Author Topic: 391 cylinder  (Read 566 times)
Offline Zen3
391 cylinder
« on: April 29, 2018, 06:44:41 AM »
First post.
I have a ms311.  Bought it because it was a great deal. It seemed to be a little sluggish. I pulled the head. It looked ok. After reading about the 311 I found you can swap the 311 head and piston for a 391 head. I have been looking for the 391 kit.  Found some but my intake boot uses 3 bolts to attach to the intake. I did find a new one for 357. But thatís not gonna happen. Itís alot more then I paid for the saw. All the 391aftermarket heads I found have the circular intake. And uses a clamp. My question is. Does anyone know where I can find a 391 aftermarket head with the 3 bolt intake. Or someone said to convert the intake boot using a circular type with a clamp. If so can someone point me to the exact part needed. Lastly if I do convert this 311 to a 391 will the gains be significant. Thanks.
Offline Canadiana
  • I was new a while ago
Re: 391 cylinder
« Reply #1 on: April 29, 2018, 09:53:02 PM »
Ebay sellers when out of stock often add an extra 0 or other digit to the price so that no one will buy the part. It must be easier to keep their ad going that way. I would be interested in hearing about possible gains with a 311/391. Best of luck
The saw is more fun than the purpose of the wood... the forest is trembling 🌳
Offline Zen3
Re: 391 cylinder
« Reply #2 on: April 30, 2018, 07:20:51 AM »
Itís impossible to find the kit. A new 391 is 357 from Baileys. Just need to get the correct part toco vert the 3 bolt clamp boot. There are plenty of 391 heads with the O intake.
question
372 xp cylinder rub down ?
Started by micky boy on Chainsaws
Last post April 05, 2006, 05:43:00 PM
by snowshoveler
Flooded cylinder
Started by luvmexfood on Chainsaws
Last post November 08, 2014, 12:12:07 AM
by luvmexfood
Torque down a cylinder
Started by chillydog on Chainsaws
Last post December 06, 2013, 06:58:50 AM
by Al_Smith
Where to get a new hydraulic cylinder
Started by woodsteach on General Board
Last post July 13, 2012, 07:53:23 PM
by Clam77
