Baltic Abrasives Technologies
Author Topic: I broke my mill  (Read 2158 times)
Offline Darrel
  • Never throw an unopened log on the burn pile.
I broke my mill
« on: May 11, 2018, 11:00:30 PM »
It doesn't matter why one is in a hurry, haste makes waste. My mill has been at a neighbor's place and I decided that this afternoon was a good time to go get it because I have a job coming up on Monday.  Now about 10' away from the operator's end of the mill were 3 fire killed Pondarosa pines about 18" each DBH.  They have been dead for about 4 years and a stiff wind was blowing and one had broken off at ground level and was leaning hard on the other two and also leaning hard toward the mill.  All I could think was hook up quick and get. And the whole time I had my eye on that busted tree and was ready to run. I could see it leaning more and more and branches were breaking so after what felt like forever I was ready to pull out, but I'm sure it was only a few minutes.
So I pulled out of harms way and did a quick walk around the mill and everything looked to be ok. But thinking about it now, I'm sure that my adrenaline was still flowing and my walk around was consequently a bit too hasty. I got in my truck and drove the half mile home.
My wife was helping me put the carriage cover on and she says, "is this supposed to be crooked?"  My heart did a somersault in my chest and I looked where she was pointing. It is now quite evident that I had not opened the log clamp all the way.
Sheared off 3 of the 4 bolts on the rail side of the mill.
On the loading arm side of the mill, the bolts are larger and in slotted holes and it looks like there was enough wiggle room. I can't see that there was any major damage.
This is what I saw coming in the driveway.
However, da dawg is still happy.
1992 LT40HD
Offline Crossroads
  • lets make some sawdust
    • Kevin Bales faith family farm and portable sawmill
Re: I broke my mill
« Reply #1 on: May 11, 2018, 11:44:41 PM »
Oh bummer Im sorry to see this. Im glad nothing major is broken.
2017 LT40 wide, Kubota l185dt, 2-036 stihl, 2001 Dodge 3500 5.9 Cummins
Offline Chuck White
  • Sawing Mobile since 2005
Re: I broke my mill
« Reply #2 on: May 12, 2018, 06:35:19 AM »
WOW!  That is looks like a very simple fix!
Sometimes we get lucky!
~Chuck~
I LOVE MY SAWMILL
Offline justallan1
  • living and learning
Re: I broke my mill
« Reply #3 on: May 12, 2018, 07:55:43 AM »
I don't know a thing about the stress you put on those bolts when working, but by the looks of them I'd say you caught a break by them breaking when you aren't relying on them, or standing real close.
Feeding cows a couple years ago, I lost a U-joint about 15' from my shop....I celebrated! :D
It's a good day when you get to turn wrenches inside a heated shop. ;D
Offline scully
  • Orange Mills Matter
Re: I broke my mill
« Reply #4 on: May 12, 2018, 08:31:04 AM »
No big deal , should be a reasonably easy fix . I have ripped the front and rear legs clean off my mill and just put new bolts in .
I bleed orange  .
Offline Jim H
Re: I broke my mill
« Reply #5 on: May 12, 2018, 04:55:45 PM »
I did the same thing with the two plane clamp on my mill. Fixing it required a lot of heat and a little bending. ::)
2008 LT40HDG28, autoclutch, debarker, stihl 026, 046, ms460 bow, 066, JD 2350 4wd w/245 loader, sawing since '94 fulltime since '98
Offline Skipper11A
Re: I broke my mill
« Reply #6 on: May 12, 2018, 09:55:03 PM »
Kudos to Woodmizer for a good design, I am really impressed!  Bolts should always shear off before something more dramatic happens.  The alternative story would have been really ugly.
Offline Darrel
Re: I broke my mill
« Reply #7 on: May 12, 2018, 10:12:55 PM »
Yes, it could have been a whole lot worse if knuckle heads weren't taken into consideration during the engineering process. :D
I'll post pics of the repair.
1992 LT40HD
Offline Chuck White
Re: I broke my mill
« Reply #8 on: May 13, 2018, 07:58:11 AM »
Good to hear you got it back together, could have been a whole lot worse!  8)
~Chuck~
I LOVE MY SAWMILL
Offline Darrel
Re: I broke my mill
« Reply #9 on: May 14, 2018, 03:53:37 PM »
Four 3/8 5" bolts hold the clamp to the rail side of the mill.  I had to use an easy-out on the lower two.
Rail side rebolted. The feed chain dried out a bit over the winter so time for a dose of ATF.
Loading arm side ready to go back together.
All back together. And don't forget the anti-seize grease. This bottle has been in my possession for about 40 years. But it still is good.
1992 LT40HD
Offline Chuck White
Re: I broke my mill
« Reply #10 on: May 14, 2018, 04:05:57 PM »
I always put antiseize grease on any bolt or nut I remove from the mill, a little goes a long ways!
Every couple of years, I unbolt the square tube that the clamp rides on, just to clean the sawdust out of it!
~Chuck~
I LOVE MY SAWMILL
Offline slider
  • sawyer,trucker,tree service
Re: I broke my mill
« Reply #11 on: May 14, 2018, 04:22:23 PM »
If you have had that bottle for 40 years you have not been using enough.
al glenn
Offline Darrel
Re: I broke my mill
« Reply #12 on: May 14, 2018, 09:57:42 PM »
I only needed it about once a year and the 20 years I was a nurse I only needed it maybe once. But then I got my old mill about 4 years ago and I have used it way more than ever before. I was scraping the bottom to get enough today so will be getting more soon.
1992 LT40HD
Offline LeeB
Re: I broke my mill
« Reply #13 on: May 15, 2018, 07:31:00 AM »
It does go a long ways. Put a dab on your elbow. By the end of the day you will be covered from head to toe.  :D
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
Re: I broke my mill
« Reply #14 on: May 15, 2018, 11:51:14 AM »
Well no bolts sheared but this happened.
After replacing the pan gasket on my mill I had issues with the contact strip for the hydraulics and inadvertently left the clamp 1/2 way out instead of the in position.
My mill has a 5" step up to the concrete pad and when I pulled the mill in this happened.
Removed the part and it is a local shop too
 get straightened.
It is 1" steel.
Oh well, I need to cut firewood anyway.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Re: I broke my mill
« Reply #15 on: May 15, 2018, 07:59:20 PM »
Wow  good service.
The guy has my piece all straightened out.
$100 bucks and I'm be back in business.
LT40SHDD51
Kubota 900 RTV
Offline Darrel
Re: I broke my mill
« Reply #16 on: May 15, 2018, 10:43:01 PM »
Maybe I am glad I have the old mill with the flip clamp. Sheared off four 3/8 X 5" bolts and only cost me $5.42.
1992 LT40HD
Offline Crusarius
  • Lost in....
    • RockModified.com
Re: I broke my mill
« Reply #17 on: May 16, 2018, 08:54:29 AM »
just make sure you put the same grade bolts in there. :)
Love to see ppl replace low grade bolts with high grade. Especially the ones that think they know better than the engineers who designed it.
Offline Darrel
Re: I broke my mill
« Reply #18 on: May 16, 2018, 09:55:08 AM »
No lines on the bolt heads.
1992 LT40HD
thumbdown
Broke Mill...need advice
Started by Larry on Sawmills and Milling
Last post December 05, 2005, 10:21:57 AM
by Larry
Mill broke tonight, DanGit
Started by mmartone on Sawmills and Milling
Last post February 17, 2013, 03:43:57 PM
by Magicman
Broke it
Started by Corley5 on Sawmills and Milling
Last post May 12, 2002, 08:52:50 PM
by Corley5
It broke
Started by Peter Drouin on Sawmills and Milling
Last post October 19, 2016, 07:55:53 PM
by nomad
