / June recovery schedule seems a bit optimistic if you plan on doing much serious physical work.
The "why did I wait so long" seems to be a common theme when it comes to "elective" surgeries like knees and hips. Probably backs too.
As for the June recovery I'm hoping that by June I'd at least be active and happy enough to enjoy the summer. I'd be hoping for more strenuous activities (like building the shop) in late summer or fall. Then I could spend all winter enjoying that new shop rather than recovering from surgery. I'll be doing some Googling to see how most people seem to fair in terms of fusion recovery.
I'm back from the acupuncturist. No immediate results. Will see how I feel over the next few days. Going back again on Thursday AM.
Alan
Timberking B-16, a few chainsaws from small to large, and a Bobcat 783 Skidloader.
Offline BradMarks
  • Foresters are TREE-mendous
    • Pacforest Supply
« Reply #61 on: January 28, 2019, 07:02:45 PM »
Addressing the "why did I wait so long" issue, I too had the same thing with me. I would ask people who had surgery "how do you know when it's time?" and the response was generally "you'll know when!".  And you certainly will, because if the need for surgery is there, your condition does not get better but does get worse.  That's the physical part.  Being in constant pain is not easy on those around you, my wife was very relieved when I decided to get the MRI, and surgery was shortly thereafter. I was making life H**L for her.
Offline samandothers
« Reply #62 on: January 28, 2019, 09:51:50 PM »
Only regret from my fusion surgeries was waiting too long.  My symptoms prior to my first surgery did not totally go away.  Pain did ease and some numbness went away but not all.
It may be too early to tell results of the second surgery. The doc did say with brushing that has occurred it will not get worse but may not get better.  I am hoping that it will improve more than it has but I am only 3.5 weeks out.  I still have the pain and unsteadiness on my feet.
I feel if I had gone earlier versus putting off 'surgery' I'd be in a better place.  Both surgeries were easy and out with one over night stay.  No lifting over 8 lbs for at least 6 weeks and at that point we'll see.  I will point out my surgery was at the cervical end and not lumbar.  My entry was through front of neck and therefore probably less tissue and stuff to navigate.
Hope the acupuncture works!
Offline alan gage
« Reply #63 on: February 19, 2019, 06:56:00 PM »
Gave up on the acupuncture after 6 visits. The same place does chiropractic as well and wanted to give it a shot. Second time for that today and no improvement yet.
Last week went to see another neurosurgeon for a second opinion. He wanted to see another MRI to be sure things hadn't changed (last one was in June or July). Went to Sioux Falls yesterday to have that done and met with him the same day. He pretty much agreed with the first neurosurgeon, that I'm probably looking at a fusion to correct the issue.
Sounds like they're still not positive the bulged discs are causing the issue since the bulges just aren't that big. But the L5/S1 is degenerated pretty bad and that's what they're suspicious of. So in a couple weeks I'm going back for a discogram where they'll inject fluid directly into the L4/L5 and L5/S1 discs and if one (or both) of them is causing my issue the pain I've been experiencing will be replicated at the time. If neither disc replicates the pain then it's back to the drawing board.
Doctor said pain shouldn't be too bad; similar to the pressure I felt from the cortisone injections. He also said they'll have an I.V. in place in case the pain gets too severe and then all I have to do is say (scream) the word and they'll send me to lala land.
When I got home last night I made the mistake of Googling the procedure. Sounds like it can be a bit unpleasant, to put it mildly. Thankfully I also found some people who said they thought it was going to be terrible (after reading online) but it turned out to be no big deal. Wonder which one I'll get?
Alan
Offline red
  • we will never forget
« Reply #64 on: February 19, 2019, 07:50:04 PM »
In winter of 1998 I had a discogram and I was in major pain . Both my L4-L5 and L5-S1 were Shot . In spring of 1998 I was operated on and fused at both levels.  It was a very slow recovery , until about Christmas time.
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline Southside
« Reply #65 on: February 19, 2019, 08:03:21 PM »
Had one of those done along with a test where they did nerve conduction via electronic signal - not pleasant, but not the worst thing ever, one where they used some hollow needles moving around to listen to the sounds the nerve made - I eventually grabbed the guys wrist and told him not to touch me again or someone else would be listening to the sounds he was making, and the disc-o-gram - they had partially sedated me for that one and even then it was about as bad as when I broke my L5, could not get the pain meds in fast enough.  The problem is if the test is accurately replicating the issue - which in theory is the right result - then you will be replicating the response.  Yea - it's bad, when I accidentally put a 16 penny nail through my finger using a pneumatic framing nailer and pulled it out with a pair of pliers I was told I have a high pain tolerance, but I would never do the disc o gram again.
Offline alan gage
« Reply #66 on: February 19, 2019, 08:51:04 PM »
I had an EMG test done as well. The needle part didn't really hurt at all. The most unpleasant for me was when they hooked up the electrodes and gave little shocks but even that was bearable since the bursts were so short.
I've got my fingers crossed on the discogram. I'm going to pretend I didn't see you and Red say it hurts like hell.
Alan
Offline alan gage
« Reply #67 on: March 04, 2019, 01:33:44 PM »
I had some interesting talks with my latest chiropractor. He said my SI joint on the right side has little to no movement. My last chiropractor also said things on the right side of the hip weren't moving well at all. New x-rays show my right hip is about 12mm higher than my left. When I had x-rays done a year ago it wasn't nearly so far off. I'm standing more hunched over and crooked than ever before.
But as to the chicken and egg (are other back issues causing the hip problems or are hip problems causing other back issues?) he says he's not sure. Despite his best efforts to get the hip to loosen up I ended my sessions with him in more pain than when I began, which was the same as the first two chiropractors I'd seen.
After taking 5 days off from chiropractic sessions things were starting to feel a little better but then Saturday I had to quit taking ibuprofen in preparation for my upcoming discogram on Tuesday. Now I can barely sleep or walk. I don't think there's a 90 year old woman in town who couldn't beat me handily in a foot race. Surprisingly enough the nerve pain in my legs hasn't really gotten worse since going off ibuprofen but the hip sure has.
The last chiropractor I saw was pretty adamant that I should try everything possible to avoid surgery. Said that my MRI and x-ray look better than most of his patients. That surgery shouldn't be required. But he's also at a loss to explain my symptoms and lack of response to treatments. I'm very interested to find out the discogram results on Tuesday and on Thursday I'm going back to see my non-surgical back doctor to get his thoughts.
I'd love to avoid surgery but mostly I just want to feel human again.
Alan
Offline alan gage
« Reply #68 on: March 05, 2019, 09:12:05 PM »
Had my discogram today. When they injected the L4/L5 disc I think my head exploded. But despite the severe pain I didn't think it was so bad overall. I was afraid the pain would last all day (or longer) but in less than a minute after the injection the intense pain had subsided to the same level it was at before. They gave me some of the good drugs via IV after he was done with the injections and the remaining pain just melted away. It probably only took 5 minutes start to finsih for three discs (from the time the doctor started injecting). The L3/L4 gave no pain at all and the L5/S1 wasn't too bad. The L4/L5 leaked some of the fluid out as well. So overall not a pleasant experience but not traumatizing either.
It's looking more like fusion on two levels (L4/L5 and L5/S1). On Thursday I'll be meeting with my non-surgical back doctor and on Monday will be meeting with a different physical therapist. I want to see if either of them have any ideas on treating the hip pain without going through surgery. In the mean time they're going to try and get approval from the insurance company for surgery.
Alan
Offline Roxie
  • Gender: Female
  • I'm your huckleberry
« Reply #69 on: March 07, 2019, 11:18:17 AM »
Please continue to keep us updated on your progress.  Hoping for a good outcome for you.
Save a farm today or starve tomorrow.
Offline alan gage
« Reply #70 on: March 07, 2019, 03:50:03 PM »
Went to see my regular (non-surgical) back doctor today. Just wanted to go over everything with him again to be sure he couldn't think of something we'd missed or if he had any other recommendations or misgivings. He listened to everything I had to say, asked some questions, and gave my hip a going over. He's of the opinion there isn't a problem with my hip (despite having lots of hip pain). He said they often see complaints of hip pain but the source is elsewhere (like my bad discs). He reiterated that fusion is a last resort but seems to be out of other ideas. He said we could try more injections or physical therapy but he wasn't real confident in them doing me much good based on my treatment history.
He didn't come out and say I should have surgery but reading between the lines I think that's what he's leaning towards. I suppose unless they see something really bad then it's a decision that is supposed to be left up to me.
I'll be seeing a physical therapist on Monday to see if they have any bright ideas and hope to see my other neurosurgeon soon to get his thoughts. He's the one that I'd like to do the actual surgery if it comes to that but I'm not sure how soon they can get me in. He's going to review my discogram results and I should be hearing from his office early next week. I have confidence in both surgeons doing a fine job but he's the one I started with and we got along well (not that I don't get along with the other).
At my discogram earlier this week they prescribed me hydrocordone and tramadol. This is the first prescribed pain medication I've ever used. I took a tramadol last night a few hours before bed and I had my best sleep in months. Took another when I woke up this morning and so far feel better today then I have in quite a while. I don't really want to make a habit of using this stuff but it sure is nice to get a little relief.
Alan
Offline mitchstockdale
« Reply #71 on: March 11, 2019, 11:04:52 AM »
Alan
Alan,
Not sure of your whole history or your physical condition / habits but just from quickly reading a couple of your posts it reminds me of a couple things I have heard of before... have you heard of, or considered, spinal decompression.  From what i gather this allows the spine to lengthen and alleviate stress on the discs. I have heard its very helpful on bulging discs.
Another story I remember was on the Joe Rogan podcast with a former wrestler called Diamond Dallas Page. He runs an intensive exercise program that has a yoga base and remember the story of a veteran that could not walk without the help of two canes from an injury while in service, he was able to rehabilitate his injury through the program.  Weak muscles and poor posture put alot of undue stress on your skeletal system especially your spine.   Anyhow here is the link .
I suffer from chronic backpain and acute sciatica...all my problems stem from sitting in a chair 8 hrs a day.  Hitting the gym regularly and focusing on back and core muscles helps keep the pain at bay for me.  Although it difficult to maintain with little kids and ton of other stuff to do.
Hope you can find a solution.
Mitch
Do today what others wont, so you can do tomorrow what others cant.
Kubota MX5200 / Woodland Mills HM126 / Stihl MS361
Offline alan gage
« Reply #72 on: March 11, 2019, 06:35:30 PM »
Saw the physical therapist today. He spent about 30-45 minutes with me doing an evaluation asking me questions and figuring out what hurt when. He had me on my stomach doing a combination of things repetitively trying to gain some range of motion before feeling pain in my buttock and my leg tingling. We didn't gain any ground.
My posture is very crooked so he also tried a couple methods of hip repositioning but neither of them worked either. By the time we were done I was just as crooked and in slightly more pain. He said he didn't think he would be able to do anything for me.
It's not really the answer I wanted to hear but I'm glad that he was upfront with me and I wish I'd at least started my physical therapy from 1 year ago in Sioux Falls (where I was today) rather than back home at our small hospital. He appeared to be very conmpetent and seemed to realize the reason why we hit a wall with some exercises when trying PT before. Of course he also has the benefit of MRI and a year's worth of my medical history on this problem.
Anyway, that pretty much clinches it. I'll be having surgery. Can't wait to get it done and start recovering. I'm about ready to leave work now and then I'll go home to lay down and read in bed for 3 hours before going to sleep. Pretty exciting life.
Thanks for the info and links, Mitch. I really do appreciate it.  I've done some reading on the spinal decompression and decided against it since I couldn't come up with any definitive evidence of it working as claimed and at this point I don't want to invest 1.5-2 months into something I'm not confident will work. As for the yoga thing it looks great but I'm not convinced it will work for me (isn't that what everyone says?). I've tried stretching and PT but we've never been able to gain any ground. Before I get to the point where I'm stretching any muscles the nerve pinches and I get a lot of pain in my hip/buttock and my lower leg starts to tingle. This has gotten progressively worse over the last year and it hasn't mattered if I've been up on my feet doing everything I'm capable of (running sawmill, cutting/splitting/stacking firewood, building lean-to addition, putting flooring in my hose, going for walks) or if I've taken it easy for a week or two. Nothing seems to help and I keep going downhill.
Alan
Offline doc henderson
« Reply #73 on: March 11, 2019, 07:23:20 PM »
alan, I have sciatica as well from an injury trying to move an overweight combative pt.  with mri, you should know if the prob. is a  nerve outlet (surgery may help 50/50) vs periformis muscle spasm/injury/swelling ( injection may help).  Just like you, I avoid surgery if at all poss.  I have a buddy who is a chiropractor, and he did a drop table maneuver to move my SI joint, that seemed to help temp., but not for long.  i had an injection from my buddy a pain doc, and I had foot f\drop for  a day and less pain, then all returned. i got my L knee scoped and my maniscus trimmed, and now my intermittent sciatica is improved.  i was favoring my L knee and flaring up my chronic intermittent sciatica.
timberking B 2000, 277c track loader, PJ 32 foot gooseneck, 1976 F700 state dump truck, JD 850 tractor.
Offline alan gage
« Reply #74 on: March 13, 2019, 12:45:21 PM »
That's interesting about your sciatica improving after some knee repair.
The chiropractors have been using a drop table maneuver on my SI joint as well as other more and less aggressive methods to try and get it moving better; all of which have resulted in more pain and no improved mobility. The last chiropractor, who really seemed to care and know his stuff, just shook his head and said, "that doesn't even make sense" when I recounted my injury and treatment history and he reviewed my MRI and xrays. He was confident something could be done but after 5 visits I was in worse pain than when we started, which has been the case for all the chiropractors (3).
So at this point I've just got to hope the neurosurgeons know what they're talking about. I'd like to think they do since the majority of their patients are the not-so-common problems that couldn't be resolved by more conservative treatment. I'm really hoping to wake up from surgery and have them tell me that once they got in there things looked much worse than the MRI indicated and that I must really be a fine upstanding American to have withstood the pain and discomfort in such an upstanding way and that everyone is sorry they doubted me and that here's a big bowl of your favorite ice cream and that you'll be back to running that sawmill by July. Maybe I'll write it down for them to be sure they get it right.
All joking aside, and this might be premature to write, but being a healthy guy my whole life this is the first time I've ever delved into our medical field. I've got to say that I've been very impressed with everyone I've dealt with; from the people at check-in to the surgeons and anesthesiologists and everyone in between. They've all been friendly, professional, and competent. They all seem to genuinely care about their career and patients. Same goes for the chiropractors.
Now that I hobble around I get asked a lot about what's wrong and also get to hear a lot of other peoples' experiences and I hear a lot of bad stories about incompetent doctors. I'm sure some of those complaints are well deserved but I'm relieved to find it out isn't the norm.
Alan
« Reply #75 on: March 13, 2019, 01:26:47 PM »
while asleep they will breath for you, when you wake up and want to hear all that, and eat the ice cream, remember to not hold your breath (i.e. don't hold your breath waiting!)  the best Dr.s technically, are sometimes not that friendly ( i.e. do not blow smoke up your asthma)  and the hard part is every person is a little different, and responds diff. to medications and procedures.  Your happiness with all involved so far says something about you as well, meaning you prob. have realistic expectations.  Just like working on complex machinery, you may think you know what is wrong, and confirm it with tests, and fix it and it still does not work.  You must also be somewhat patient, and you being healthy so far in your life means you worked your  bottom off and prob. pushed yourself to the limit.  not sure what good all this post does for you, but I had fun commenting!!!  I hope you find relief soon.  it is often the little things for a long time that wear us down.  My grandma used to say, "I am sick and tired of being sick and tired".  We can tolerate big pain for a short while, but it is the little ache that keeps you awake at night for years that can really drive you crazy and impact your life.  Best wishes sir.
« Reply #76 on: March 13, 2019, 01:35:46 PM »
my sciatica was from injuring the little muscle in my butt, the piriformis.  when it would get inflamed or swollen it put pressure across the nerve.  Pain in by butt and down my leg.  when my meniscus was hurting, i changed my gait to favor the knee, and it stressed my prev. injured piriformis. that is why diagnosis is so important.  If they work on your back, and that is not the prob., of course that will not improve your pain.  not all problems have a test to confirm, and then you are relying on the expertise, experience and ability of your doctor.
Offline alan gage
« Reply #77 on: March 13, 2019, 07:37:31 PM »
Of the two neurosurgeons I've seen one is in his mid-60's with a long distinguished career. He's friendly enough but I mainly deal with his assistant and rarely the Dr. himself. He's not unpleasant but is a little brusque. I can understand this and it doesn't really bother me but sometimes I worry that most of the things I say and that he says are going through a 3rd party (the assistant), which leaves room for miscommunication.
The other is probably in his early 50's and I've only ever dealt with him other than the initial nurse that takes my vitals. He sits in a relaxed posture wearing a cardigan over his white coat and listens to what I say in a patient manner (at least from outside appearances), answers my questions, and then asks if I have any more questions. The biggest reason I chose him for the surgery is because I feel more comfortable talking to him (and he also has a good resume).
I don't know if that's really the best way to pick a surgeon or not. The thought has occurred to me that I'd rather get fixed by a jerk than not get fixed by a nice guy.
I'm a mechanic by trade and I specialize in electrical/computer diagnostics. I recognize that even though I've dealt with this for a year with no results that we're working through a diagnostic process and that I haven't been responding the way these cases typically do. I was told in my first visit this wasn't a problem that should require surgery and that physical therapy ought to clear things up. Yet here I am a year later preparing for surgery after spending a few thousand dollars with no results. While I wish we could have just jumped to this point a year ago I also realize that would have been foolish without the benefit of hindsight. But I can see where some people would get frustrated along the way and give up on that doctor (or all doctors).
It's a 2 hour drive from here to the nearest specialty hospitals (Sioux Falls) and people often complain about taking the day off work and a 4 hour round trip just to talk to the doctor for 15 minutes. But I understand that it shouldn't necessarily matter to them what I went through to get there that day. If they can spend 15 minutes and determine the next step in the process then that's all that's needed. It's just all the sooner I can turn around and get home in my opinion. And I do appreciate that, when possible, they try to schedule an office visit and procedure the same day or else squeeze me in that same day for a procedure the doctor just ordered to save me a trip.
And I also know from personal experience, even though you shouldn't let it happen, that it's nearly impossible not to let a bad customer affect the level of service you give them. Just as it's hard not to go above and beyond for a customer who is respectful and patient. I'd rather do everything I can to have the doctor be 100% committed to me.
If you get a bunch of mechanics talking someone will compare ourselves to doctors. The ones that don't like doctors say the doctors have it easy because they can bury their mistakes. The ones that do like doctors know mechanics have it easier because the customer can drop off their inanimate object (car) which we can poke, prod, hammer, shock, and swear at all we want. Unless the patient is unconscious the doctor doesn't get those luxuries.
Alan
« Reply #78 on: March 13, 2019, 07:48:18 PM »
i assure you that a doc appreciates a good attitude and patience.  and we are sometimes pressured to do things that we think are not best, and with a aggressive pt and or family makes you wonder.  i should have guessed you might also be  a diagnostician.  Regards
the new guy is prob. great, the days of the Docs throwing a fit are over.  The young guy may have got more of the pt. satisfaction in his training.  sitting vs standing in surveys the pt thinks the doc was in the room 45% longer than if he stood!  some studies have actually shown higher mortality in pt.s who like there Dr.  go with the guy who listens!
Online Old Greenhorn
« Reply #79 on: March 13, 2019, 09:07:12 PM »
I concur with what @doc henderson said. He is on on the side most of us don't get to see clearly. I have had the opportunity to study this detail from several angles, as a patient who knows what is wrong and has to push for the care he needs, and as a patient advocate for my elderly parents for many years who were just treated as 'people getting ready to die' and made comfortable. I have also worked in E/D's for a bit and witnessed the pressures that some Doctors are under to ensure timely and proper treatment for many patients at once, some of whom are at critical points. If you've found someone who talks to YOU and listens, you have a solid relationship that you can work on.
if things get dicey, that is a Doctor you can work it out with and understand what is going on. The straight clinical guy who works through an assistant will be harder to deal with and get a feel good outcome.
 I have actually gotten to a point where I argued with a Doctor (loudly, but in a professional manner) about his diagnosis because I knew it was just wrong and had him call me on it by ordering further tests which proved he was, in fact, wrong, and was forced to prescribe the treatment I asked for in the first place. I hated being put in that position, he hated me for exposing his poor work,  but I would not let the patient suffer for the benefit of the Doctor having it easy. He has since retired. I wouldn't want to see anyone else have to do that. Most folks would not know how and would have suffered greatly in his care. Pick the guy you feel good about and give him your confidence. There are good mechanics, and not so good mechanics. Same in every trade.
 By the way Doc, I worked with one of those old school Doc's who had fits and threw stuff when I was doing clinicals. He scared me a LOT. I had a challenging case that night and asked the charge nurse if we could talk to the Doc about making an adjustment for a patient in pain. She told me to leave him alone and wait for the x-rays and MRI to come back and he (the Doc) would make a decision then. The patient's discomfort would not wait, so I asked again a while later and she said "fine, he's over there, why don't YOU go ask him?". So I did, he got really pithed at me but got up and checked on the patient, saw the issue as I did, and fixed it. At the end of the shift I apologized about the incident and he told me I should never apologize for advocating for a patient's well being. I never forgot that. He was gruff and mean, but he cared about his patients. What you see is not always what you get.
Oscar 328 Band Mill, Husky 450, 372 (Clone), Mule 3010, and too many hand tools. :) I mill for fun and my mental health. NYLT Certified.
I ain't the woodcutter, but I can cut wood 'til the woodcutter gets here.
Sciatic Nerve
Started by POSTON WIDEHEAD on Health and Safety
Last post December 30, 2016, 02:51:26 PM
by Clean Image
Self help for a pinched nerve?
Started by Old Greenhorn on Health and Safety
Last post April 29, 2019, 08:43:49 PM
by John Mc
Nerve Damage
Started by Ken on Health and Safety
Last post August 12, 2014, 09:17:55 PM
by Ken
Da nerve of some people
Started by chet on General Board
Last post July 27, 2004, 05:53:24 AM
by Bruce_A
