Arborwear
Author Topic: band blade type  (Read 174 times)
Offline DDW_OR
band blade type
« on: May 12, 2018, 02:32:55 PM »
would it be a good idea to make a poll for band blade type
Munkfors
wm
kasco
cutting edge
Simmons
Timberking
and maybe one for different types of sharpeners
cooks cat claw
dremel
Woodmizer Drag style
Timberking Drag style
woodland
Timberline
Gam
EZ
Home made Drag style
Home made CBN style
will let this post run for a week to get everyone's ideas before i start any polls
would be similar to my last pole
what degree bandsaw blade in Sawmills and Milling
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline WV Sawmiller
    • Green's Sawmill Services
Re: band blade type
« Reply #1 on: May 12, 2018, 03:13:29 PM »
   I'd bet you will be about as successful adding sawmill and vehicle types to your poll. Without knowing the conditions, equipment used and experience level of the user I don't how accurate such a poll would be. Good luck.
We have an old band type mill saw
Started by David Rogers on Sawmills and Milling
Last post February 28, 2008, 10:32:18 PM
by Fla._Deadheader
Upgrade WM drag type band sharpener
Started by pineywoods on Sawmills and Milling
Last post May 04, 2016, 10:34:32 PM
by pineywoods
my acme band saw blade (captive needle bearing )roller blade guide
Started by buildthisfixthat on Sawmills and Milling
Last post January 16, 2012, 09:34:15 AM
by 5quarter
Blade type
Started by revid on Sawmills and Milling
Last post March 12, 2018, 08:24:03 PM
by starmac
