Author Topic: Is yours like mine....try it.  (Read 1748 times)
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« on: May 09, 2018, 08:58:43 PM »
You see the shiny screw that holds the forward reverse handle on?
After my mill warms up and I've been sawing for a while, me or anybody can hold their finger on it no more than 8 seconds.....if you do it will burn your finger like fire.
I just happen to have my finger on it while sawing some Black Oak yesterday and I suddenly jerked my hand back thinking I had been stung by a bee....I mean it hurt!
Got to touching it and it was hot as fire. not sure why but gonna take the face off tomorrow and see what's touching it...if anything.
Touch yours and see if its hot. Could be just the Wideheads or could be just mine but I'm gonna find out.  ::)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: Is yours like mine....try it.
« Reply #1 on: May 09, 2018, 09:19:51 PM »
You stick your finger hoof in some strange places.  :o
« Reply #2 on: May 09, 2018, 09:32:26 PM »
And sometimes I get burnt!  :D
Offline Sixacresand
  • John and Nancy
« Reply #3 on: May 09, 2018, 09:37:27 PM »
Wonder what's going on?  I'm going to touch mine tomorrow.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #4 on: May 09, 2018, 09:38:54 PM »
Maybe a wire arcing on the switch.
A&P saw Mill LLC.
License NH softwood grader.
« Reply #5 on: May 09, 2018, 09:42:30 PM »
I thought about that. i'll find out.
« Reply #6 on: May 09, 2018, 09:43:15 PM »
Run it for a while then touch it.
Offline Jack S
« Reply #7 on: May 09, 2018, 10:43:23 PM »
if its a switch probably loose wire or contacts not making a good connection.
Offline DPatton
    • D & S Sawmill Services
« Reply #8 on: May 09, 2018, 11:02:07 PM »
:D :D :D  Good thing he didnít put his tongue on it huh? ;D
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline highleadtimber16
  • Learning Everyday
« Reply #9 on: May 10, 2018, 12:28:22 AM »
Your drum switches most likely need electric grease. Take your front cover off and you will see when you engage the switch it sparks. Or in your case starts welding  :D
There should be a little cup of grease in the side cover of your control station.
2011 Wood-Mizer LT 40 hyd w/ 12' Extension, Patrick Model A Loader, 75 Hitachi, Stihl 461, 2X066, & ms 192
Cutting Old Growth Cedar from Queen Charlotte Islands.
Offline WLC
« Reply #10 on: May 10, 2018, 01:03:46 AM »
Sounds like you came up with a new use for a widehead, BBQing goat. ;D
Woodmizer LT28
Branson 4wd tractor
Stihl chainsaws
Elbow grease.
Online Chuck White
  • Sawing Mobile since 2005
« Reply #11 on: May 10, 2018, 07:39:34 AM »
The drum switch fingers not making good contact in the feed position!
~Chuck~
I LOVE MY SAWMILL
Offline Sixacresand
  • John and Nancy
« Reply #12 on: May 10, 2018, 07:37:11 PM »
My switch screw did not get hot.
« Reply #13 on: May 10, 2018, 09:11:44 PM »
I did not saw today as I was working on my dump trucks HD Cylinder.
But I did take the face off the control panel.
126 hours on my mill and I hate to say it but not a lick of grease on any of the drum switches where it makes connection.
All wires looked secure. Just no grease and it would make a grinding when using the forward reverse feed lever.
I put a film of grease on all the switches and will test to tomorrow.
Offline Southside logger
« Reply #14 on: May 10, 2018, 10:35:43 PM »
I suspect it has to do with the whole sticker holding in place, non factory, aftermarket, modification that mill has seen to pimp it up.   :D
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #15 on: May 11, 2018, 08:09:04 AM »
Reminds me that it is time for me to grease the drum switches.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline Sixacresand
  • John and Nancy
« Reply #16 on: May 11, 2018, 08:34:48 AM »
Good Idea.  Thanks, too, to the Forum and folks like PostonWideHead for making us aware of stuff going on with our mills.
Offline Crossroads
  • letís make some sawdust
    • Kevin Bales faith family farm and portable sawmill
« Reply #17 on: May 11, 2018, 12:58:22 PM »
I guess at 153 hrs, mine is ready too. Thanks goat, Iíve been going to grease them, but seem to forget about the time I turn the key on 🙈
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins
« Reply #18 on: May 11, 2018, 07:28:07 PM »
Well I'll be.....after greasing the contact points I ran the mill all day on Hard Maple.
My screw was as cool as a Cucumber.  8)
Oh what a little grease will do.  :)
Still Mine
Started by thechknhwk on General Board
Last post November 30, 2014, 08:57:34 PM
by terrifictimbersllc
Nice but not mine
Started by TreeWinder on General Woodworking
Last post October 28, 2012, 06:29:42 PM
by TreeWinder
Mine Cart.
Started by old3dogg on General Board
Last post April 25, 2004, 03:54:49 AM
by Fla._Deadheader
smiley
If this was mine , I would be dam proud of her !!!
Started by isawlogs on General Board
Last post May 22, 2011, 01:07:03 AM
by jamesamd
