Author Topic: Oliver oc4?  (Read 1121 times)
Offline gman98
Oliver oc4?
« on: May 07, 2018, 03:37:42 PM »
Hello guys.  So I have an opportunity to get an old Oliver oc4 dozer with a carco c3 winch for free.  Itís a late 50ís model I believe.  It has been sitting since the late 80ís early 90ís.  It ran when it was parked.  Iím looking to cut some wood with it.  Not planning on supporting myself with it, just looking to log some private lots on the weekends as a hobby and some extra income.  What are you guys inputs on these dozers?  What are some key issues to look for when getting it back running?
Stihl 362 c-m
Husqvarna 562xp
Husqvarna 359
Husqvarna 353
Husqvarna 61
Husqvarna 245rx thinning saw
Offline mike_belben
  • Pulp Friction
Re: Oliver oc4?
« Reply #1 on: May 07, 2018, 03:44:16 PM »
Have seen quite a few chevy 350 conversions into olivers on CL over the years.  Is it on tracks or tires?
Either way itll be about 3x better than a skid steer in the woods.  Probably about 1/3 as good as a skidder.  Good for what you want to do, if youve got the capability to deal with retrofitting and reworking around obsolete parts.
Revelation 3:20
Offline gman98
Re: Oliver oc4?
« Reply #2 on: May 07, 2018, 04:06:13 PM »
Itís on tracks.  Iím no mechanic or fabricator by any means, but it will be a good piece to learn on.  It was a family owned machine.  My grandfather used it to yard spruce logs to build log cabins and to build roads into the camps he built.
Stihl 362 c-m
Husqvarna 562xp
Husqvarna 359
Husqvarna 353
Husqvarna 61
Offline luvmexfood
Re: Oliver oc4?
« Reply #3 on: May 07, 2018, 05:40:27 PM »
Go for it. Nothing ventured nothing gained. Just watch the Washington's you have to put in it. You know you can always get your initial investment back in parting it out if you had to and help restore a part of history.
Give me a new saw chain and I can find you a rock in a heartbeat.
Offline maple flats
  • Life is what you make it!
Re: Oliver oc4?
« Reply #4 on: May 08, 2018, 03:35:12 PM »
It should be 19 engine HP, but the horses were bigger back then. We had an Oliver OC3 when I was growing up, with a FEL on it. That was 22 HP. It worked well, but was on the light side. The tracks were no match if there was ice on the ground.
Offline KyLogger
  • Loggin' for a livin'
Re: Oliver oc4?
« Reply #5 on: May 10, 2018, 07:36:02 PM »
Typically the older the machine the simpler to work on. Especially a small tractor like that. Parts availability will be an issue I would guess. I don't know much about the Oliver tracked machines, but a lot of the old construction/forestry equipment made by tractor companies used ag parts a lot. I would watch the U/C, putting an undercarriage on a tracked machine can get pricey in a hurry! Like good rubber on a skidder you could easily double the machine price. All that being said, if you are handy with tools and have a halfway decent shop, go for it! I would check out yesterdaystractor.com There is a wealth of knowledge over on that site. Good luck!
I only work old iron because I secretly have a love affair with my service truck!
Offline gspren
Re: Oliver oc4?
« Reply #6 on: May 10, 2018, 09:06:18 PM »
Try Zimmermans at www.olivercletrac.com
Offline Skip
  • Saw hard or stay home.
Re: Oliver oc4?
« Reply #7 on: May 11, 2018, 07:11:39 AM »
You can get parts at Zimmerman Oliver Cletrac in Ephrata PA 1-717 -738-2573
Offline Remle
Re: Oliver oc4?
« Reply #8 on: May 12, 2018, 01:01:42 PM »
For information go to " Oliver Tractor Data ", they are sorted by model #. Just click on the OC 4 at the bottom of the page.
Oliver
Started by mburrow on Sawmills and Milling
Last post April 26, 2015, 11:20:56 PM
by mulerider
Oliver Moulder
Started by Sawmill_Nick on Drying and Processing
Last post November 03, 2010, 07:04:24 PM
by Sawmill_Nick
Oliver oc3 crawler
Started by Firewoodjoe on Forestry and Logging
Last post November 23, 2014, 12:17:03 PM
by Firewoodjoe
1265 Oliver
Started by Skip on For Sale
Last post June 14, 2016, 08:55:36 AM
by Skip
