Author Topic: Rolly ll versus four-roller  (Read 730 times)
Offline deastman
« on: May 16, 2018, 07:06:23 PM »
How do they compare? The Rolly looks more heavy duty, does it work better in big hardwood,  more delimbing power than the four-roller? My four-roller has been really reliable but it struggles in bigger hardwood, I know it has a lot to do with the size of the carrier and mine is kinda small
Samsung 130 LCM-3 with Fabtek 4-roller and Cat 554 forwarder, Cat EL 180 excavator, Cat D3C dozer, Cat D7E dozer, '92 Ford LTL 9000 dump, Easy-2-Load 25 Ton tag-a-long, current project under construction: '91 Peterbilt 379 with a Hood 8000 w/extenda-boom loader
Offline BargeMonkey
Re: Rolly ll versus four-roller
« Reply #1 on: May 16, 2018, 09:35:21 PM »
 I bought quite a bit of hardwood off someone with a Timberpro / Rolly last yr and once it got into bigger limbs you where crudely sawing them off, much sweep you could see how it gouged. I'm seeing more and more of them for sale, I've talked with Woodland on some parts and they seem to stand behind the Rollys pretty good.
 Have you seen the "Timberheads" made in WI ? I think at somepoint that's the route I'm going, the 24" dangle on a 153. They do also make 2x fixed heads which do 24-28".
Online Skeans1
« Reply #2 on: May 16, 2018, 09:42:15 PM »
Another option would be a skidmore head.
Offline bushmechanic
  • Someone else has it worse than you.
« Reply #3 on: May 17, 2018, 05:13:21 AM »
Well the four roller still has only two drive motors on it and I see there are conversion kits now to change them to two rollers. I can't comment on the Rolly as I have never saw one here.
Online Skeans1
« Reply #4 on: May 17, 2018, 07:01:24 AM »
One huge advantage with the 4 roller heads is you can drive them up a tree vs a two in a kink youíll be stuck even with a float.
Offline deastman
« Reply #5 on: May 18, 2018, 07:56:51 PM »
Those Timberheads look like a nice head. I think the dangle heads follow the tree better but I'm not sure if they work better in hardwood.
Online Skeans1
« Reply #6 on: May 18, 2018, 07:59:37 PM »
Most of the newer fixed heads have a float function that will allow it to follow the tree vs drive them with your feet like the 2000 head.
Rolly ll versus Fabtek 4-roller
Started by deastman on Forestry and Logging
Last post March 29, 2016, 07:31:54 PM
by deastman
Risley Rolly head
Started by logger444 on Wanted
Last post June 27, 2009, 10:08:55 AM
by logger444
Tigercat 822 with rolly 2 rotosaw
Started by Kingkodiak on Forestry and Logging
Last post April 18, 2018, 04:48:36 AM
by Riwaka
Risley Rolly II Heads
Started by bkellyvtme on Forestry and Logging
Last post February 24, 2013, 09:17:37 PM
by CTL logger
