Those 3 fingers in the dust chute on the Woodmizer. . . .
Started by Just Right, May 02, 2018, 10:50:09 AM
Just Right
I am new here and want to say HAY!  Love this place as it is full of a wealth of knowledge and even a bit of humor!
Has anyone else thought about cutting those 3 fingers out of the dust chute of a Woodmizer?  I am sure they are there to catch a broken blade,  but they catch bark too and clog up the dust chute.  Or am I missing something.
Thanks.
If you are enjoying what you are doing,  is it still work?
Dave Shepard
Welcome to the Forum. It's been done. You have to assume the liability of doing so. I never allow anybody on that side of the mill when its running anyway. I've had bands come through the fingers anyway. Back when I had those fingers.
Just Right
Dave that is what I was thinking too.  I understand the safety aspect,  also ease of use is important too.  Thanks for the reply
pineywoods
Yeah, they are there to catch a broken blade, which will be traveling in the neighborhood of 60 mph. I saw a lot of cypress and cedar with stringy bark. My mill has the rubber sawdust hose replaced with a sheet metal duct leading to a sawdust blower. Have had broken blades punch a hole completely through the sheet metal.
SawyerTed
I've had vertical bandsaw blades break in the school shop (retired shop teacher) and at home.  When one breaks and comes out of the machine, you can't get away from it fast enough! The zone directly beside the shop bandsaw table is a no standing zone just like the chute area of the sawmill.  I'd hate to be standing/walking at the controls of a band sawmill and have one come out without being slowed down by those fingers.  Without those fingers, it would be far less predictable similar to a vertical bandsaw blade.  Imagine an wildcat with 158 inches of claws coming after you.
I think there was a photo posted in one of the threads where the blade broke and punctured the rubber chute and protruded 18" or so. And that was with the fingers in place.
Stephen
My mill has the fingers bent outward some. Don't clog with bark and chips too much, but still there to deflect a broken blade downward and slow it a little.
1994 WoodMizer LT40G18. 69 acres mixed wood. 1952 ford tractor, Norse 290 winch, studed Norse ice chains. 45-66DT Fiat.
Just Right
I like the modified version Stephen.  Helps but doesn't get rid of all the protection.
Piney I enjoyed your insight on the solar kiln.  What is the highest temps you have seen with your kiln?
Southside
I cut out two of the fingers as cedar was always plugging up my mill.  Once in a while when a band breaks it will come a couple of inches out of the steel, down into the rubber chute, but that is all.  Zero chance of it getting me.  Having a constantly plugged mill was a greater danger in my opinion.
White Oak Meadows
Just Right
Southside.   I like that too.  I farm so I can saw . . . . .and saw so I can farm . . . .lol  We do about 55 acres of horse hay.  What do you farm?
One of mine is broken off but it still does bad things with only 2.  I have had many blades break and a few escaped and exited via the sawdust chute.  This one decided to make it's own escape route.  Personally, I do not recommend removing the fingers.
Southside
White Oak Meadows
Southside
Magicman - interestingly I think the sawdust chute on our saws is different, yours seems to be directed more at the ground than mine.
White Oak Meadows
Just Right
Magicman,  Thanks for the pic.  That could do some damage.  I have a lot of family in MS.  Try to get that way a couple of times a year.
PAmizerman
I cut mine off long ago. I work alone and that side of the mill is 4' from the wall. I'm never on that side while the mill is running
Hydraulics everywhere
Woodmizer edger 26hp cat diesel
Traverse 6035 telehandler
Case 95xt skidloader
http://byrnemillwork.com/
WM bms250 sharpener
WM bmt250 setter
POSTON WIDEHEAD
Anyone who removes fingers may also be removing fingers, legs, bellies, pets and friends.  ;D
POSTON WIDEHEAD
Quote from: Magicman on May 02, 2018, 12:22:32 PM
One of mine is broken off .......
If you need one I'll be glad to give you a finger.  :D :D :D 8) 8) 8)
POSTON WIDEHEAD
Magicman, your pics looks like a blade vending machine.  :D
4x4American
Quote from: Southside logger on May 02, 2018, 12:28:30 PM
That was one of my complaints with the lt40, the sawdust chute was pointed right at the ground which made the sawdust go underneath the mill as it built up.  I took a c-clamp and clamped around the outside to hold it up more.  That is one of the many advantages of going to the 70, they have the sawdust chute at the perfect angle, it puts the sawdust far enuff away from the mill it makes shoveling alot easier.  It might seem silly but when you shovel 3-5 yards/day it makes it more better.  When I have the mill outside I just leave the chute up so I could just scoop it up with a machine
Boy, back in my day..
Dave Shepard
My LT40 seems to get the sawdust away from the mill.  :D I need to refilm this with Turbos.
LT40 Wireless - YouTube
Peter Drouin
I cut mine out, I'm going to fast for the blade to come out, It sticks in the log.
A&P saw Mill LLC.
License NH softwood grader.
petefrom bearswamp
Mine are long gone. NOBODY goes past he chute when the blade is engaged.
Kubota 900 RTV
Polaris 570 Sportsman ATV
57 acres of woodland
Just Right
There has been a lot of good insight.  I appreciate all the food for thought.  Thanks guys.
Chuck White
Just Right
Thanks Chuck.  I just can't get over how much good and useful info one can find here.
