Author Topic: You folks made me do it!!  (Read 4837 times)
Offline 78NHTFY
  • I'm old!
Re: You folks made me do it!!
« Reply #20 on: May 11, 2018, 08:49:23 PM »
KyLogger--thanks for the heads up on the hydro, valuable info as I have some steep terrain.  Does that occur when the hydraulic fluid is full, or just low in the tank? Thanks. Coxy also mentioned the bolts holding the blade cradle on the frame.  Will make sure all is tight there.  All the best, Rob.
If you have time, you win.
Offline Grandpa
« Reply #21 on: May 12, 2018, 08:42:50 AM »
I wouldn't worry about the hydraulics. KYLogger must have had something wrong in his machine. I've been on steep ground where we had to pull one skidder up the hill with another skidder and never had a problem.
Offline Skeans1
« Reply #22 on: May 12, 2018, 11:11:33 AM »
Sounds like a pump issue or low hydraulic fluid level, we work up to 100% Ive never had a pump cavitate like KYLogger. These are going to have gear pumps which it can be pretty easy to do being theres no load sense itll be constant pressure.
Offline mike_belben
  • Pulp Friction
« Reply #23 on: May 12, 2018, 12:43:23 PM »
Check for clogged sump screen, delaminated/collapsed suction hose, worn out pump.  Is it a vane pump?  Look for witness marks of chatter in the cam ring and worn vane tips.  Hit the pump, tank and valve with an IR thermometer after a hard run and see if your max temps are getting too hot.  Boiling kills pumps.
Is there any chance that a relief bypass is rerouted right back into the pump suction line?  Thats a terrible yet kinda common design.  Relief flow should go through a cooler and back to tank.
Revelation 3:20
Offline Grandpa
« Reply #24 on: May 12, 2018, 07:48:03 PM »
This machine has a piston pump on the front of the engine. However, there is a gear pump in the transmission that lubes the transmission and is also a charge pump for the main pump. My guess is that there was a problem with the charge pump and it wouldn't pump that far uphill for some reason. The pickup tube for the charge pump goes to the right rear of the bottom of the transmission, so pointing uphill should make the oil supply nothing but better.
I think it's a moot point because it sounds like KYLogger sold the machine that had the problem.
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #25 on: May 12, 2018, 09:34:07 PM »
has any one ever owned or used the 340 jd skidder
I drove a 340D once it was a decent machine.  Basically just a 440c with no turbo its still bigger than a 440b I think.
Offline 78NHTFY
  • I'm old!
« Reply #26 on: May 14, 2018, 09:28:38 PM »
Helped my buddy at his shop with pulling what needs to be fixed.  Four hours to:
Pull steering/pump; remove brake/pump; remove both steering cylinders/brackets; remove trans cooler.  Everything sitting on the bench or on trays.  Cooler goes out to be reman'd.  Small frame crack get welded.  Buddy will reman steering/pump, brake/pump, one steering cylinder.  I'm good for scraping and cleaning years of crud.  When done, the hydraulic system should be tight!  Not pushing it time wise so 3-4 weeks to have it all back together.  8) 8)  Dug into the beast pretty deep so hopefull no big surprises going forward.  Here are the pics....
Offline dsroten
« Reply #27 on: May 15, 2018, 04:01:58 PM »
I'd be interested in seeing the guts of one of those steering cylinders.  I picked up an old 540a recently that has leaky cylinders (among other things), and am trying to decide if I want to monkey with them myself.
Thats a decent looking machine though, much cleaner than mine  ;D
Offline KyLogger
  • Loggin' for a livin'
« Reply #28 on: May 15, 2018, 08:12:10 PM »
Steering cylinders are a breeze to repack. And fairly accessable on those machines.
I only work old iron because I secretly have a love affair with my service truck!
Offline Skeans1
« Reply #29 on: May 15, 2018, 09:50:53 PM »
Something like this might make a good little log getter out of a 440
https://portland.craigslist.org/clc/hvo/d/john-deere-logging-esco-boom/6584900041.html
Offline teakwood
  • Switzerland
« Reply #30 on: May 27, 2018, 11:29:14 AM »
it's really not difficult to do the steering cyl on the 440/540s. i did mines all alone
Offline 78NHTFY
  • I'm old!
« Reply #31 on: June 17, 2018, 09:58:40 PM »
Everything is back together: no leaks, no errors!! 8)  I still knock on wood for luck--good things there's a lot around ;D.  Took 5 wks to get it back from the shop--most of the time was waiting for parts.  Spent the last few days scraping, sanding and painting: for a dub at painting, I think it came out alright!  Couldn't resist painting the "stinger" with a left over can of red paint (don't mean to offend any JD paint color purists out there....).  Still have to find 2 1/4" stencil letter/#'s for the JD 440-B on each side panel.  Will keep you posted on what I get done in the woods.  Here's a before and after pic
Offline g_man
« Reply #32 on: June 18, 2018, 07:47:08 AM »
Lookin good Rob - Nice job. Have fun in the woods.
gg
Offline teakwood
  • Switzerland
« Reply #33 on: June 18, 2018, 08:41:50 AM »
Wow. Nice job!! congrats
Offline AlexHart
« Reply #34 on: June 18, 2018, 08:55:04 AM »
Ahh memories.
1) Jiggle the wheel when you start it.
2) Do NOT winch in park.
3) Enjoy.
Offline cutterboy
  • Sometimes trees fall where they want to.
« Reply #35 on: June 18, 2018, 08:26:50 PM »
Rob, you did a really nice job. It looks great!
Offline Bruno of NH
« Reply #36 on: June 19, 2018, 04:18:35 PM »
Rob
Looks good :)
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline 78NHTFY
  • I'm old!
« Reply #37 on: June 19, 2018, 10:22:15 PM »
Thanks guys!
AlexHart--Am definitely enjoying it 8).  Twitched my first load today, some small blowdown. Winched in neutral, as you advised--why not in Park? (Am a newbie with a skidder so need all the help I can get).  And, what are these memories of which you speak?
All the best, Rob.
Offline 47sawdust
« Reply #38 on: June 20, 2018, 05:28:51 AM »
Don't scratch it now!
Looks really,nice.
Mick
Offline GRANITEstateMP
  • LIVE FREE OR DIE
« Reply #39 on: June 20, 2018, 11:30:47 AM »
That looks like CASE / IH red, should help keep that Deere goin'!!!  ;D
Looks good, enjoy!
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
1999 New Holland TC29
moved
MOVED: Best made double bit axe made in USA
Started by Jeff on Forestry and Logging
Last post May 17, 2016, 08:30:28 AM
by Jeff
Hello Folks
Started by Woodwalker on Sawmills and Milling
Last post December 22, 2005, 07:21:37 PM
by tnlogger
hey, folks!
Started by zopi on General Board
Last post June 30, 2012, 11:02:35 AM
by fishpharmer
you folks!!!
Started by twobears on General Board
Last post February 14, 2007, 12:01:18 AM
by LedlieLogs
