AVAILABLE
Author Topic: Finally cutting joints  (Read 3267 times)
Offline barasingha
Re: Finally cutting joints
« Reply #20 on: June 07, 2018, 07:48:12 PM »
Offline barasingha
« Reply #21 on: July 26, 2018, 07:50:02 PM »
I have finally set the big boys.
And this is how I reached the 35' necessary to set joists:
Offline barasingha
« Reply #22 on: July 26, 2018, 08:01:05 PM »
Many years ago, while on a construction site, I saw some timber framers cutting timbers.  They were sawing with a big skill saw, flipping timber, and finishing cut on the other side.
I asked, "why dont y'all use a chainsaw?"
"Because we're carpenters, not butchers," one responded.
If there is any truth to that mans words, then consider me a butcher.
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
« Reply #23 on: July 26, 2018, 08:08:29 PM »
You can do a bunch of things with a chainsaw that are not critical cuts that can save a bunch of time. I want the new Milwaukee 18 volt battery saw for making the odd cut. Mafell makes a very expensive chainsaw for timber framing. I think it's $8k.
Offline TimFromNB
  • New guy here.
« Reply #24 on: July 26, 2018, 08:31:44 PM »
Looking good!
Offline barasingha
« Reply #25 on: July 27, 2018, 09:28:54 AM »
Here is how it all locks together.
And here is how I'll raise the floor over the small joists to be level with big joists using 2x4 sleepers.
Offline Runningalucas
« Reply #26 on: July 27, 2018, 01:03:19 PM »
Keep'em coming; enjoying the build progress.  8)
Offline ljohnsaw
« Reply #27 on: July 27, 2018, 05:36:42 PM »
 :P
Waiting to see how this is going to work.  Don't quite understand why the ends are cut the way you did and what that "walkway" thing down the middle is all about.  Love the rock work!
John Sawicky
Offline barasingha
« Reply #28 on: July 27, 2018, 06:55:09 PM »
The rock walls will continue vertically.  There will however be doorways between sections of the house divided by the rock walls, thus the need for a level floor.  The 2x4 sleepers will not pass thru the rock wall, as of yet unbuilt, but instead support about 6" of flooring.  The photo was to check the level.
The joists are cut that way to facilitate the running of wires and plumbing  between end of joist and rock walls; to be hidden later with trim boards.
The overhang on top of big joists, and the over hanging 2x4 upon the smaller joists, support about 6" of flooring upto the rock walls.
Hope that makes sense.
Offline ljohnsaw
« Reply #29 on: July 27, 2018, 07:54:30 PM »
OK I think I get it.  That will be a big mechanical chase on the joist ends.  How much head room is that below the joists?  Just a crawl (crouch) space or is it walkable?
John Sawicky
Offline barasingha
« Reply #30 on: July 27, 2018, 08:00:20 PM »
The bedrock floor is not level.  Clear space under joists ranges from 7'10" to 8'5".
I plan to have a full staircase to down below.
Offline barasingha
« Reply #31 on: July 27, 2018, 08:09:42 PM »
Here you can see the empty foundation.  At far end there is scaffold standing.  At far left is the construction staircase.
Offline samandothers
« Reply #32 on: July 28, 2018, 09:52:26 AM »
Very interesting build and beautiful rock work!
Offline Bindian
  • Gender: Female
« Reply #33 on: September 06, 2018, 09:04:13 PM »
I love your build and location.  I was planning on retiring in the Hill Country, but my daughter announced she will be moving back here from the Austin (Manor) area.  So no rocks in my future plans, just tons of pine trees here!
        hugs,  Brandi
Cutting the Big Black Walnut - Finally
Started by Swing_blade_Andy on Sawmills and Milling
Last post September 04, 2003, 12:48:35 AM
by WoodChucker
Grizzly 30 finally cutting good!
Started by onorato on Sawmills and Milling
Last post April 21, 2016, 08:22:53 PM
by 4x4American
Box joints
Started by D._Frederick on General Woodworking
Last post November 21, 2009, 12:46:45 PM
by Brad_bb
Fitting joints
Started by Jim1611 on Timber Framing/Log construction
Last post December 14, 2014, 03:02:21 PM
by Dave Shepard
