Baltic Abrasives Technologies
Author Topic: Stilh Ms 290 farmboss  (Read 1055 times)
Offline boboyee58
« on: May 15, 2018, 11:34:49 AM »
Stalls out when chain brake is applied
Offline boboyee58
Re: Stilh Ms 290 farmboss
« Reply #1 on: May 15, 2018, 11:37:25 AM »
Stalls out when chain brake is applied looking for a fix I think it's the clutch but not sure
Offline sawguy21
« Reply #2 on: May 15, 2018, 11:42:23 AM »
Welcome to the forum! Either the sprocket bearing is seized or the clutch has come apart. Pop the clip off and remove the drum.
Offline boboyee58
« Reply #3 on: May 15, 2018, 11:46:49 AM »
already tried new bearing and new clutch springs
Offline ZeroJunk
« Reply #4 on: May 15, 2018, 02:48:41 PM »
Did you clean or replace the drum ?
If the chain isn't turning at idle I don't see why the brake would do anything.
It shouldn't be.
Offline boboyee58
« Reply #5 on: May 15, 2018, 03:29:57 PM »
Did not replace drum and chain is moving at idle
Offline Hilltop366
« Reply #6 on: May 15, 2018, 03:56:01 PM »
Does the clutch drum turn freely by hand with the saw shut off and cover removed.
Offline BradMarks
  • Foresters are TREE-mendous
    • Pacforest Supply
« Reply #7 on: May 15, 2018, 04:41:33 PM »
"Chain moving at idle" indicates a very loose chain, or too high idle rev, or both. I have an old 026 that if the throttle gets goosed with brake on it will sputter out, as if flooding the carb.
Offline boboyee58
« Reply #8 on: May 15, 2018, 07:28:41 PM »
Clutch cover turns freely by hand with a little squeal
Offline boboyee58
« Reply #9 on: May 16, 2018, 08:15:54 PM »
Remove clutch cover cleaned everything thoroughly reassemble and all is good.
Thanks for all the input
Offline Hilltop366
« Reply #10 on: May 16, 2018, 08:54:43 PM »
 smiley_thumbsup
Offline Weekend_Sawyer
  • Jack of all trades, master of fun
« Reply #11 on: May 17, 2018, 09:52:19 AM »
My neighbor brought his 250 over with the same problem. The clutch was filled with debris. We cleaned it out and she works fine now.
About every 2nd sharpening I flip my bar. While I have it apart I blow everything including the bar channel out with air. Makes me and my saws happy.
Jon
Imagine, Me a Tree Farmer.
Jon, Appalachian American Wannabe. ... and it looks like my dream will come true!
028 Stilh
Started by turkeyhtrb on Chainsaws
Last post March 14, 2009, 07:53:40 PM
by Jim Spencer
041 Farmboss still going strong
Started by gspren on Chainsaws
Last post February 01, 2013, 08:16:15 PM
by JuniperBoss
stilh saws
Started by redneck logger on Chainsaws
Last post February 11, 2009, 10:07:07 AM
by chevytaHOE5674
Stilh 029 Super
Started by bdsmith on Chainsaws
Last post July 19, 2017, 04:15:18 PM
by bdsmith
