Author Topic: How is this possible, my saw started running backwards.  (Read 3106 times)
Online sawguy21
Re: How is this possible, my saw started running backwards.
« Reply #20 on: May 07, 2018, 11:35:28 PM »
I had an old GMC 7500 Dump truck, actually an old Wyoming State plow truck. Tandem Axle (44K) heavy front for the size of the truck (16K) and a 12 ft box. Two lift rams...and used it for spreading road base on the steep hills in the Colorado Foot Hills 15-20 years ago. The thing had an 5x4 two stick transmission setup and a 6v53T ear buster for a motor. Ran out of power going up a real steep hill. with the box part way up, too steep to spread down hill.... and next thing I know I'm headed backwards under power with all this smoke billowing out the front and all this noise! A real butt pucker moment to say the least..:) BUT I'm still here so the story had a good end. That truck eventually was sold at auction in Ft. Collins...it was green... LOL Had LOTS of memories in that thing. Ears still ringing too.
20 gears in reverse! WOW!! :D :D :D
Offline Don P
    • Calculator Index
« Reply #21 on: May 08, 2018, 07:50:22 AM »
Wheee :D
I was reading the manual for the Kubota yesterday and there was a short paragraph on what to do if it started in reverse. Basically, shut 'er down quick, it's going dry and can also ignite the air filter.
Offline Iwawoodwork
« Reply #22 on: May 08, 2018, 02:43:06 PM »
How about the Mercury outboards?  I had a white 4 cylinder, around 60-70 hp and it was a direct drive that ran backwards for reverse, was probably manufactured in the 1960's.
Offline weimedog
  • Better to be a "Has Been" than a "Never Been"!
« Reply #23 on: May 08, 2018, 11:38:27 PM »
Worked for this dairy out there, in the Longmont area..:) And they were into selling compost. We would use those trucks to haul the manure from cleaning pens up to this area where they would mix it up with top soil......and the sloppy stuff sometimes too out of their "pit". It was fun to up shift back wards and pop the gate / hit the brakes and watch in the mirror the splash....my newer trucks of that time didn't have that.....With the thirteen speed road rangers high range in reverse was too tall. ( County trucks I just retired from driving with their 18spds would let you get started in reverse, then go to high range.....we were heading backwards in those county trucks are close to 20mph...all summer long keeping up with the chippers and other stuff :) )
Husqvarna 365sp/372xpw Blend, 365/Huztl 52mm build (Cyclops),562xp "HTSS", 272XP, 61/272XP, 555, 257, 242, 238, 440e, Homelite 540, S-XL 925, XP-1020A, Super XL (Dad's saw); Jonsered 2094, Three 920's, CS-2172, 49sp, 621; Solo 603; 3 Huztl MS660's (2 54mm and 1 56mm)
Offline weimedog
« Reply #24 on: May 08, 2018, 11:42:03 PM »
Some of the old merc's were called "Dock busters" because they literally ran the motors in reverse vs. having a geared reverse in the lower units...:) Most were the in line 6's
Offline teakwood
  • Switzerland
« Reply #25 on: June 11, 2018, 08:47:07 AM »
:D  The clutch would likely not come loose unless you put a load on the chain. I once had a customer complain his new chain would not cut, it was on backwards. He realized that but wanted to cut with the top of the bar.
 oh man, that's a good one!!
Offline Hilltop366
« Reply #26 on: June 11, 2018, 12:00:47 PM »
Just tell him to put the chain on the regular way and flip the bar over.  ;D
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #27 on: June 11, 2018, 07:19:48 PM »
Had this happen to my Echo cs600p.
Had been running it a while then shut it off.
When I went to start it it back fired and then I had to pull several times to get it going.
I was bucking a White pine log and the thing wasn't cutting for crap.
Thats when I noticed the chain running backwards.
Shut it off and it took many pulls to get started again but then performed normally
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
353 Running Backwards
Started by David-L on Forestry and Logging
Last post April 16, 2015, 06:06:00 PM
by snowstorm
Bandmill running backwards?
Started by broker farmer on Sawmills and Milling
Last post November 23, 2005, 09:56:36 PM
by pigman
3 phase motor running backwards???
Started by LandfillLumber on Alternative methods and solutions
Last post June 28, 2009, 09:12:43 PM
by Ironwood
Doing it backwards.
Started by Dave Shepard on Chainsaws
Last post December 02, 2015, 02:08:53 PM
by sablatnic
