Author Topic: Husqvarna 372 throttle not closeing all the way  (Read 621 times)
Offline steele109
« on: May 01, 2018, 07:37:10 PM »
Hi I just rebuilt a husqvarna 372 from a junker I bought on fleebay. Lots of aftermarket parts on this saw including a tank handle.I finished up with gas and oil, it cranked on the third pull but it was idling between 5-6000 rpm (do you know how hard it is to try to adjust the carb on a modified 372 at that speed geez.)Well I adjusted and could not ever get it low enough to idle right.Finally looked real close and the throttle wasn't even touching the idle screw. You could push it down and it would idle down but as soon as you hit the throttle it would go right back up to 5-6. I finally put a lite spring on it to the base of the air filter holder which worked to get it adjusted. But I  would like a permanent solution to the problem I've looked for a stronger spring to put on the return but so far no good.Any ideas anyone?
Offline sawguy21
Re: Husqvarna 372 throttle not closeing all the way
« Reply #1 on: May 01, 2018, 09:31:32 PM »
Try loosening and retightening the throttle plate screw, the plate may not be centered in the bore.
Offline NCFarmboy
« Reply #2 on: May 01, 2018, 09:50:17 PM »
Agree w/ Sawguy21.
Shep
Lots & Lots of Saws
Offline steele109
« Reply #3 on: May 01, 2018, 10:26:15 PM »
Thank you did as you said and it works.Hopefully it will work tomorrow when I crank it.The stop is seating on the idle adjustment screw every time you pull the trigger. ;D now I need some more help( probably nerve pills lol)i'm rebuilding a 009 stihl. Thanks again steele109
Offline steele109
« Reply #4 on: May 02, 2018, 09:45:30 PM »
I would like to thank the two of you again.Finished tuning today and it ran great.Thanks
Offline sawguy21
« Reply #5 on: May 02, 2018, 10:05:02 PM »
 ;D You are very welcome, glad to help.
Throttle Adjustment ? 24 HP Kawi motor on my Husqvarna lawn tractor
Started by JOE.G on General Board
Last post July 14, 2012, 10:11:48 PM
by JOE.G
governor throttle lever, pushing throttle instead of pulling
Started by SCSawyer on Sawmills and Milling
Last post July 31, 2016, 09:23:05 AM
by mburrow
441 throttle cable
Started by yogi on Chainsaws
Last post March 30, 2013, 02:03:34 AM
by yogi
Remote throttle
Started by bandmiller2 on Sawmills and Milling
Last post November 01, 2008, 07:41:17 AM
by bandmiller2
