Author Topic: Bluecreeper Testament  (Read 768 times)
Offline Chuck White
  • Sawing Mobile since 2005
« on: April 27, 2018, 01:32:22 PM »
My usual use for Blue Creeper is applying a drop on each end of my tooth setters readout dial indicator rod every once in a while!
A couple of days ago, I had the blade guide motor off of my sawmill, checking for stretch in the chain!
While it was off I noticed that not only was the chain stretched, but the sprocket on the end of the motor was worn!
The sprocket and the roll-pin were severely rusted in place, I tried drifting the roll-pin out, but it just didn't want to move, so I applied a couple of drops of Bluecreeper at each end of the roll-pin and both sides of the little sprocket and repeated with the Bluecreeper again in the evening!
This morning I went out and the roll-pin just drifted out just like it was supposed to!
Then I went to my tool box and got my little battery clamp puller and clamped it onto the sprocket and against the shaft and the sprocket came off so easily that I could hardly believe it!
As long as Bluecreeper is available, I'll always have some on hand!  8)
~Chuck~
I LOVE MY SAWMILL
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
Re: Bluecreeper Testament
« Reply #1 on: April 27, 2018, 02:25:24 PM »
Thanks Chuck!
Glad you found Bluecreeper to be helpful!
Offline Chuck White
« Reply #2 on: April 27, 2018, 02:51:35 PM »
A friend of mine once asked me "What's in that, anyway"!
I replied BlueCreeper!   ;D
~Chuck~
I LOVE MY SAWMILL
Offline Chuck White
« Reply #3 on: August 24, 2018, 06:56:12 PM »
Used some again today!
I changed the "feed" chain and sprocket and shaft (upgrade), had a little trouble getting the power feed drive pulley off, added a couple drops to the shaft on both sides of the pulley and went to lunch!
Couple minutes messing with it when I got back out there and had it apart!
Still have about 3/4 of the bottle left!
Great stuff!  :)
~Chuck~
I LOVE MY SAWMILL
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: August 25, 2018, 09:37:37 AM »
Yup, it is just a natural reaction to reach for the Bluecreeper.  I did twice this week.  ;D
Offline tawilson
« Reply #5 on: August 25, 2018, 09:43:34 AM »
I picked up a bottle in Boonville. Haven't had a chance to use it or the pickaroon I bought at the same time. I'll be back at the mill and the shop next week after my house painting project so they'll be put to use then.
2017 LT40HDG35 WIDE
Another Bluecreeper Testament
Started by Weekend_Sawyer on Bluecreeper
Last post February 06, 2018, 03:32:10 PM
by Tam-i-am
Testament to Woodmizer!
Started by ChadH on Sawmills and Milling
Last post November 12, 2016, 05:40:01 PM
by red
Yet another use for Bluecreeper
Started by sweetjetskier on Bluecreeper
Last post September 06, 2013, 10:48:07 AM
by Tam-i-am
Bluecreeper
Started by Tam-i-am on General Board
Last post September 29, 2011, 02:04:08 PM
by SwampDonkey
