TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
Author Topic: MOST AMAZING TOOL EVER ......  (Read 2023 times)
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« on: May 06, 2018, 08:02:01 PM »
A while back when we were on a short trip I had to change a flat tire on my utility trailer along the road.  It was a real PIA to get the lug nuts loose with a regular tire iron.    Then, last week I had to fix a flat on my skid steer.  Removing the wheel was the worst part.    I near beat myself to death getting the lug nuts loose.   I ended up using a 18" breaker bar with a 4 foot pipe over the handle to get 2 of the nuts loose.    This week I had planned to replace all four tires on my 20 foot flat bed equipment trailer.   I ordered the tires online and they arrived late last week and with the recent memory of trying to remove the skid steer wheel I decided it was time to buy a new impact wrench.
I have an old Chinese air impact that is about worthless.   I don't think it EVER loosened a lug nut.   I had read some reviews on electric impact wrenches that sounded impressive.  Especially the corded ones.   They had lots of torque.    Then I thought about the convenience of a battery operated one so I started looking at them on line and reading lots of reviews.   I started out leaning toward the "yellow" one as I have lots of other yellow tools and they perform well.   But the reviews on the yellow one were not all that good, and it was close to $300.  :o     Several reviews I read were tool comparisons between brands and more than half of them identified the same tool as the #1 pick.   It was the Lowes Kobalt brand, 24 volt lithium ion battery powered one.  One review even said the measured torque was "well beyond" the advertised specification.  I found nothing bad written about that particular one so I decided to buy it.  And, it was $50 cheaper than the "yellow" one.
I put it on the charger last night and today I changed all four tires on the flatbed trailer using it.  I don't believe the tires had been removed in 5 or more years.  The nuts ands lugs were completely covered with rust.   The Kobalt spun off all 32 lug nuts (8 per wheel) without any effort.  It didn't even bog down.  Just unbelievable.  I didn't even break a sweat until I wrestled the tires onto the changing machine.    This tool is truly amazing.  I don't know why I never picked up one before.  Of all of the tools and gadgets I own, this one is probably the best one I have ever bought.  I may jack up the vehicles and take the wheels off and put them back on just to play with it.  ;D
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline moodnacreek
  • Sawin by the notches
Re: MOST AMAZING TOOL EVER ......
« Reply #1 on: May 06, 2018, 08:13:04 PM »
Use never seize on all steel threads as I have for over 50 years.
Offline submarinesailor
  • LT15 and a wife of 45 yrs
« Reply #2 on: May 06, 2018, 09:19:24 PM »
I TOTALLY agree.
Bruce
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #3 on: May 06, 2018, 09:22:30 PM »
   I don't have a battery powered one but several years ago I bought a corded electric impact wrench from HF and have asked the same question more times than I can remember and still don't know how I got along without it. Every time I change a trailer, ATV, truck tire or just take the blades off my mower to sharpen I repeat it. I first used my son's to remove my electric PTO on my mower simply to replace the drive belt. I could not spin the nut fast enough with a socket wrench but it was a piece of cake with the electric impact wrench.
   Congrats on the new tool. I am sure you will have many years of happy service with it.
Offline barbender
« Reply #4 on: May 06, 2018, 09:35:26 PM »
I have a cordless Dewalt 18v impact. Pretty darn handy, it has removed every automotive tire and trailer tire I ever put it on, it even removes the lugs on my skidder once I figured out they were left handed threads😁 The new brushless lithium ion Dewalt and Milwaukee impacts are rated at about 3 times the torque of my old 18 volt. I'll upgrade to one someday. I don't know of any cordedi mpact that can match the torque of the brushless, cordless ones.
Offline Southside logger
« Reply #5 on: May 06, 2018, 09:50:23 PM »
I have one of the DeWalt 20V brushless heavy duty ones, there have two versions of the 1/2" impact, it was expensive, but man alive - it will knock all 20 lugs off of two tires on my Franklin skidder and put them back on with a single battery, it's rated for something like 1,000 ft/lbs of breakout torque.
Woodmizer LT35 sawmill, KD250 kiln, BMS 250 sharpener and setter
Offline jwilly3879
« Reply #6 on: May 06, 2018, 09:52:49 PM »
I have an 18v Bosch that is great.
Offline coalsmok
« Reply #7 on: May 06, 2018, 10:12:09 PM »
Use them almost daily now at work. They have went along way towards replacing the air impacts for most jobs there. Less stress on our ears from noise of a truck or air compressor running and also no high pitched whine of the air gun
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #8 on: May 06, 2018, 11:04:49 PM »
I've got an 18v Milwaukee Fuel that's rated at 1,100 lbs of torque.  It'll pull the threads off a 3/4" bolt/nut.  The new ones are rated @ 1,400 lbs.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #9 on: May 07, 2018, 10:59:31 AM »
 I've got the Gen 1 M18, it's awsome. A friend has the Gen 2. He was breaking bolts putting cutting edges on snow plows this winter.
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
« Reply #10 on: May 08, 2018, 07:52:01 AM »
seems like cordless is the wave of the future.
I havent had my old corded Makita drill off the shelf in probably 10 yrs.
cordless chain saw at the mill is a godsend as well as a leaf blower.
Only change tires in my shop so my IR thunder gun does the trick.
Do wish the batteries weren't so expensive tho
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Raider Bill
  • Who will pull the wagon when everyone rides?
« Reply #11 on: May 08, 2018, 08:23:59 AM »
Pete, Check online. I bought 2 dewalt clone batteries for $49 a pair.
The First 60 years of childhood is always the hardest.
Offline gspren
« Reply #12 on: May 08, 2018, 08:42:09 AM »
I am going to "need" to get a cordless impact before my next RV trip and I could see that even at home it would nearly replace my air tool. The only recent use of a corded drill was when making a fishing rod rack I needed to use a 1 3/4" hole saw for 16 holes through 3/4" pine.
Offline Sixacresand
  • John and Nancy
« Reply #13 on: May 10, 2018, 08:25:07 PM »
The only time I ever called AAA for a flat was because I could not loosen the lugs with the truck lug wrench.
« Reply #14 on: May 11, 2018, 08:10:39 AM »
Raider were they 40V?
LT40SHDD51
Kubota 900 RTV
Offline Raider Bill
« Reply #15 on: May 11, 2018, 09:19:06 AM »
No but I believe 40v a/m are available.
Offline mike_belben
  • Pulp Friction
« Reply #16 on: May 13, 2018, 12:12:42 AM »
The milwaukee fuel 18v cordless 1/2 impact i bought my dad a few years ago for maybe $199 or so smokes my $600 snapon CT3850HO.
Milwaukee makes an 18volt 3/4 impact too.  If i ever get another itll be that.  Those ball and socket budds arent getting any easier to change with age. Nor is my 1" air impact a picnic to lug around.
Revelation 3:20
    • My homepage
« Reply #17 on: May 13, 2018, 12:06:28 PM »
The first gen M18 2763 Fuel beats all the others. The second gen M18 2767 beats the first gen. ;D The 2767 is more powerful than the 3/4" model, at present.
Offline trapper
« Reply #18 on: May 13, 2018, 10:54:48 PM »
what 18 volt fuel drill is the one to get
stihl ms241cm ms290  echo 310 400 suzuki  log arch made by stepson several Logrite tools woodmizer LT30
« Reply #19 on: May 14, 2018, 12:15:09 AM »
That Gen 2 appears to be a monster.  I would like to see some real world comparison to that beast vs the Dewalt.  Can't understand how they get 40% more torque out of a lower voltage battery.
An amazing tool I recently bought
Started by Percy on Sawmills and Milling
Last post November 19, 2017, 07:20:00 PM
by SlowJoeCrow
Tractor 3pt Multi-tool - And Another Log Handling Tool Added
Started by tcsmpsi on General Board
Last post February 08, 2007, 07:18:52 PM
by SPIKER
AMAZING !
Started by POSTON WIDEHEAD on General Woodworking
Last post February 27, 2013, 02:17:05 PM
by ljohnsaw
My Pop!..Amazing.
Started by POSTON WIDEHEAD on General Board
Last post December 15, 2013, 08:55:48 AM
by thecfarm
