Author Topic: Husky 576 xp muffler mod  (Read 516 times)
Offline tripg1968
« on: May 08, 2018, 09:58:34 PM »
I recently purchased a 576 xpg and noticed that it really runs hot compared to my older saws. Started poking around on the net and read about several people adding outlets to the muffler to get rid of some of the heat and maybe ad power. I added one outlet and also drilled 4 holes into the bottom of the baffle inside. Ran the saw and found out two things right away: its louder and its revving higher. I tried to add fuel and found out something else: the carb screws only back out so far and they stop. Has anyone on here run into this? What can be done? With a little richer mix I think this saw would run perfectly. Blame it on the epa i guess.....
Offline Canadiana
  • I was new a while ago
Re: Husky 576 xp muffler mod
« Reply #1 on: May 10, 2018, 01:55:42 AM »
The carb is only partially adjustable until the limiting caps are removed. They are usually red plastic and can be removed with deep threaded dry wall screws and a hook tool. Removal voids warranty. So does a muffler mod Retuning properly is VERY important. Improperly tuned saws can achieve greater power and higher temps that ruin the engine. i put a bigger hole in my 570at and got some more power, increased fuel consumption but didn't notice an increase in volume. It's not a speed demon but it is comfortable in 24" softwood. I would like to see how it does with a longer bar.
The saw is more fun than the purpose of the wood... the forest is trembling 🌳
Offline Skeans1
« Reply #2 on: May 10, 2018, 07:54:01 AM »
When I did hand falling all the time one of the first thing we always did was triple port the mufflers for running well it wasn’t fire season. Make sure you guys add some screen over the new ports you’ve added as well.
Offline tripg1968
« Reply #3 on: May 10, 2018, 08:58:02 PM »
Took the top cover off my saw tonight and found two little brass pins that act as stops for the hi and lo screws. tapped them out with a small punch and hammer and thought I had it made. Wrong! The screws still only back out 1 turn each. This saw is a 2013 husqvarna 576 xpg. There are no caps over the screws. I think thats on Stihl saws. The 2nd port I added is an outlet off of an old 272xp muffler complete wth the factory screen. I welded it in on the front of the muffler.
Husky 51 Muffler Mod
Started by icornmfire on Chainsaws
Last post March 20, 2012, 09:08:19 PM
by icornmfire
Muffler Deflectors for Husky 272/288 ???
Started by rahtreelimbs on Wanted
Last post December 20, 2005, 05:19:23 PM
by rahtreelimbs
Modded muffler on Husky 455
Started by Woodcutter_Mo on Chainsaws
Last post August 15, 2017, 10:04:57 AM
by Woodcutter_Mo
Husky Prestique 61 (1980) Vs Husky 562XP
Started by Mikeinkaty on Chainsaws
Last post June 13, 2016, 06:09:49 AM
by SawTroll
