Author Topic: Finally cutting joints  (Read 3342 times)
Offline barasingha
« on: May 12, 2018, 12:26:11 PM »
I have started on my first floor.  It's been a long time coming, but I am now cutting some joinery for the sill plates.
Offline TimFromNB
  • New guy here.
Re: Finally cutting joints
« Reply #1 on: May 14, 2018, 07:40:03 AM »
Awesome! I've been waiting a long time as well...still waiting ;)!
Offline barasingha
« Reply #2 on: May 18, 2018, 06:28:59 PM »
Scarfs are done.  Cutting joist pockets now.
Offline barasingha
« Reply #3 on: May 18, 2018, 06:31:29 PM »
Offline barasingha
« Reply #4 on: May 23, 2018, 03:23:17 PM »
Almost ready for joists.
Offline barasingha
« Reply #5 on: May 24, 2018, 05:54:48 PM »
The small joists are on the cutting boards.
Offline flyingparks
  • If my dog doesn't like you, I don't like you.
« Reply #6 on: May 24, 2018, 10:47:20 PM »
Beautiful! Love that foundation. Where are you?
Offline Runningalucas
« Reply #7 on: May 24, 2018, 10:54:12 PM »
I grew up in central Texas, that's my guess, looks familiar.
To the OP, that's a beautiful foundation!!!
Offline fishfighter
« Reply #8 on: May 25, 2018, 05:36:50 AM »
That sure is nice work.
Offline barasingha
« Reply #9 on: May 25, 2018, 12:21:47 PM »
Guessed correctly.  I am in central Texas.  All of the rocks for the foundation were gathered here on the property.  I am trying to build this house with all local materials (local being Texas.)  The wood is So. Pine from east Texas.  The sand is manufactured at a local quarry from dolomitic limestone.  There is no cement in the mortar, but instead, quicklime produced at Austin White Lime.  It was waterproofed with sodium bentonite from west Texas below grade, and an elastomeric at grade made up by Dallas.
While this isn't a timber frame, or log cabin, this website has been instrumental in my research for the timber parts.  So thank you all for sharing your work and knowledge.  Because this forum is such I good resource, I wanted to show my work to y'all.
What would y'all call this type of construction?  It was commonly used in the historic settlements around here, except they used cypress and post oak.
Offline Hilltop366
« Reply #10 on: May 25, 2018, 12:59:47 PM »
 smiley_thumbsup popcorn_smiley
Offline barasingha
« Reply #11 on: May 25, 2018, 02:02:44 PM »
Along the banks of the creek, you can still see the trunks of cypress trees cut and milled over 100 years ago.
Offline barasingha
« Reply #12 on: May 26, 2018, 08:30:31 AM »
The small joists, spanning 13.5', are 6x10 syp.  The big joists, spanning 21', are 6x14.
I'd like the top of all joists to be level.  The plan was to scoop the big joists down to 10" at the sill plate.  I must cut the small joists down to 9.5" at the sill plates due to inconsistent milling.  That means the big joists would also have to be cut down to 9.5" at the sill.
Scooping out 1/4 of the 14" joists would mean 10.5" at sill plate.  I was already pushing it by planning to cut them to 10".  Now I either need to shim up the small joists, or cut the big joists down to 9.5"
Can anyone walk me thru the engineering of cutting down joists?  Is verticle shear the only thing to watch out for?  Horizontal shear appears fine, requiring only 28 sqin for my loads.  And I always assumed verticle shear was nothing to worry about.  Would you shim up small joists or cut down big joists?
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #13 on: May 26, 2018, 08:47:08 AM »
rule of thumb for floor joists:
Don't violate these rules.
Jim Rogers
Offline Don P
    • Calculator Index
« Reply #14 on: May 26, 2018, 11:07:24 PM »
d is at least 3/4 of h, don't remove more than 1/4 of joist depth. That is a limit in the code and NDS, so I would shim.
Offline barasingha
« Reply #15 on: May 30, 2018, 07:14:39 PM »
Shim it is.  I will set all joists onto sill plates and shim up the floor with a 2x4 sleeper over the joists.
10" joists are cut down to 9.5"
14" joists will be cut down to 11"
More pictures one joists are being set.
Offline WolverineLiving
« Reply #16 on: May 30, 2018, 08:08:11 PM »
That looks like it's going to be amazing once finished!
Offline barasingha
« Reply #17 on: May 31, 2018, 09:02:49 AM »
Thanks.  I hope I live long enough to see it finished.
Offline barasingha
« Reply #18 on: June 07, 2018, 07:26:15 PM »
The cutting board is cleared and the small joists are in place...I have yet to wedge them permanently.
Tomorrow the big boys get put on the chop block.   Still thinking about how to place the big ones, might be too heavy to set by hand.
Offline barasingha
« Reply #19 on: June 07, 2018, 07:39:34 PM »
Cutting the Big Black Walnut - Finally
Started by Swing_blade_Andy on Sawmills and Milling
Last post September 04, 2003, 12:48:35 AM
by WoodChucker
Grizzly 30 finally cutting good!
Started by onorato on Sawmills and Milling
Last post April 21, 2016, 08:22:53 PM
by 4x4American
Box joints
Started by D._Frederick on General Woodworking
Last post November 21, 2009, 12:46:45 PM
by Brad_bb
glueing joints
Started by Woodbilly on Timber Framing/Log construction
Last post October 19, 2014, 07:24:36 PM
by Dave Shepard
