AVAILABLE
Author Topic: ID? Several of these in woods behind my house. Check out the leaf projections...  (Read 2018 times)
Offline bobznew
In north-central Georgia.  1000' elevation.  Woods behind my house.  Several of these trees. Last leaf image shows some strange growth-like projections from the tops of the leaves.
Any ideas on species?  And what is that growth?
Offline LeeB
Looks like elm to me.
Offline bobznew
Just plain American Elm?
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
Is the top of the leaf rough like sandpaper or smooth?  If rough, it is winged elm.  American elm is smooth.
Offline caveman
  • In the land of the blind the one eyed man is king
If I had to choose based on the pictures, I would lean towards winged elm for a few reasons, the leaf texture as WDH mentioned, the really short petioles, and the width of the leaves compared to their leaves' length.  Most of the time, the American elms are a bit wider across the middle than winged elm leaves of the same length.
Caveman
Offline Don P
    • Calculator Index
Leaf galls.
our elm leaves tend to look more woppyjawed than those at the base.
Offline WDH
Woppyjawed.  That is a new botanical term that I have not used :D.
It is almost certainly winged elm.
Offline Don P
    • Calculator Index
Yeah, I may have misspelled that  ;D
Have you heard that tree called a wahoo?
Offline WDH
Yes.  Euonymus atropurpureus.  I have never seen it, though.
Offline bluthum
  • Tick magnet.
The way I learned it slippery elm [U. rubra] is always rough on the upper leaf surface [also uneven at the leaf base] and U. americana can be either hairy or  not hairy. U. americana leaves are  always even at the base.
Winged elm U. alata] and water elm [not even an Ulmus]  leaves leaves are narrow, more lanceolate than the bigger elms.
If that tree were in my stomping grounds I'd call it a winged elm    although in early growth stage the leaf width can be a fooler. It seems like faster growing winged elms have less obvious corky growth on the small limbs but that's a rare problem here in the Ozarks.
They can be a mean little weed tree and some 1" in diameter can have 30 annular rings. I poked one of the stout little twigs on one I had girdled well into my eye once but you gotta love antibiotics sometimes.
The more common local name here is uh, something like "urine elm" though not exactly.
Offline WDH
There is also cedar elm that grows in parts of Arkansas, Louisiana, and East Texas.  Ulmus crassifolia. Very closely related to winged elm.
Offline bluthum
  • Tick magnet.
In Arkansas that one is limited to [mostly] the south east part of the state and doesn't grow in the mountainous parts.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
I've read that the American elm was the only Elm with alternating light/dark layers in the bark.  I can confirm that Slippery Elm does not have this pattern in the bark (or not as pronounced), but not sure about Winged etc. Elm.
Any input from the resident gurus on this?
Offline WDH
Yes, that is correct.  Called striations in the rhytidome .  I get in trouble for using big words, but this time it is your fault, TKehl.  You set me up for it :)
Offline Don P
    • Calculator Index
I'm still coming to grips with wahoo and hearts a bustin being the same or kissing cousins and here we are whipping somebody in a stadium. Do tell, what is the rhytidome?
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
He could have just said that it was bark.....but he didn't.  :D
Offline WDH
I told you that it was TKehl's fault.  He started the whole mess.
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
Not familiar with winged Elm, only Red (slippery) and american.
Havent heard of Wahoo
Red elm split pretty easily, not so American.
elm that smelled like a certain bodily liquid was american in my area growing up but is very scarce now.
The is a huge one about 7 miles from me on a client's property about 60" in diameter but I havent checked on it in about 2 yrs to see if is still among the living.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline bluthum
  • Tick magnet.
Yeah but funnin' aside this thread gives one perfect example of why big words work. The name wahoo is commonly used for 2 totally different woody plants that grow sometimes near each other. They each also have many other common names. Total confusion.
But Ulmus alata is the same plant every time. Ditto Euonymus atropurpureus, even if it is hard to spell.
Offline WDH
You are spot on, Sir.
Climate Projections for Michigan Tree Species
Started by Ron Scott on Forest Education
Last post November 19, 2015, 10:29:41 AM
by mesquite buckeye
Before Pulling Your Mill....Check and Re-Check!
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 09, 2018, 01:44:17 AM
by Ianab
question
Heating a hoop house/green house.
Started by pinebugsrus on Firewood and Wood Heating
Last post June 03, 2012, 08:21:44 PM
by pinebugsrus
leaf id's
Started by Dave H. on Tree, Plant and Wood I.D.
Last post September 26, 2016, 10:10:40 PM
by WDH
