Arborwear
Author Topic: Stihl 460  (Read 287 times)
Offline sawwood
Stihl 460
« on: May 06, 2018, 09:46:56 PM »
I just bought a used Stihl 460 to go on our chainsaw mill. We will be running a 36" bar and ripping chain. Do I need to add a little more
oil to the mix as I will be milling large oak logs in the 28 to 32" size. Also what type of oil do you guys recommend and should I buy alcohol
free gas to run in it ?
Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Offline TIDE-HSV
Re: Stihl 460
« Reply #1 on: May 07, 2018, 12:35:41 AM »
I'm sure I'm just O/C (and old), but I use Stihl oil with my Stihls (3) and Husky oil with my 372xp. I'm sure I could interchange with no problem. However, on the no-ethanol issue, I don't think I'm O/C. Nothing but pure gas for me. I'm not sure what the absolute limit is for alcohol sitting in a small engine is before it ruins the seals, but I've found it several times...
“I would rather live my life as if there is a god and die to find out there isn't, than live my life as if there isn't and die to find out there is.” Albert Camus
Offline Texas-Jim
Re: Stihl 460
« Reply #2 on: May 08, 2018, 12:15:46 PM »
If you have a source for ethanol free use it, even if it didnt hurt seals it has less stored energy than gas.
What we do in life echoes through eternity.
Does Stihl have a different mount size at the studs for bigger and smaller Stihl
Started by quietrangr on Chainsaws
Last post October 09, 2011, 08:25:11 AM
by Al_Smith
Mounting Cannon S2 (big Stihl) 42" bar on MS661 (small Stihl)
Started by neildorin on Chainsaws
Last post September 11, 2017, 06:01:44 AM
by Al_Smith
What's the Dolmar equivalent of Stihl 260, and Stihl 362
Started by DebarKing on Chainsaws
Last post January 23, 2012, 11:48:37 PM
by MOwoodchopper
Trading in a Stihl saw to a Stihl dealer?
Started by gus1957 on Chainsaws
Last post January 01, 2008, 11:42:12 PM
by sawguy21
