Author Topic: pine poles  (Read 704 times)
Offline Bosco
pine poles
« on: May 22, 2018, 08:57:29 AM »
I've been clearing land that has tons of Ponderosa Pine, I've got "farwood" stacked more than I need or can give away. I was wondering if I could make some fence poles? Is there a easy way to debark and pressure treat? There is a mill near by maybe I could barter some logs for posts, but was wondering if there was a homestyle method ?
Offline firefighter ontheside
  • I like trees.
Re: pine poles
« Reply #1 on: May 22, 2018, 05:04:49 PM »
Are they green?  Might be able to debark with a pressure washer.
Woodmizer LT15
Kubota Grand L4200
Stihl 025 and MS291
2017 F350 Diesel 4WD
Offline GeneWengert-WoodDoc
Re: pine poles
« Reply #2 on: May 23, 2018, 03:45:32 AM »
Indeed, there are "farm" methods in old books for treating poles.  The first step is drying them in order to make room for the preservative.  I a, not sure what preservative is approved for DIY treating, if any.  Borates cannot tolerate wetting, as they will leach out.  Some of the others, like creosote, are no longer considered safe.  Others require licensed users.
Offline Ianab
Re: pine poles
« Reply #3 on: May 23, 2018, 04:11:23 AM »
That's the problem, anything that's toxic enough to preserve a pine fence post is also toxic enough to be regulated and need all sorts of permits and equipment to use.
Offline Dakota
  • Swing'en in South Dakota
Re: pine poles
« Reply #4 on: May 23, 2018, 08:20:14 AM »
The trees on my place are 99% ponderosa pine.  They just don't make good posts.  Years ago we used to treat some posts with Pinta and get a few years extra use, but that's outlawed now.
Dave Rinker
Offline DelawhereJoe
  • Trapped in Delawhere
Re: pine poles
« Reply #5 on: May 23, 2018, 10:20:03 AM »
Foundation coating / fence black ?
pine poles
Started by phuss on Wanted
Last post July 03, 2012, 10:16:08 PM
by bill m
red pine poles
Started by newkirkmills on Forestry and Logging
Last post July 13, 2010, 03:39:18 PM
by Clark
Treating Pine poles
Started by Hitchcock Woods on Drying and Processing
Last post May 21, 2015, 11:01:33 AM
by beenthere
Ponderosa Pine Poles
Started by 904man on Timber Framing/Log construction
Last post December 10, 2014, 10:11:02 PM
by Jim1611
