Author Topic: Limit switches  (Read 1524 times)
Offline revid
Limit switches
« on: May 03, 2018, 03:53:15 AM »
Any recommendations and or links for limit switches for a bandsaw mill?
Online LeeB
Re: Limit switches
« Reply #1 on: May 03, 2018, 05:37:53 AM »
What will they be use for?
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: Limit switches
« Reply #2 on: May 03, 2018, 08:34:38 AM »
I don't have any recommendations but I am also looking for something that will hold up to the weather. and sawdust.
I also need a rotary encoder.
Offline FloridaMike
Re: Limit switches
« Reply #3 on: May 03, 2018, 09:06:04 AM »
These are what I'm planning on using for saw head carriage travel stops at both ends of the track.  I like the spring arms, to prevent breakage when you come in a little too hot.
DAYTON Compact Limit Switch - 12T962|12T962 - Grainger!2966!10!8973609645!1102900018140&ef_id=Wk2HlAAABQF08-yQ:20180503125616:s
Mike
Offline William1961
  • BaaZinga
Re: Limit switches
« Reply #4 on: May 03, 2018, 05:33:16 PM »
Hello.
Do a search for a user named kbeitz.
I searched and found a lot of info as to how to wire limit switches.
And also how to install speed controls with reverse wiring diagrams.
I wish I could post the link as all I did was take screen shots and saved them.
Maybe this link.
wheelchair motor wiring for auto feed in Sawmills and Milling
But ask Kbeitz.
Offline William1961
  • BaaZinga
Offline revid
Re: Limit switches
« Reply #6 on: May 11, 2018, 07:31:52 AM »
I bought the plunger type of the same kind but one broke after only a few  touches . I have where it touches spring loaded so that it doesn’t hit to hard also. That one with the rod, Iam guessing it goes sideways to the travel? There’s also one with a wheel, would that one go sideways also or head on?
Offline Brad_S.
Re: Limit switches
« Reply #7 on: May 11, 2018, 10:44:44 AM »
My Timber Harvester uses Eaton/Cutler Hammer pre wired limit switch part E47BCC06
 The package calls it a compact limit switch with sealed pin plunger.
Offline revid
Re: Limit switches
« Reply #8 on: May 11, 2018, 10:56:40 AM »
Got a pic, link or model number
Offline Brad_S.
Re: Limit switches
« Reply #9 on: May 11, 2018, 06:10:59 PM »
Offline Ve7oab
  • Member*
  • Rancher, electrician
Re: Limit switches
« Reply #10 on: May 14, 2018, 12:35:50 PM »
Limit switches are available at electrical wholesalers. They can be explosion proof, water proof etc. Most have 2 sets of contact blocks, normally open or normally closed.
When used as end of travel, two switches are commonly used to provide safety. First switch is normal stop, next switch is emergency stop. Emergency stop are wired fail safe, it means switch carries current until condition of operation becomes false or not wanted. Attach a pull cord to activate it anywhere along saw. Ramp type metal actuators(flat bar)  are commonly added to activate switch slowly.   Sensor switches are also available. Search within these pages.
Electrical and Industrial Power Management Solutions | Eaton
WESCO International, Inc. | Home
sawing dogs and limit switches
Started by Jeff on Sawmills and Milling
Last post December 13, 2003, 08:49:32 AM
by Fla._Deadheader
On/off switches
Started by thurlow on General Board
Last post April 13, 2007, 04:59:56 PM
by Quartlow
drum switches
Started by deadeye on Sawmills and Milling
Last post March 30, 2006, 05:50:18 AM
by highpockets
Woodmizer switches
Started by bandmiller2 on Sawmills and Milling
Last post November 29, 2007, 10:25:10 AM
by sparks
