Author Topic: Timber Peg Size question  (Read 1061 times)
Offline shinnlinger
« on: May 17, 2018, 09:23:42 PM »
H<brH>
Shinnlinger
Offline shinnlinger
Re: Timber Peg Size question
« Reply #1 on: May 17, 2018, 09:28:03 PM »
Hello,
My construction class is building an outdoor classroom at our school and we are getting to peg time.  Normally I would use a bed on my planer to make octagonal pegs but I happen to have a number of lathes and a number of students who are fairly proficient turners.  I also have a duplicator that was just donated so we are trying it out.  My question is do I want the peg to be a hair larger than the hole or pretty true?  Do I want an 1-1/16th peg for a 1 inch bore?  Red oak pegs and a white pine frame.
Thanks.
Dave
Shinnlinger
Offline ljohnsaw
« Reply #2 on: May 17, 2018, 11:09:43 PM »
I'm sure @jim_rodgers will be along shortly.
When doing octoganol pegs, the flats would be 1" and the points will be larger and can conform a little.  Being 1/16" larger overall, I think that would get a little bit tight.  Are you making the pegs with a slight taper?  Maybe go from 1" up to 1-1/16".  Assuming you are through bored, you could drive until tight.
John Sawicky
Offline flyingparks
  • If my dog doesn't like you, I don't like you.
« Reply #3 on: May 18, 2018, 12:35:43 AM »
I like a 1" peg for a 1" hole. That's just me. Its always worked.
Offline TimFromNB
  • New guy here.
« Reply #4 on: May 18, 2018, 08:00:57 AM »
I was just reading a few passages on this in Benson's book this morning. An octagonal peg that is over sized may work, because the pine is soft and can absorb some of it (on the points). However, for a round peg, where the entire surface is over sized, I would be scared to split the hole. He suggests shaving a bit off on two sides to create a slight oblong form. It is in the tips section near the end of the Timber Frame Workshop book.
Just my 5 cents.
Offline Heartwood
  • Will Beemer
    • Heartwood School
« Reply #5 on: May 18, 2018, 09:01:44 AM »
Dave,
Are you going to drawbore the joints? If so, the pins should be tapered 1/8" under at the start with the nominal hole diameter reached at the point on the pin where the tenon will be, and straight from there on to the other end. If you can't do this taper on the lathe then drawknife or block plane the pins after. Then put a narrower point on the pin for a few inches to get it started in the drawbore. Drive the pin until the joint is tight or far enough so this point is outside the far end of the timber and cut it off (if wanted); include this excess when determining where the tenon will ultimately be on the pin.
If you're not drawboring, then make the pins 1" all the way, not any bigger.
Offline LeeB
« Reply #6 on: May 18, 2018, 12:19:29 PM »
Just a question about drawboring, Would it be possible to drive the peg in further at a later date as the joints loosen up? Don't shoot me on this one. I know nothing about timber framing.
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #7 on: May 18, 2018, 02:11:16 PM »
Dave,
x2
Jim Rogers
Offline Brad_bb
    • My timberframe blog
« Reply #8 on: May 18, 2018, 03:15:34 PM »
For a line to line fit, you want a 1" peg for a 1" hole.  I like have a die on hand.  Drill a 1" hole in a heavy piece of steel.  You want to be able to clamp the steel to some timber drops that you can put on some timber saw horses.  You use the die to drive the peg through.  I did this on the last frame.  I had riven octagonal pegs (white oak) and I drove them through the die with a 3lb hammer.  The first time you drive them through they remove the bulk of material but they compress a little.  They weren't a good fit or the peg holes, so I drove them through a second time and it shaved a little more off and the fit was then good.  You can drive them a third time (they go through pretty easy by then) but it removes very little.
I like green riven peg blanks and as soon as I get them I put them in a rubbermaid tote of water to keep them wet.  This way they are easy to draw knife if you're draw boring, or if you're just putting a point on one you're going to do line to line fit.  Then I let them dry out for a couple months before driving them through a die.
Offline Heartwood
  • Will Beemer
    • Heartwood School
« Reply #9 on: May 18, 2018, 05:23:25 PM »
Lee,
The beauty of drawboring is that the pin acts as a spring and the joint shouldn't get loose as the timbers dry. Assuming the pin is dry and the timbers are green.
By NOT drawboring, as the timbers dry, the joint will probably open up, unless you're really lucky or anal about pin location and grain direction (pins should be located closer to the shoulder of the joint where you don't want shrinkage to show up).
Offline LeeB
« Reply #10 on: May 18, 2018, 09:25:55 PM »
Thanks Heartwood.
Offline PA_Walnut
« Reply #11 on: May 30, 2018, 09:45:50 PM »
I am not a timber framing expert, but the dudes I've seen who specialize in timer framing rive the material, not turn it. When you turn, there's always the grain runout issue. Riving doesn't have this issue.
I discovered the joy of riving when I learned to make Windsor chairs. It was an adventure in drawknife and spokeshave work. Now, I use both ALL THE TIME...some of my favorite tools. Add a shave-horse for even more joy!
Good luck.
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Timber size calculator and timber frame design.
Started by Joe Vachon on Timber Framing/Log construction
Last post July 07, 2017, 10:25:46 PM
by Roger Nair
Timber size criteria
Started by scgargoyle on Timber Framing/Log construction
Last post August 14, 2007, 10:34:23 PM
by Don P
Timber Frame Size ?
Started by Remle on Timber Framing/Log construction
Last post December 05, 2013, 01:25:12 PM
by Thehardway
wood shed timber size
Started by ktm250rider on Timber Framing/Log construction
Last post April 22, 2015, 03:16:24 PM
by shinnlinger
