Baltic Abrasives Technologies
Author Topic: Winch mounting options?  (Read 614 times)
Offline MilkTruckin
« on: May 02, 2018, 01:17:07 PM »
I am in the process of fixing up and modifying a car trailer to pickup and haul logs.  Im planning to make and mount a removable arch using rectangular steel tubing and stake pockets and possibly also a rear mounted pickup truck crane.
What im stuck on is what i should do about mounting the winch.  Im torn between permenently attaching a mounting plate to the tongue/deck or welding a hitch receiver tube to the tongue so i dont have to leave the winch out in the elements when not in use.
Offline Stuart Caruk
  • Gender: Female
  • Woodmizer LX450 DieselStationary timber processing
Re: Winch mounting options?
« Reply #1 on: May 02, 2018, 04:32:11 PM »
I still have the receiver tube on the front of my trailer. Used to think it was a great idea, although I rarely removed the winch from the trailer. Turns out that while I was having breakfast on a trip, someone else decided it was easy to remove as well. I vote for bolting the sucker down, welding the bolts so they have to be cut off, and building a cover for the winch.
Stuart Caruk
Wood-Mizer LX450 Diesel w/ debarker and home brewed extension, live log deck and outfeed rolls. Woodmizer twin blade edger, Barko 450 log loader, Clark 666 Grapple Skidder w/ 200' of mainline. Bobcats and forklifts.
Offline MilkTruckin
« Reply #2 on: May 02, 2018, 08:29:52 PM »
So basically I would  want to just get a big enough mounting plate to fit the winch  then use u-bolts to attach it to the 3 tongue beams?  Planning to use smittybilt 9500lb if that matters.
Offline mike_belben
  • Pulp Friction
« Reply #3 on: May 03, 2018, 11:24:59 AM »
I use reciever tube because i have many things i mount the winch on, but i use a 5/8 nylock nut threaded on pretty far.  It has prevented the hit and run dirtbags for a quick pin pull score when im just on the gas station or bank.  Extended periods it goes in the shed
Revelation 3:20
Winch mounting
Started by luvmexfood on Forestry and Logging
Last post June 22, 2013, 03:15:32 PM
by Sixacresand
Receiver hitch mounting cradle for Ramsey winch
Started by Delawhere Jack on Wanted
Last post December 28, 2012, 10:50:21 AM
by LaserZX
Mounting antlers
Started by isawlogs on The Outdoor Board
Last post January 17, 2006, 08:24:47 PM
by ellmoe
Husqvarna 435 bar mounting stud
Started by Bobsaw on Chainsaws
Last post April 02, 2015, 11:48:59 AM
by 346xp
