AVAILABLE
Author Topic: Building a solar kiln  (Read 381 times)
Offline Wes06
« on: May 26, 2018, 10:59:41 AM »
Im wanting to build a solar kiln an was wondering if i could use tin to line the outside an inside walls instead of using wood?   Does it matter at all?  I have some used tin id like to use it up.  Any answers would be appreciated
Offline GeneWengert-WoodDoc
Re: Building a solar kiln
« Reply #1 on: May 26, 2018, 04:23:23 PM »
Does not matter at all.  Just use lots of butyl rubber latex caulk on all joints between sheets, corners, floor, etc.  Of course, the high humidity and acidic environment would be tough on most tin panels on the inside walls.
Pre-build solar kiln questions(Photos of kiln building progress)
Started by caveman on Drying and Processing
Last post April 17, 2016, 06:35:35 PM
by caveman
Building Solar Kiln
Started by GF on Drying and Processing
Last post June 02, 2004, 07:36:05 PM
by Carl_B
Building a Solar Kiln That Will Fit On My Trailer
Started by Tree Dan on Drying and Processing
Last post July 11, 2015, 05:59:44 PM
by Tree Dan
question
Questions About Building A solar Kiln
Started by sawmillhand on Drying and Processing
Last post November 23, 2013, 01:53:51 PM
by Planman1954
