Arborwear
Author Topic: Munkfors bands  (Read 1012 times)
Offline tacks Y
Munkfors bands
« on: May 11, 2018, 09:06:21 AM »
Any one here running these? That is what came with my used Logmaster so I am thinking that is what  Logmaster sold. They where 10 degree but I have been sharpening to 7 and they work well. Time to buy some new bands thinking Kasco or another brand.   At 19' 1" they are not small. Thanks
Offline LeeB
Re: Munkfors bands
« Reply #1 on: May 11, 2018, 09:37:23 AM »
They were a popular blade with some of the guys a while back but haven't heard much about them lately. I tried a few and didn't find them to be any better than the WM blades I had been using. I switched back to WM after that and never tried them again. I bought a box of Kasco 7 blades a few months back but have not yet used up my WM blades I have left, so can't give any insight into the Kascos as of now.
Offline Brad_S.
Re: Munkfors bands
« Reply #2 on: May 11, 2018, 10:40:02 AM »
 They were the best out of the box cutting blade that I ever used. The finish from the factory on a milled board was phenomenal. After the factory edge and set wore off, they werent any different than any other blade. I get maximum blade life with Simmons blades so I went back to Simons after the monkeys broke.
Offline slider
  • sawyer,trucker,tree service
Re: Munkfors bands
« Reply #3 on: May 11, 2018, 04:42:55 PM »
I don,t saw every day but i have been sawing for years using double hard blades from wm which have served me well. For the last 2 years i have been using kasco blades from cutting edge a kasco dealer and forum member. I still buy all my parts from woodmizer because they have treated me well for years.
I chose to go with cutting edge because he sells a good product and has helped me many times .He is also a one man show supporting his family from his small business .
al glenn
Offline Pabene
Re: Munkfors bands
« Reply #4 on: May 12, 2018, 01:53:09 PM »
We have used Munkfors blades sins 2005. IMO its among the best blades on the market.
We have a card bounded to each blade to keep track what is going on, from the first cut to its end of live. That way I have recorded 28 resharp procedures  and  cut about 100 logs for one blade. All setting and resharpenings is made by or self.
Offline tacks Y
Re: Munkfors bands
« Reply #5 on: May 13, 2018, 09:02:41 AM »
Thanks guys. I think Logmaster must have sold them with their mills. I need to buy more bands and thinking of a direction to go.
Offline gmmills
Re: Munkfors bands
« Reply #6 on: May 13, 2018, 10:15:36 PM »
If you are considering Kasco blades I second what Slider said. Contact member Cutting Edge he can get you the blade profile you need. I have been buying my Kasco blades from him for a number of years now. You will be treated right.
Custom sawing full-time since 2000.
WM LT70D62 Remote with Accuset
Sawing since 1995
Offline Skip
  • Saw hard or stay home.
Re: Munkfors bands
« Reply #7 on: May 14, 2018, 07:51:17 AM »
I have been using them since 05 Good Swedish steel .Stay sharp longer than the others I,ve tried.
Offline MrMoo
  • Do you have a spare log dar
Re: Munkfors bands
« Reply #8 on: May 14, 2018, 04:41:53 PM »
I use Munkforsagers on my Logmaster. I like them. I also like them because the tooth profile pretty closely matches the cam on my sharpener.
Offline EZ
  • Betya can't cut just one!
Re: Munkfors bands
« Reply #9 on: May 17, 2018, 07:33:19 AM »
Been running them since i started milling. Tried other brands and always went back to the monkeys. EZ
Offline JB Griffin
Re: Munkfors bands
« Reply #10 on: May 18, 2018, 10:08:10 AM »
Log Master sold Daikin Flathers blades.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
new Munkfors blades, 11' long
Started by Okrafarmer on For Sale
Last post March 20, 2013, 07:15:10 PM
by Okrafarmer
Sharpening Munkfors blades
Started by 3Dog on Sawmills and Milling
Last post December 07, 2011, 11:34:52 PM
by gmmills
How many bands
Started by Inwoodsman on Sawmills and Milling
Last post October 03, 2014, 12:39:14 PM
by gimpy
question
Saw Bands
Started by oregonsawer on Sawmills and Milling
Last post April 11, 2010, 01:14:46 PM
by oregonsawer
