Baltic Abrasives Technologies
Author Topic: Simpson Tie Down Strap Past Mudsill onto Post Face  (Read 575 times)
Offline jb9
« on: May 13, 2018, 09:28:39 AM »
Hello,
Does anyone have any good ideas on how to get a Simpson Tie Down strap past a mudsill?  I have internally bumped out pilasters and I need to run the strap against the post face.  Could I cut a kerf in the PT mudsill?  I have attached a couple of renderings from my model to show what I am trying to accomplish.  I am stacking ICF (Insulated Concrete Form) blocks now and when I get to the top course, I need to come up with something that will work before I pour the concrete.
Thanks.
Offline Don P
    • Calculator Index
Re: Simpson Tie Down Strap Past Mudsill onto Post Face
« Reply #1 on: May 13, 2018, 11:45:27 AM »
I guess I'm failing to see the collision, it looks like its working in the sketch. Can you switch the sketch to transparent view and describe the problem more? You can bore or lightly kerf the sill.
Offline jb9
« Reply #2 on: May 13, 2018, 04:02:09 PM »
My bad...  I drew in a 2x6 mudsill and I think I want to use a 2x12 mudsill.  If I went with a wider mudsill, I think I would get a collision.  I think I could cut away the section around the post and then put a square section of PT in there.  Does this make sense?
Offline Don P
    • Calculator Index
« Reply #3 on: May 13, 2018, 06:58:47 PM »
It sounds like you could just drill a hole or cut a slot in the sill and feed the strap up through it.
Post on mudsill vs. on post base
Started by kodl on Timber Framing/Log construction
Last post October 12, 2018, 07:48:16 PM
by Don P
Simpson post anchor for 8x10?
Started by mrbrb on Timber Framing/Log construction
Last post October 29, 2013, 10:43:08 PM
by razor
Use of Simpson Strong Tie Post Brackets
Started by Jjoness4 on Timber Framing/Log construction
Last post April 30, 2017, 08:52:32 PM
by Brad_bb
Simpson Strong tie for concrete foundation to post
Started by mmhailey on Timber Framing/Log construction
Last post June 22, 2010, 03:54:32 PM
by Raphael
