KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: LT-40hd fire  (Read 1106 times)
Offline carhartted
LT-40hd fire
« on: May 15, 2018, 07:15:13 AM »
I was running my new to me LT-40HD for the first time over the weekend. Put close to 20 hours on it, the mill has 2000 hours. On the second day of sawing I saw smoke coming from the main frame rail on the hitch end. Started taking covers off and found a bunch of smoldering sawdust inside the tube. Dumped a bunch of water in there and cooled it down. Any idea what could of caused it?  Sawed two more days after that with no more issues.
Here's to making sawdust.
Offline tacks Y
Re: LT-40hd fire
« Reply #1 on: May 15, 2018, 07:49:04 AM »
No ideas, but I use a leaf blower on mine to clean up. Try to keep it cleaned out after use.
Offline SawyerTed
  • Hi, I have a saw dust addiction and fishing pox.
Re: LT-40hd fire
« Reply #2 on: May 15, 2018, 08:14:05 AM »
Could the sawdust have been greasy or damp?  Spontaneous combustion could have been the case if the sawdust was greasy or oily.  It's also possible if the sawdust was wet and was decomposing.
Woodmizer LT35HD25, Kubota MX5100, IH McCormick Farmall 140, Granberg Alaskan Chainsaw Mill, Husqvarna 372XP, Husqvarna 455 Rancher
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: LT-40hd fire
« Reply #3 on: May 15, 2018, 08:26:28 AM »
Either that or electrical.  I would thoroughly wash/clean it out and do some serious investigation.
Offline carhartted
Re: LT-40hd fire
« Reply #4 on: May 15, 2018, 10:27:41 AM »
Electrical is what I thought but the only electrical that runs through is the trailer lights and I have never used them. Was thinking the power strip on the side or ground on the bottom got hot.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
Re: LT-40hd fire
« Reply #5 on: May 15, 2018, 01:32:57 PM »
Yup, one of those two.
Offline sparks
  • Sponsor
  • Woodmizer Electrical Tech
Re: LT-40hd fire
« Reply #6 on: May 15, 2018, 05:16:36 PM »
The pin wasn't pulled on the electric brakes switch was it?
\"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves.\" Abraham Lincoln
Offline Chuck White
  • Sawing Mobile since 2005
Re: LT-40hd fire
« Reply #7 on: May 15, 2018, 06:36:33 PM »
I've been following this post with interest!
I hadn't thought about the possibility of the electric brake system being under load (with the pin pulled), but that makes more sense to me now!
~Chuck~
I LOVE MY SAWMILL
Offline LeeB
Re: LT-40hd fire
« Reply #8 on: May 16, 2018, 04:04:25 AM »
Hmmm, interesting and it also reminds me I need to order a new pin to replace the piece of wood I stuck in mine years ago.
Offline carhartted
Re: LT-40hd fire
« Reply #9 on: May 16, 2018, 07:10:01 AM »
The sawmill has surge brakes. Is there some electrical side to them as well? The only wiring I saw in the tube was for the trailer lights.
Offline Chuck White
Re: LT-40hd fire
« Reply #10 on: May 16, 2018, 04:03:09 PM »
Shouldn't be any electrical wires going down through the tube other than your tail light wiring if you have surge brakes!  ;)
~Chuck~
I LOVE MY SAWMILL
1993 Lt-40HD
Started by Red Pill on Sawmills and Milling
Last post February 13, 2012, 08:28:48 AM
by Red Pill
Dialing in the LT-40HD
Started by Okrafarmer on Sawmills and Milling
Last post September 29, 2012, 01:07:09 AM
by Okrafarmer
WM LT 40HD vs. LT40SHD????
Started by bikedude73 on Sawmills and Milling
Last post September 21, 2009, 08:07:24 PM
by MartyParsons
motor cycle cover for Lt 40hd
Started by haywire woodlot on Sawmills and Milling
Last post March 13, 2013, 05:36:58 PM
by haywire woodlot
