Author Topic: What's a fair deal (and advice) for a small guy needing logs?  (Read 1872 times)
Offline cbay
Several questions,   i'm a beekeeper and trying to grow my operation.   Need pine badly for equipment.   No pine around my area.   Got an Lt15 and want to save money milling my own boards.
If i can find a source for pine saw logs what is a fair price?    Found one about an hour away and he wants .50 / bf.   Don't think i want to swing that.   Another about 2 hours away quoted my .40 / bf.   That sounds a little better.   Was hoping to find in the 30ish range but it doesn't look like that's going to happen.
Our trailer is a small 5x10 dump so it wouldnt be worth the expense to go all that way for such a small load, so my neighbor offered to haul a bigger load with his 16 ft trailer and truck.    Any idea if a 1000 bf would be too much for a 1/2 ton truck?
A real shame i can't use lumber from our 80 acres, but the oak, hickory and walnut is too heavy for bee hives.   Got sycamore  as well but was reading that they walk around too much by the time they dry.
Any suggestions around this whole topic would be greatly appreciated, and thank you in advance.
Regards,
Chris
Offline mike_belben
  • Pulp Friction
Re: What's a fair deal (and advice) for a small guy needing logs?
« Reply #1 on: May 14, 2018, 10:27:08 PM »
Saw some of your oak, sell the lumber, buy some finished pine lumber, tend bees, profit.
Revelation 3:20
Offline Southside logger
« Reply #2 on: May 15, 2018, 08:12:21 AM »
Mike has very good advice there. 1000 BF of SYP logs will weigh between 10,000 and 12,000 lbs, not including the trailer. Not something I would want to do with a half ton pickup that I owned.
Woodmizer LT35 sawmill, KD250 kiln, BMS 250 sharpener and setter
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
    • THEE Forestry Forum
« Reply #3 on: May 15, 2018, 08:22:07 AM »
That can't be right is it? 10 to 12 lbs a bf?  Oak is only 6
« Reply #4 on: May 15, 2018, 08:47:32 AM »
You are right Jeff - 5,000 to 6,000 lbs, per 1000 bft, it's that new math.
Offline Pclem
« Reply #5 on: May 15, 2018, 08:56:42 AM »
I thought there was 2.2-2.5 cords in 1000 bf (of logs). That would be pushing 10-12k lbs wouldn't it? ( for oak ). Don't know about syp weight, but a little over 2 cords of logs? That's a big load
Dyna SC16. powersplit. supersplitter. firewood kilns.bobcat T190. ford 4000 with forwarding trailer. a bunch of saws, and a question on my sanity for walking away from a steady paycheck
Offline cbay
« Reply #6 on: May 15, 2018, 09:08:11 AM »
Thanks,
Mike, we really don't want to lose oaks off the property if we can help it.    They are precious to us just to have them.   Otherwise that would make a lot of sense.   Maybe some hickory in the future though.
We will be sure and give thought on the weight and be safe about it.
Offline mike_belben
  • Pulp Friction
« Reply #7 on: May 15, 2018, 09:15:46 AM »
I had to go look at my slip from brown foreman.. I sold 1300 bf doyle of WO stave logs and weighed on their scale before and after at 23,500 of logs.  So 18lbs per bf.  Ive heard all oaks avg at 14-16 bf doyle.
Revelation 3:20
Offline mike_belben
  • Pulp Friction
« Reply #8 on: May 15, 2018, 09:23:22 AM »
I do think itll be 10-12k and if its a 5 lug car trailers theres just not enough brakes, tire or axle to be certain you wont blow or bend something.  On a 3 axle id do it, if they work triaxles have great brakes.  A half ton truck will just skid in a panic stop with that much behind it.  Btdt.
If its close, flat and all backroads maybe.  If its far, hilly and interstate definitely bad.  If DOT sees 1000bf behind a half ton you are getting the portable scales and a roadside colonoscopy.  Maybe an impound or criminal charge.  Done that too.
Revelation 3:20
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #9 on: May 15, 2018, 03:42:56 PM »
Why not use Cedar for bee equipment?
Light, rot resistant, and abundant in SW MO.
Offline luvmexfood
« Reply #10 on: May 15, 2018, 04:17:54 PM »
I have a half ton pickup. Use a flatbed trailer. No gooseneck. Just travel back roads except maybe a mile on fourlane to the log yard. Have hauled about 450 bd feet of poplar and it's about all I want back there. It's only about six miles and I crawl along.
Give me a new saw chain and I can find you a rock in a heartbeat.
Offline luvmexfood
« Reply #11 on: May 15, 2018, 04:53:33 PM »
My post may have been confusing. That is the largest load of one species. Could you possibly get someone to furnish the logs and saw on the shares.
Offline cbay
« Reply #12 on: May 15, 2018, 09:40:02 PM »
Thanks guys,  wow i was underestimating the weight and glad i posted here about this.   Thank you all for the feedback.
May have to reconsider this and look for better ideas.
TKehl,
cedar is around here and have considered it even though it's more expensive.   Would definitely last longer.
luvmexfood,
not sure how that would work, maybe i can look into that...
Bottom line is i would like to have some good usable lumber here as inexpensive as possible.   Going to check with the local amish sawmill and see if he gets any poplar.   Talked to him once but only asked about pine - which he doesn't see.
He wants some pollination for his vegetable business so maybe something could come of it.
Offline Jeff
  • Fearless Leader
  • Proverbs 13:20
« Reply #13 on: May 16, 2018, 05:05:42 AM »
I was thinking you were talking lumber weight.
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #14 on: May 16, 2018, 07:35:12 AM »
5 tons per MBF is about right for SYP logs depending on the size of the logs.  Really big logs will be more like 4 tons per MBF.
Offline BargeMonkey
« Reply #15 on: May 16, 2018, 09:40:27 PM »
 I'm sending redpine to Deposit NY right now and its 5ton per mbdft conversion.
 .50 cents would buy you gorgeous pine up here, its .30 cents delivered for redpine, white pine, hemlock. I've got a mountain of 8-10-12ft stuff I've been selling cheap on this job, the overseas market is all 13-6 19-6 right now.
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #16 on: May 16, 2018, 11:46:43 PM »
Generally, as a rule of thumb when I'm hauling with my DOT registered and regulated diesel pickup and double axle, single wheel gooseneck, I try to cut the log loaders off at 1,000 bdft of hardwood, or 1,100 bdft of pine to get me to just under CDL weight of 26,000 lbs on the truckers scales.  Sometimes I'm a thousand lbs or so light, but better that than to come in heavy.  I'd never want to do that load in a half ton pickup.
Sycamore flatsawn moves a lot, but for building bee boxes, I'd give it a try.  Quartersawing it to make it more stable would certainly work.
Most properties have more than oak and hickory, what other species do you have?  I'd also seriously consider selective harvest on distressed trees or trimming back fencelines and property boundaries to scavenge usable timber.
How many bdft does a hive take?  Seems like it wouldn't take too many logs to make a lot of hives.
HobbyHardwoodAlabama.com
Offline mike_belben
  • Pulp Friction
« Reply #17 on: May 17, 2018, 12:27:16 PM »
I think.pine is $200/thou here, ive not cut a one.
Red maple is the pine of my life.  And i sure do try to smother it in the cradle.
Revelation 3:20
Offline cbay
« Reply #18 on: May 17, 2018, 01:34:38 PM »
YellowHammer,
it takes around 6 bf just for a hive body.   Then lids and bottom boards, inner covers...    So to make several hundred completed boxes takes up quite a bit of lumber.
Not real experienced with a tree or two out there, but think one that we have a few of is hackberry.   I was thinking they were a cottonwood but after looking online they look more like hackberry.     Don't know how they would work out.
Bargemonkey,
I would absolutely flip out to have pine delivered for anywhere in the .30 range.   Would be swimming in bee equipment come this winter.  Lol
It's early yet, but did find out that not allowing wood enough time to dry makes for some wonky hives. lol     So trying to get ahead of things for this winter.
Offline TKehl
    • Kehlhof Ranch
« Reply #19 on: May 17, 2018, 02:03:30 PM »
Hackberry would be fine if quarter sawn.  It's related to elm and likes to twist if flat sawn.  Nice and light when dry, but rots quick.  I'd only use it someplace where it can shed water quickly, even then it's so so.
TKehl,  cedar is around here and have considered it even though it's more expensive.   Would definitely last longer.
I see milled cedar in your neck of the woods selling at $.60/bf on C-list.
If that's too much, most farmers in the area will let you have all the cedar you can cut for free.  Sometimes I get paid to cut it...
It's early yet, but did find out that not allowing wood enough time to dry makes for some wonky hives.      So trying to get ahead of things for this winter.
Cedar.  One of the quickest drying and most forgiving woods out there.
Just saying...  ;)  (No I'm not getting paid by the Cedar checkoff, but should be.   :D)
advice for milling small diameter logs
Started by yukon cornelius on Sawmills and Milling
Last post January 28, 2014, 06:56:28 PM
by Ianab
how to make a fair deal?
Started by Engineer on Forestry and Logging
Last post November 21, 2004, 02:02:27 PM
by SwampDonkey
Needing a drawing for a small TF project
Started by opticsguy on Timber Framing/Log construction
Last post November 13, 2017, 01:21:32 PM
by opticsguy
New here, just getting started and needing advice!
Started by roberts.isaiah on Forestry and Logging
Last post July 26, 2011, 08:30:56 AM
by chevytaHOE5674
