Author Topic: Franklin 170 winch and park brake  (Read 325 times)
Offline just farming
« on: May 06, 2018, 08:32:14 PM »
Need help with #32 winch on my 170. The machine has set for at least 5 years and the winch hasn't be used for longer than that. The problem is in free spool. With the control in the free spool it tries to spool in. Not at full power but enough resistance that you aren't going to pull the line out by hand. I tried tying the cable off and use the machine to pull the cable out several times, it might have helped a little but its still not usable.
I broke the hydraulic fittings loose at the winch to bleed any trapped air, that didn't help either. I checked the hydraulic pressure at the winch and it seems low to me. One line was 200 psi and the other was 400 psi.
Another problem is the machine park brake. Where is it located on the machine and what actuates it? Any and all help, ideas and suggestions are greatly appreciated.
Cat 311
JD 550G
ASV RC50
Mack Superliner RW613 Dump
Kubota M9000 4X4
Kubota L3430 4X4
 Deutz-Fahr Agroplus 87 4X4
Offline Gary Davis
Re: Franklin 170 winch and park brake
« Reply #1 on: May 06, 2018, 11:01:50 PM »
sounds like the clutch is dragging  not fully releaced
Offline JesseA
« Reply #2 on: May 07, 2018, 12:37:02 PM »
All the older franklins Iíve seen had a mechanical disk mounted on the front driveshaft, the parking brake was a latch that caught the brake pedal when you depressed it.
parking brake cable for franklin skidder
Started by lynde37avery on Forestry and Logging
Last post April 25, 2014, 08:02:51 PM
by lynde37avery
winch brake band
Started by teakwood on Forestry and Logging
Last post August 05, 2015, 07:46:24 PM
by Maine logger88
winch brake bands
Started by MICKEY108 on Forestry and Logging
Last post April 01, 2015, 08:32:37 PM
by coxy
hercules winch brake cylinder
Started by redneck on Forestry and Logging
Last post May 23, 2013, 08:28:44 PM
by redneck
